Is the LT1 externally or internally balanced?
Old Oct 21, 2018 | 06:38 PM
ArcticWhite's Avatar
ArcticWhite
Default Is the LT1 externally or internally balanced?
It is highly likely that I will be rebuilding my engine with non drop-in rods and pistons. Is the LT1 fully internally balanced? In other words, do I have have to worry about the clocking of the damper and flex plate at all? When I send the crank/rods/pistons to be balanced, are the damper and flex plate required to be included?
Old Jan 5, 2021 | 02:16 PM
ArcticWhite
No one? Every web search I do only comes up with the 90's LT1 and LT4 engines.
Old Jan 5, 2021 | 03:53 PM
ronsc1985's Avatar
ronsc1985
https://helpcenter.jegs.com/hc/en-us...ce-Cheat-Sheet
Old Jan 5, 2021 | 06:06 PM
Mitch03Z06's Avatar
Mitch03Z06
There is a You Tube video about the building of the LT5 engine (
) . I believe they (Chevrolet high performance group) were doing a demo build at SEMA 2019. I think they mentioned that the only engines that were factory balanced were engines that were coupled with a manual trans. This was external, vibrations from the engine traveled through to the shifter. The balance was done to stop the complaints. Evidently the vibrations were not a prevalent in automatics.
Old Jan 6, 2021 | 11:08 AM
Katech_Mike's Avatar
Katech_Mike
Premium Supporting Vendor
All LS and LT engines from 1997+ are internally balanced.
To Is the LT1 externally or internally balanced?
