C7 Z51 Factory Driveshaft & Differential Power Limits
Pretty much what the title says.
What are the limits on the stock driveshaft and differential when it comes to HP levels, of course wheel HP.
I live in Coloraro Denver and currently I am at 712rwhp SAE corrected.
Took it to the drag strip this summer and struggled to get traction with my Pirelli PZero's.
Next year I'm wanting to get a set of wheels and tires just for the drag strip.
I'm wondering if my Driveshaft and Differential wont go to **** with stickier tires.
Since I live in Colorado and with out high Air Density, I know my car isn't putting down 712whp at this altitude. So I'm thinking that it should be able to handle it.
I was looking into Nitto NT01, NT05 or Toyo R888. I dont want to run a true drag slick, since I want to be able to drive the car back home.
What do you guys think? Opinions?
Received 1,762 Likes
I am doing a all forged motor now but stock CI with a A/A TI with a 3.4 pulley on it with a BTR stage II cam with a 38% fuel increase with the LT4 inj & pump & set of 2 15 meth on it also. I also have RPM wavetrac set up in the rear end with 3:42 gears with 300 mm harden half shaft with a set of E-FORCE axles. I have & also on the new set be putting in a NEW C.F. driveshaft with no rubber couplers on it also.
Also very nice looking car but if me you do at least need a set of forged drop in piston in your car with those new D/R tire set up. Also look at doing at least a set of MT DR in a 18 inch rim if you are even hope to half *** hook that car up even with 650 rwhp. A 19 r sure not a 20 inch tire will not do it at all. Just not enough side hall for it..
If your car is not a z06 you will be walking the line at air density to breaking a ring & piston in the car.. Plus at close to 650 rwhp with a good rear tire set up the spider gears in your rear end will be the first to go. Then the half shafts in the car then the axles this will also have a lot to do with if your car is a stick or A8 transmission.
I've been running this setup issues free for a year now.
I have the A6 and it's been amazing, very responsive and its tuned as well.
Many have Supercharged their C7s and are pushing similar HP numbers without doing any the internals. I believe I read somewhere that that limit is closer to 800 whp, before its really a need to do the forged pistons.
I don't have anything to say about your actual question though. Although I haven't seen anyone on here complain about the differential giving out.
<700 rwhp actually. There are people here that have blown the engine at that power level. You're there already. Any minute now. But it's your choice. $1200 + labor in pistons or the entire short block.
Anything over 650rwhp and you are on borrowed time. Anything over 600rwhp is risking it. You may know someone who has a car that makes 700rwhp and is holding up, but do they drive it often and how hard do they drive it? I know people on stock Z51 clutches with a turbo pushing 700+ rwhp, but they drive the car like its a Prius and never get on the throttle. The only time the car has seen WOT is on the dyno.
If you drive your car hard or race it, it will break. Remember this thread when it pops. You will wish you had done drop in pistons.
Now of course some want to be extra careful swap the pistons. Many are running this HP level and more, with no change to the internals.
My concern isn't the engine and internal. I posted this thread to get educated on the transmission and drive shaft. Sone have said that with very sticky tires (drag slicks) even on a stock Z06, which is at 560 whp or so, have bend and warped the Driveshaft.
I'm trying to avoid that and I was also told to not go full slicks..since with that much torque, some wheel spin is necessary to avoid drivetrain issues.
Read this thread that talks about C7 LT1 hp limits. Many are running at and over 700whp.
https://www.corvetteforum.com/forums...tor-limit.html
Read this thread. LT1 hp limits. Many run it issue free at and over 700rwhp
https://www.corvetteforum.com/forums...t1-handle.html
try that one.
That thread is from 2015, not much was known back then..
try that one.
try that one.
And yes that thread was started in 2015 and has had many comments recent as well.
I even had a talk with A&A and they didn't think it was a concern. Yes eventually i probably will replace the pistons just in case, but not really worried. Earlier this year when I did the install, I was more worried about blowing out seals dude to crank case pressure, but has been issue free and i did a catch can just in case and changed all the air lines to 5/8.
Former Vendor
I have yet to do an aftermarket unit or have the need to on any of our customer's C7/C7Z cars and many are doing high mph 1/2 mile runs as well as launching on a prepped track. you should be fine on your setup
- David @ Vengeance
- David @ Vengeance
BTW.. do you know what the limits on the DS are and what kind of WHP cars are you seeing that are still running thr stock DS?
Ttt
Again here I have seen guys in here at 700 plus rwhp out of the rear end on the spider gears. This car only has two of them very weak point in the rear end. There is a guy are two in here that has cut down the c6 spider set up & have been putting 4 spider gear into this rear end. THIS WILL WORK FROM ALL I HAVE HEARD & SEEN IN HERE. I did the other & got a wavetrac from RPM transmission in here that is a vendor..
A few guys in here have also broke the longer one in the two half shafts that are coming out of the side's that the axles hook up to in the rear.. But from what these guys have posts have been 750 plus at rwhp on the spider gear and half shaft break. THE REAR END THAT HOLDS THE SPIDER GEARS NO. Robert
I just got my car back from the shop brand new factory diff z51 car making around 700 wheel. Something in the diff gave out today. I’m really glad I wasn’t romping on it when it decided to let go. Cars going to be sitting a while now as I depleted the car fund.
