Cranks over a few seconds before starts when cold?
So the weather has gotten a bit colder here (mid 40s) and I'm noticing it takes a few more cranks before lighting off. Its a 2014 and I've only had it about a month. Is this normal, or something that should be looked at? Is there a high pressure fuel pump in the tank like the C6 and earlier, plus obviously the super high pressure for the direct injection?
Received 1,298 Likes
Normal, May take as long as 7 sec in sub zero weather.
Yeah, fuel pump in left gas tank + high pressure cam driven pump for direct injection.
See GM bulletin:
https://www.corvetteactioncenter.com...2018-1351.html
See GM bulletin:
Red86Cfour (11-11-2018)
Awesome, thanks for that link. I parked it friday night, and started it up today (sunday) so I figure the pressure bled out over that time. Its starts up normally when warm or later the same day.
#4 on the list of normal C7 things listed below. #1 caught me off guard right away, I thought I ran over something or had a suspension problem. #7 still makes me shake my head.
https://www.corvetteforum.com/forums...ette-does.html
