Rear Tie Rods (LG vs WeaponX vs Granatelli)
I'm looking for a set of rear tie rods. Can any owners of either of these comment on quality or any issues?
+1 for the Granatelli links with the AMT locking hardware. I haven't tried others but these get you the typical track alignment specs. They seem very well built, including the locking hardware.
Premium Supporting Vendor
Thanks!
__________________
Dane Syme
Build & Part Sales
LG Motorsports
972-429-1963
Dane Syme
Build & Part Sales
LG Motorsports
972-429-1963
St. Jude Donor '14
I've got the Granatelli's with the AMT blocks and they work great. Highly recommend them over the factory ones. If you want to maximize your camber for the track the stock ones don't allow enough adjustment.
Supporting Vendor
I can't speak to the others; however, the addition of ours reduced my 60' by over a TENTH on my C7 ZR1! I've cut a best of 1.44, so needless to say, they work like a charm This is the same design we've used on our CTSV3, ATSV1, and Cam6 ZL1 setups and our record setting CTSV3 is cutting mid 1.3s using them
The Toe links allow you to gain the toe you need. There is no way that a tie rod would help decrease the 60', unless the alignment was incorrect to start. The stock part doesnt flex, doesnt bind, and actually does it job well when with in the limits of the stock alignment.
To clarify, the purpose of these toe rods is to help you achieve the proper toe, WHEN YOU ADD CAMBER. The stock eccentric maxes out, and you are left juggling the alignment shims to get where you need to go. You can do it with out it, but the eccentric is maxed out, and you have nothing left.
__________________
"Keeping You on Track!"
http://www.gspeed.com
877-512-5180
Instagram_Facebook_YouTube
GSpeed C7Z Cooling Development
2014 NASA Texas TT1 Champion
2015 NASA Texas ST1 Champion
2018 NASA TTU & TT3 National Champions
2019 NASA ST2 National Champion
2019 NASA Texas TT2 Champion
2020 SCCA Majors COTA GT2 pole sitter
2020 SCCA Trans Am Road Atlanta SGT Winner
2022 NASA National Champion ST2
2023 NASA National Champion ST2
2023 NASA National Champion TT2
877-512-5180
St. Jude Donor '14
During the launch, the rear wheels tip inward on the forward side as well as inward on top. The removal of the rubber bushings with the rod end greatly reduces the forward side tip in as well.
jstewart (11-20-2018)
Dig
Thanks for the attempted lesson; however, to clarify lol you are incorrect. The additional alignment is a great benefit and the point for some, however; it is certainly not the only benefit. The rubber OEM bushings allow for more deflection on the launch.
The following 3 users liked this post by 123sugey:
I don't any of these but I have the Carlyle Racing rear toe arms, they seem good quality and aligned easy.
https://www.carlyleracing.com/produc...able-toe-arms/
Those look just like the Granatelli's. I have a set and from an alignment standpoint, getting camber where you want it, and caster too is easy. You flat run out of range with the OEM's.
The only complaint with the Grannies I might have is that the jam nut on the wheel side is impossible to tighten without a crow's foot, and even with a Crow's foot, you run the risk of scratching the barrel of the wheel. Lucky for me, my good friend BELVIN gave me a Crow's foot the right size. Thanks!
It would be a better design to move that adjustment to the center of the shaft so both sides could be tightened easily. Yea, then GM has to have the parking brake cable right there too.
The OM says the rear camber for track is-2.0. I went to the Granny's because I couldn't get -2.0 AND the optimum caster setting at the same time. Besides it takes a bunch of fiddlin' time to get even close with OEM links. With the Granny's (except for tightening) you just adjust your camber then fiddle with the two eccentrics to keep the camber at the desired setting and get caster. With the Granny's you can get 0 caster pretty easy.
Most dealers DO NOT have a tech that knows the what and how for rear caster. So they will tell you you have it and it might be an itty-bitty fib. Of course the dealers would NEVER tolerate that
Removing the shim washers is good for about +/- 0.4 camber. I run -1.0 camber for the street and -2.0 for the track. For the street, i make sure I have 0 toe (not quite as fussy about rear caster for the street). AT -1 rear I get perfect centered wear on the rear tires The front camber, I run -2.2 track, -1.1 street and a pinch or toe out front and a pinch of toe in rear. Toe for street front is set to 0. Again for me and my driving style these settings, along with proper tire pressure give me pretty good wear. When I go to a new track and see corner wear particularly on the outside, The first thing I look for is me turning in too early on some turns. Watching the PDR video definitely call out your driving!!!!!
Thanks all for the responses. Was going to try LG's based on the responses about adjustability of Granatelli, but shipping kills it ($120+ to Hawaii). With AMT's sale, seems like a no brainier.
Received 1,762 Likes
Supporting Vendor
Which island? Happy to deliver for LG after christmas at no charge if you have not bought yet. We have family on Oahu in Nuuanu and Manoa.
