What would be your ultimate C7 track car build?
Track Rat
I hate to create two threads but I wanted to get some input from the folks that hang out over here and might not check the Autocrossing & Road Racing section.
https://www.corvetteforum.com/forums...car-build.html
GS with coilovers, Kateck 427 with 600 N.A. WHP, and ZR1 level downforce. Also some R7’s.
GS Z07 with 575 na to the wheels
E85, MSD, Stage 3 cam, ARH - Akrapovic
7200 rpm redline
Z06 7 speed manual
3.90 rear end
18x11,18x12 with 305/660 & 315/685
3300 lbs via headers, AFM removal, Katech flywheel, lightweight battery.
ZR1 rear wing via Competition Carbon, stage 3 front aero
Car would be a blast to drive!
7200 rpm redline
Z06 7 speed manual
3.90 rear end
Stock GS with the Z07 package with manual transmission. That's it. Maybe 100HP upgrade would be great.
Very interesting to read that GS is the preferred choice over Z06 and ZR1
"posted in this thread by mistake"
The GS has a better weight bias. With no supercharger and plumbing it actually has a slight rear bias. The advantage of a Z06 is HP. A GS with a NA 427 solves many heat issues generated from a FI on the track, while keeping a car that has better balance. As I don’t believe the chassis can put much more than 550 down, a NA beast at 550 to 600 would Ultimate level of power with the best blend of weight bias. Take away timing being pulled at a hot CA track with FI and you have a car that handles amazing at the limit without pulling **** tons of power by lap two on a 100 degree day.
Jordan Priestley of JDP Motorsports has an awesome track built GS. Quote from his thread:
"We appreciate the interest everyone! We've been slammed in the shop and I haven't had a lot of time to dedicate to the forums. The car has evolved into a 655 WHP NA monster by way of a 440ci 13.5:1 LT1 and we've got A LOT of updates for the build thread. We took 2nd in the Optima Ultimate Street Car GTS National Championship and we tied for 2nd in GTS and 5th overall at the OUSCI following the SEMA show."
https://www.corvetteforum.com/forums...rsports-2.html
