Transmission problems
Old Nov 23, 2020 | 02:13 PM
Mike Raines's Avatar
Mike Raines
Default Range Technology
Originally Posted by pit-man
2019Z here with Range plugged in all the time and my battery stays charged up fine. I drive it once every 7 to 10 days
Pitt
what is the Model No. on the Range to address the transmission issues?
Old Nov 23, 2020 | 06:12 PM
KemahGT's Avatar
KemahGT
Keep in mind that the Range is not a cure for the torque converter clutch issues. Many think it may delay the onset of symptoms but it will not fix the problems. My clutch started the shudder problems again after 50,000 miles.
The converter was replaced under warranty several years ago. I deleted the DoD with a cam at about 34,000 miles. My next step will be a fluid flush with the newer synthetic Mobil1 fluid. If that doesn’t fix it I’ll be replacing the converter. Probably with a Circle D.
