Side skirt removal
Old Jan 4, 2019 | 02:08 PM
gulflyer's Avatar
gulflyer
Default Side skirt removal
I have a 2017 ZO6 with the basic carbon flash 3/4 side skirts which I am trying to remove and then replace with carbon fiber units. My question concerns removing the fasteners attaching the factory side skirts. Does anyone have any advice on how to remove them? They appear to have torx style heads but will not screw out. Are they actually rivets that need to be drilled out? Thanks in advance for any assistance.
Old Jan 4, 2019 | 04:02 PM
Jeff V.'s Avatar
Jeff V.
Factory skirts are riveted on.
Old Jan 4, 2019 | 08:53 PM
L82Brake's Avatar
L82Brake
The material is very soft and will drill out very easily with a drill bit (the size of the head or a bit larger). Just go slow since the material will come off quickly. Drilling didn't make any marks in my 3/4 removal.
Old Jan 5, 2019 | 08:27 AM
gulflyer's Avatar
gulflyer
Thanks for the reply. They did come out easily with a drill, used a 3/16" bit and went slowly.
Old May 28, 2019 | 09:27 AM
i3eezenotch's Avatar
i3eezenotch
Hey guys, I’m trying to do the same thing. Wondering if when you drill out the rivets, do the rivet tubes get loose in the car? I’m worried they will rattle around. Thanks!
Old May 28, 2019 | 03:47 PM
Obe1 GS's Avatar
Obe1 GS
Yes part of the rivet remains inside the body. I don't hear any rattling from them.
Old May 29, 2019 | 04:32 AM
OEFastZ06's Avatar
OEFastZ06
when you install the new side skirts on do you use rivets? Are they plastic? or can you use push pins or bolts?
Old May 30, 2019 | 12:46 AM
poughkeepsie's Avatar
poughkeepsie
I went with these. They work great
Amazon Amazon
Old May 27, 2021 | 01:42 PM
Drkhrse's Avatar
Drkhrse
Can they come out of the rockers and cause a flat tire?
Nevermind, I see that they are plastic.
Old Apr 20, 2022 | 02:45 PM
PatC79's Avatar
PatC79
I know I'm digging up an old thread, but are the holes from the short spoiler visible once it's removed or are they on the underside of the car?
To Side skirt removal
