The Hooker shorties will bolt right in place of oem manifolds and connect to the oem cats. You don't have to take the dry sump lines off to install them or to remove the factory manifolds. The installation is fairly straight forward and mine haven't caused any codes. The bolt holes for the passenger side weren't exactly right and had to be drilled out but other than that no issues. Mine are Cerakoted. I would recommend regardless of whose headers you choose to use ARP studs. You'll know immediately if anything is off with the headers and you won't risk stripping out the holes in the heads.
I just finished a set of ARH's on a 17GS last week. Be generous with firesleeve. I sleeve the dry sump hoses and heater hoses. There is a harness that runs near the heater hoses forward and into the underhood fuse box, it needs to be firesleeved. I wrap the left primary tube with metal heat shield where it is near the oil cooler, same for the tube near the starter. Tie up the )2 sensor wiring as far away from the headers as possible and use a piece of firesleeve over the connectors. Add heatsleeves over the spark plug wires. I can't say how close they are to the a/c because I removed the a/c and also the back half of the compressor, but look and firesleeve as needed.
Is there any set of long tube headers that don't require the matching x-pipe that just bolt on to factory setup? I just have a muffle delete now and am looking to upgrade to LTH's. Thanks.
I don't think it's physically possible for long tubes to connect to an x-pipe having stock the stock dimensions due to the stock X-pipe extending as far forward as it does.
