DRL running lights
Old Jan 7, 2019 | 08:59 PM
GSDUBBZo6's Avatar
GSDUBBZo6
Default DRL running lights
Does anyone know the fuse that controls the right side running lights on a 2016 ZO6? My whole right side is out but the headlamp and brake light are still working. Markers and running rear tail and front light are out. Any help would be appreciated.
Old Feb 15, 2020 | 01:04 PM
Tohnstad's Avatar
Tohnstad
1st Gear
Default Left side running lights not working
I have that issue on the left side...did you find the answer?
Old Feb 15, 2020 | 01:19 PM
TSLAVette's Avatar
TSLAVette
I had a loose ground from a SC install that caused this and intermittent remote start issues.
Old Feb 15, 2020 | 01:26 PM
charliebrown266's Avatar
charliebrown266
i would check the module that is bolts to bottom of headlight! there are 2 on each headlamp one is for the the HID the other for turn signals and lights
To DRL running lights
