C7 throttle body response, getting to know it
#221
Just ordered one for my 2019 Z06 - figured with the 30 day return policy - there's no real risk to trying this out.
If it does fix that hesitation / wants to stall off the line - then WIN... if not - it can go back for the refund.
Nothing ventured nothing gained!
I'll report back after I get the TB and install and test... probably another thread and I'll ink it here for future reference
I am one happy customer.
#222
It'll work. Installed one on m y 2019Z with barely 300 miles on the clock. I have been driving manuals for 25 years. I cant tell you the last time I stalled a manual. I stalled my new Z 3 times the first time I drove it. I felt like a dork. The Soler MTB totally transformed my car and made it drive/respond the way it is meant to.
your review tho makes me very excited. I haven’t stalled but I feel off the line like the thing is a pig. And I had some issues at a HPDE event trying to just feather throttle in the uphill turns not to accelerate but hold speed - so - I’m hoping this is the ticket!
i have 3k miles on mine so far and love just about everything about the car. Except throttle tip in
#223
It'll fix that too. As an ex HPDE Instructor, I'd like to think I know a little bit about fine throttle control. I didnt have it before Soler, I have it now. Made for driving near or at the "limit" much more repeatable.
The following 3 users liked this post by ssmith512:
#224
That's interesting, I have had my C7 manual (2017 w/ about 7,000 miles on it, so not a new clutch really) for about a couple months now and stalled for the first time today when stuck in a "move a few inches at a time" traffic jam where you never really get going fast enough to give it any/much gas. You are saying that this will make that an easier situation to drive in?
#225
@Mike@SolerEngr curious to hear your input on this comment by @TurboLX (a tuner) and the available mapping in the ECU/PCM tables... given the actual air flow mapping and other work you have done on the TB itself...
https://www.corvetteforum.com/forums...post1599440787
Clearly the folks that have bought / installed your TB "see" results...
Or is the context of this comment in a "tuned" environment - for other mods?
(let me clarify - I know the TB itself that comes in the mail today is "tune free" plug and play - but the default tables he references still come into play - so I'm curious about thoughts on this... I know little about tuning a GM... but I learned a ton tuning my Coyote... so - I'm struggling with how the modified TB works if the tuner says the tables don't understand... clearly the ECU interpolates values... I'm just trying to understand how this system works
Last edited by fishpick; 05-22-2019 at 10:45 AM. Reason: add comments for clarity of question
#226
I’ve had my Solar TB on For a few weeks now.... it definitely does something there’s no way you can’t notice it . The biggest difference I personally notice Between a stock TB and my new solar TB is a much tighter faster reacting clutch pedal. In my opinion it makes it much easier to stall the car. That being said I actually really like it so......,,
seems 10 People Could Drive the same car and end up with 10 different opinions on how the car acts and drives.
#227
Driving on the freeway yesterday I decided to look at the real time fuel economy Function as I was driving.
Cruising in sixth gear I was amazed to see 33 to 35 miles per gallon I’ve never seen that good of gas mileage unless going down hills and then of course it goes way up... with the oem TB same Circumstances I would see upper 20s to low 30s freeway cruising .
Does this solar TB actually increase fuel economy ???? Or is this just a false reading for some reason?
#228
I'm almost 100% sure it's a false reading caused by smaller throttle angle for the same airflow due to the different throttle body. Mine indicates upper 30s fairly often and I've never seen actual mileage better than 29
#229
Interesting .....that makes sense.
Although I would have figured the ECM relearn would’ve accounted for that ?
#230
Supporting Vendor
The fuel flow and fuel temp sensors are independent of TP sensor or any other sensor for that matter. I don't see how it could be false. We can always resort the old odometer and gas station receipt method to verify.
I know they can get the equations as complicated as they want but; distance/fuel volume...
The following 3 users liked this post by Mike@SolerEngr:
#231
You and Sellout, are the 4th and 5th customers to watch that and report an improvement, I did not expect that, but I'm going to have to start believing it.
#232
That was before my PTB and it was while cruising with app. 75 mph in average.
So your reading is not that unusual, but I am not saying the PTB did not improve your milage, I just don't know if it has an Impact here.
The only way a PTB can improve milage I can think of is by leaning the mixture, does it do that ?
Regards
Götz
#233
Supporting Vendor
I have another couple of possible reasons,
1) Our design reduces pumping loses through the TB during the intake stroke. That is the point of the converging-diverging nozzle we feature on our blade-body interface at low throttle, where the flow is sonic and benefits a lot from that geometry. It also increases the discharge coefficient of the valve (TB), meaning less pressure loses for the same mass flow rate.
2) It is getting hotter out there and the vapors from the canister are being purged and burned, and I don't think this amount of fuel is being metered. If this is true, the gains will be only temporary.
#234
Guys and Gals, that I have closely monitored, if you can monitor it on your car, please do. AFR compensation parameter = 1 (stoichiometric) when cruising. Fuel trims are doing what they are supposed to do. The oxygen sensor is very strict about this b/c of emissions concerns.
At low speed it needs exactely the same amount of air (mixture) to achieve a certain speed, regardless if the TB is ported or not.
But then if the conture is more flow efficient, the pumping losses are less.
So far the theory, I just struggle to see that the difference is big enough to achieve a noticeable better mileage.
By the way, I am not doubting that the People who saw an improvement didn't tell the truth, I just struggle to see the TB as the reason.
But I culd be wrong.
Regards
Götz
#235
Supporting Vendor
Gotz, I'm also carefully optimistic and really not fully convinced of my own explanation. Like you, I know what we have done is conducing to smaller pumping loses, but can't really gauge the full effect nor prove that is the reason. There must be a way, though.
I'm sure you are not doubting, your point is perfectly reasonable. Thx.
#236
Here's a link to my impressions that I'm going to keep updated as the install "matures" in data and experiences...
https://www.corvetteforum.com/forums...post1599463466
Mike@SolerEngr (05-26-2019)
#237
Immediate Difference
Mike at Soler,
Just installed mine on Thursday - drove about 150 + miles on Friday. After having 2 C7’s and 50,000 + miles I love my car even more now. There is an immediate positive difference in the driving experience. IMHO this is the best mod you can do for the money. If you love your C7 now, you will be shocked with how much better you like it after this mod. This is a high quality product.
#238
Mike at Soler,
#239
Ordering mi e next week. My 2015 Z51 M7 has quite a few mods and a tune. Hoping this TB will alleviate some of the lag when I pull from a stop. Feels like the pedal has to be pushed way too far to get a good solid response.
#240
100% should! Was out against today and that “from a stop” lag is friggin gone! It’s amazing. Car feels more nimble overall. Who would have thought!
