Lowering coolant temps - currently 220
What does the higher wattage fan do? will you get more CFM? or run at a higher RPM?
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
FWIW, my '14 Z51 never went over 215, and that was in 112 degree ambient heat (Needles, CA in early September!). Even with A/C on, around town in 90 degree temps, it always hung around 195 - 200 tops. Most of the time, it hung around 189.
I notice my '19 GS seems to "wander" around 192 - 202, even at idle....weird
Jim, not sure if you have to worry about freezing temps where you are but my formula is 20% dexcool, 80% distilled water, 1 bottle of water wetter. My car (before I took it apart) was running about 165* at cruising and would peak at about 190-200 max sitting in traffic and would immediately cool down again upon starting to move. I also have an LMR 160 stat and housing in mine.
Also I’m no scientist, but with ambient temps at -5, isn’t it possible that an aluminium block could be even colder than that?
Were seeing temps of about -5c here in the U.K. right now so I’m guessing that I still need a fairly high % of dexcool - but I don’t know white how much as I can’t seem to find a chart anywhere.
I'm tempted to try 65/35 and a bottle of water wetter. I can't see that freezing solid to the point of expansion until well into the negatives? Even if it goes slushy, I wont be driving the car until the weather gets much better..
I pulled this up with a google search. -5°C is 23°F. I'd mix it for temperatures a little lower than what you're expecting just in case it gets a bit colder.
The block won't get any colder than the ambient temp, but it will cool down to ambient temp a bit faster than an iron block would.
You won't see a difference. I went from the 60/40 stock to close to 80/20 and I can't tell a difference on track
I asked because I plan on turning up the stock Fan. Will changing to a 600 watt Fan alone pull more CFM, or does it need adjusted in the tune?
The new fan will definitely pull more CFM. I was tuned with the stock fan and would have times when it was really hot outside and when I cut the car off the fan would keep running because of the temp. My tune could not adjust it to make it quit. When I switched to the new fan everything works fine.
Dazed Confused & Verklemp
I purchased a Mishimoto 160 deg T-stat after having several others from Linginfelder and Summit fail after a few weeks The Mishimoto T-stat looks exactly like the factory T-stat, as it has a compressed seal between two pieces of metal. After I again had temp issues with my 15' Z-51, I pulled the Mishimoto T-stat and the seal had disappeared. Found it when I reached into the T-stat housing with my finger. So..either the one I bought was defective or the seal wasn't secured the same as the stock T-stat seal, even though it looked identical. So.. I don't see a simple solution if you encounter below freezing temps. ( see below for a possible option)
I have a couple Pontiac G8's (Holden Commodores). Some people that have them reduced the engine temps by drilling some holes in the T-stat to allow leakage which reduced the effective temp of the the engine coolant in normal driving conditions. However, a t-stat won't lower your engine coolant temp if you load the engine for long periods of time, like if your tracking your car. I believe drilling a couple 1/8" holes is what most did.
Interesting - I now have 2 C7's. My 15' runs about 15 - 20 degrees hotter than the 16'.
Good luck!
Good luck!
why not just do the upgrades that the Chevy engineers used to improve cooling in later model years.
The auxiliary fan was added in 2017 MY and is a relatively easy install assuming you have the manual tranny.
And look at the 600 watt fan which I think was added to 2015 and up Z51.
Both are now OEM parts, readily available from GM performance parts and proven to work.. Have your tuner adjust the fan speeds and that may be all you need.
Moderator emeritus
2015 C7 of the Year Finalist
The fan is controlled by the ECM. The ECM is reading the temperature.
It will simply ask for less of the fan than the stock fan. No tune is required for the 2015 Z06 fan when installed in the 2014.
I have the Z06 fan for another reason. Some of the 14 fans were failing to come on for certain conditions and causing overheating. It was fixed by getting the Z06 fan. It took less than an hour to do.
Thread with fan replacement instructions.
https://www.corvetteforum.com/forums...-to-260-a.html
Elmer
Elmer
Elmer
Elmer
