To all the vendors here!!!!!!!!!!!
Old Jan 29, 2019 | 03:33 PM
Ghostnotes's Avatar
Ghostnotes
Default To all the vendors here!!!!!!!!!!!
When is somebody going to come out with a good set of rocker arms for the C7????????
All these high end parts...high speed lifters, 3/8 rods, high lift spring kit titanium keepers/locks/valves and what sits on top of them....stock rockers.
Old Jan 29, 2019 | 03:46 PM
subieworx's Avatar
subieworx
Do you see them breaking?
Old Jan 29, 2019 | 04:13 PM
Mike@DiabloSport's Avatar
Mike@DiabloSport
Supporting Vendor
Is the LT rocker much different than the LS rockers that have performed amazingly well at high power levels?
Old Jan 29, 2019 | 05:22 PM
2014stingrayjoe's Avatar
2014stingrayjoe
both Jesel and T&D have them for the LT engines
Old Jan 29, 2019 | 06:23 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
you have links to these?
Old Jan 29, 2019 | 06:49 PM
Ghostnotes's Avatar
Ghostnotes
Yes much different.
+1
That is the only thing holding me back.
I might need to be more specific though..... a good set of shaft mounted like the T&D heavy duties.
Just checked T&D and they have nothing and left a message with Jesel. The "LT" that T&D refer to are the Vortech/LT1 heads.
Just got a reply back from Jezel.
I'm guessing shaft mounts are out for obvious reasons. I paid $1400 for my LS Comp cams/T&D shaft mount rockers. Plus they had the lubricating system. Going to try to contact T&D as well just to see.
This is really high for pedestal...
DavidI have attached a link below. The rocker with hardware is $245.00 each.
https://www.enginelabs.com/engine-tech/cam-valvetrain/pri-2017-jesel-puts-the-lt1-and-lt4-on-a-pedestal/
Apparently he was absolutely correct.
Here is T&D
The part number for this set is 15014, price is $1430.00. time frame right now is right at 10 weeks from time of order.
I was told last year they had no plans.....obviously that's changed. Going to look for pics.
Last edited by Steve Garrett; Jan 30, 2019 at 08:14 PM. Reason: Merged Posts-please use the Multi-Quote button in the lower right hand corner (the middle icon) to make your responses to multiple people look like this!
Old Jan 30, 2019 | 09:39 PM
2014stingrayjoe
that is in fact correct part number for the t and d. best bang for buck. jesel is nice but over 3k and molson is about 2500. now you know!!!!
Old Jan 30, 2019 | 09:56 PM
Ghostnotes's Avatar
Ghostnotes
I had the TD rockers on my G8 they were built like a tank and i took it to 8500 all the time. The rockers are my missing link. Everything else can handle those speeds in my C7 but for now i wont go past 7k
Old Feb 4, 2019 | 04:55 PM
Cordes Performance Racing's Avatar
Supporting Vendor
the oem rockers are great just like in the lsx stuff. only reason to change is if going solid roller.
On my personal shop/race car i run oem rockers with the trunions upgraded and rev to 7600 and make 1500.
Old Feb 4, 2019 | 06:36 PM
Ghostnotes's Avatar
Ghostnotes
I dont trust them for high lift/high speed duty. Seen too many times where stock rockers and lifters fail.
Old Feb 4, 2019 | 07:58 PM
Supporting Vendor
correct i wouldn't run an oem rocker past 635 lift, who said anything about lifters though? we run johnson's here.
__________________
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
Old Feb 4, 2019 | 08:13 PM
Ghostnotes's Avatar
Ghostnotes
I said high lift,not lifters.
As far as lifters,I'm running tbe same.
To To all the vendors here!!!!!!!!!!!
