ABS delete?
Feb 22, 2019 | 12:37 PM
2020 Corvette of the Year Finalist (track prepared)
C7 of Year Winner (track prepared) 2019
ABS delete?
Has anyone been able to remove/disable ABS on a C7? Is it as simple as removing a fuse? Does the car go into limp mode without it?
Feb 22, 2019 | 02:49 PM
So there are two fuses that I see, "ABS valves" & "ABS Pump"
I guess ill just do this trial and error. See if I can get the car to the track on a member day so i can safely test this.
Feb 22, 2019 | 04:07 PM
C3 of Year Winner (track prepared) 2019
I've heard/been told that if you pull the fuses it will screw up the front/rear (and maybe side to side) proportioning and isn't that easy on a C7.
Feb 22, 2019 | 04:10 PM
Quote:
Originally Posted by
fleming23
that's what im concerned about, i haven't heard of anyone actually trying it yet tho.
I'm just seeing If I can just buy myself time before I do a full motec swap on the car.
Feb 23, 2019 | 11:27 AM
Why would you want to? Even with Motec, why defeat ABS?
Feb 23, 2019 | 11:33 AM
davepl
It's really just because I've been experiencing ice mode frequently and if there was an easy way to disable ABS so i could at least make the brake predictable than I would deem that safer.
Jul 31, 2023 | 11:27 AM
Have you found a way to prevent ice mode?
Jun 17, 2025 | 02:20 PM
2nd Gear
Did it work
lobsterroboto
yo so how did pulling those fuses go? Were you able to drift the car with no problem?
Jun 17, 2025 | 03:33 PM
2nd Gear
lobsterroboto
which fuse did you pull and did it slide well on the track?
