Help with DA
Old Feb 24, 2019 | 08:07 PM
Yourconfused's Avatar
Yourconfused
Default Help with DA
I need help with calculating DA or a link (or android app) to what it is based on time, date location etc. I know time, date, elevation, dew-point and temp but I have no clue how to find what DA is, as any google search wants to know something like a altimeter setting. I am tired of wasting my time reading links in which lead to irrelevant or just similarly lacking info which is all about the same stuff that I have no access to the information of. What is the air pressure of a barn swallow 19 days ago in alaska at 3am? **** if I know! lol Pretend I am Homer Simpson please.
Thanks in advance!
Old Feb 25, 2019 | 04:06 PM
Bubbletop409's Avatar
Bubbletop409
Are you just curious or are you planning on using the DA reading as a performance parameter? Reason why I ask, there are several hand held DA computers available to racers that are very accurate, and many offer real time information through a separate driver carried pager. Once you have acquired sufficient information, they are capable of making e.t. predictions based upon changing weather conditions.
Old Feb 25, 2019 | 09:12 PM
Yourconfused
I am curious as i have weather data at work and want to know how the car is performing based upon the data when I walk out the door and hop in the car. If I can take some on the performance recorder times from the car, say like 40-90 timer, I can start to see what mods are working based upon accurate conditions instead of what feels better on the butt dyno. I saw someone mention that they had an app that will tell the DA based on GPS, time of day etc, to compare info accurately. I can't find that thread though. My brain hates me. lol
Love the 62! I prefer the 4 door version but that thing looks sweet.
Old Mar 1, 2019 | 03:25 AM
Bubbletop409
Without having a vehicle capable of making back to back run's within a hundredth or so consistently accurate DA information would not be pertinent. An example, my last drag car was a 94 Chevy Lumina, tube chassis, strut and 4 link, 540 powered, capable of 8:45 at 165 flat out. A DA change of 160' would change my quarter mile e.t. by .010 of a second, your butt dyno is not capable of measuring the difference a change of 1000' would make. A change of 2500' would only change the e.t. by .,150 , that 15 hundredths of a second, so you can see slight changes in DA are for all intentional purposes are going to be indistinguishable as far as a felt difference.
You can see the weather station pick up and sender above the left side of the door on the trailer.
Old Mar 1, 2019 | 08:13 AM
Yourconfused
Yeah, butt dyno doesn't mean much and the reason I was interested in more specific data. I figured that a spreadsheet can be configured to output useable data once populated with specifics. Isn't there an app for everything these days? lol
Off topic I use to build those cars and others, tube chassis, cage, suspension, motors, exhaust and rear ends. I was banned from doing the inside tin work though. lol
Old Mar 4, 2019 | 01:48 AM
Poppacapp's Avatar
Poppacapp
I use airdensityonline.com to look up DA for tracks I go to. It also has a forecast option where you can see the estimated DA at different hours.
Old Mar 4, 2019 | 07:30 PM
Yourconfused
Thankyou for a good link to help me out. I swear google didn't help me on this at all. lol I input 30.38hg for 1028mb pressure reading and got this. Does this look wrong to you? Neg DA?
[img]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAA2YAA AFkCAYAAABLgijcAAAgAElEQVR4nOy972scV57vf/+F86xAD4SgnhhhhJA9imiC2phobiJP0CxmW+7vTZ NBfVmiNTJEcZRYi8xNJyBIZzD4O016JtfyZjo2ih XoaO04vm4m1k1rl1m7r1gtPcFEmmnJGF3MdJZN/KCfve+Dquo+59SpqlP9Qy3Znxd8MFZXnd+/3nV+/RcQBEEQBEEQBEEQXeW/dDsABEEQBEEQBEEQzzskzAiCIAiCIAiCILoMCTOC IAiCIAiCIIguQ8KMIAiCIAiCIAiiy5AwIwiCIAiC IAiC6DIkzAiCIAiCIAiCILoMCTOCIAiCIAiCIIgu Q8KMIAiCIAiCIAiiy5AwIwiCIAiCIAiC6DIkzAiC IAiCIAiCILoMCTOCIAiCIAiCIIgu06Qw+xJvDQ1h SLaRFzEWfwMffvovqNS83659ca7+TixTDu17rfIH/G42jrEXR2x3RvDiWByzv/uDr79+/Nvl07Zbp3H535pz4yD5QxAEQRAEQRDE4aF1YRY5g Zdffhkvn4gIIi3y//0WXrqjuPjzxrPnvkAoLfVvGcRGODEYeREvcv8fiW U8/fV19pAIs8b7b+HL9gePIAiCIAiCIIgu0Lowe4uTB 7UK/rAYw4g9i/X3y39VvFtGJsYJq9GLuKvt71+x/Pf2LNlIDJf++JPjMSpfvIUTtr9vfRl+2oyEGUEQB EEQBEEQ3aK9wgwAanfwD6P2b69fwV/kV2tf4JwtoEZGhjA0FIP2asa/XsMbtr8/XyxKPxax+HPrt9GL+lLPgYQZQRAEQRAEQRDdov3C DP+Gy6d9ZsOKi/j50BCGRv8ef/+69dy5LzRnuJx3lXvTOH9VgjAAEmZArdbkBj2CIA iCIAiCIFqiA8Kshi/ODXmKh79ced367Y1r+PLiqMfsl5e3b9WXQLq85YX Z6cvcPrMaKrc+xK9+8WJ9ieWLv/gV3vviT8LeNk/B9NO/48Z8HCcijQNOfvGrD3GLO2VE/W4jjU5zDnr6U6vg1oe/wi+cA01GXsQvfvUevvhTzeWebI20qOFPX7zHxTWC E7+cxuW1x2JK8WH4Ixc/d6ISBEEQBEEQBLEPdECYAV++5SXMavjyLUt4/PJSCX+99ka4GS5fYVbG//zvL1sHkfz3/wlnPu2vt96x957JB4WcwMW7QeLqMa69MVL3M/KiI3iGMDSexh993w0jzP6KW++cUPtz4iKsYH6N//Hyy9xJlBGceNmK7//4OiCuIzFkOBHYCMMoTpwYwdBQBBESZgRBEARBEAT RNfZZmDX2gZ37ogaULuGXQ0MYGjoHrdWMvsJMxV9 wxV4uOfLGp9ZR+j/dwjv2HriRt76sz5opBdO/XcZp27/kp9asU624iPGhIQwN/RzORF/LwuwvV/C6PZv3xqcVWMF8B6OKw0y8lzI24jp0+hJKNQC1Ih bH7X13/3BHEdchjL5xFf/+EwDUUKmIM2sEQRAEQRAEQewP+yvM6gLEOfDDcac hcvy9DSvMVOKIW2rJLXlUCqa6f2rB5YShZWGm8qd +SIrX+7IwU/tXz4tfXkLJ5cYvcakEgiAIgiAIgiC6zP4Ks1vvWE v0Rt7BLQD80fmvX/mLhrchhdkP3yD77rt499138dHNhvv18AUIsyDB1S 5h9sM3Wbz77rt4992P0Ahm0PteotdDmHHP0yXXBE EQBEEQBHGw2FdhVrr0S9eesrv2ASD8skJvb8POmL n5aetbfPTfWhFmP+H//vnP+POf/4z/+5PfcyEP/xBDia1vP8J/CyPMuGWXJMwIgiAIgiAI4nCxj8KssQeKP4WxfgDI zxcRuJrRV5jV8NcdSzD9eeevksirofIvn2L+b7lD NZoWZm7aJsxqFfzLp/P42xcbB46QMCMIgiAIgiCIZ599FGa38M7IkCA4RH sdV/4S5G0zx+U/xpfvjNlLKMfwd5f/gKuae8z2VZg9/hLvjFmCbGTs73D5D1fD7TEjYUYQBEEQBEEQh5YOC DPudEBePNRPYPSyEbxzK8jbsMKshtIlW4SMxHDpj z/ZzrQizL7H//7iC3zxxRf439/7PRdCmNVKuGSHfSR2CVYwQ+4xI2FGEARBEARBEIe WDggzTiBxJwHWlyy6jsYv4dIv3UsclRQX8XOF+HD 5Ww9TY5aOd/ugHf5RPxRFOJ2SDv8gCIIgCIIgiOeF9guz2pd4yx ZD/IEeziEfQ7FM/fLnumuOeAi6aNrDbfm3nzcuGHPdQyb4d0COy2/8LYlGMEMKs6aOyydhRhAEQRAEQRAHgfYKs5+2cOO tE/agfxT/cMeRTo1ZsRHFesW6UKgfo+9FDXf+wRZ4Qyfw9598 i3//85/x5z//K268NW7/fRzpP9qPc7NIo+e+wGMAP/3xEmIjmsKsnEFMEnaNC6Ybz5UzMfvdn+ODtRqAGi p/+EC5tFDlz1+uvF5Ps3NfPAbwE/54KVY/qIR/3+2XQzMXTJMwIwiCIAiCIIiDQOvCLHICL7/8Ml4+ERH2jJ1460vUJ3/+eg1v2H9X3ldWX8qnceHx4y/x1gnvvWqCv3iMa280TjgciUQwMjSON974pebyPvH 9yIkTiDhuvX4FD53H7l7EKJ8eJyIYOnECJ3SXMj6 +hjfqB6OMIBIZwdD4G3jjlwrx+8e0LQwb5vz811v v1P0ciryIFx03R2LIcAKMhBlBEARBEARBHCxaF2a 8jbyIsfgb+PDGv+Mn/vG7jnAZxcW7Cue4mSmdi6ZrlT/gd7NxjNWPlR/Bi2NxzP7uD6jIl6E9XsPlv7NOZRx58W8x/8WfUKsLwcZ+N0+xUvsTvpjn/Bp5Eb+Yvoy1x7wnD7F8zvHjF/jVezfw7z+FO5Xx8dpl/N3YiBWXv53HF3+q4dY7tp/nvuCWbdbwpy/4I/UjmP+a/+09/OoXzrUAEZz45TQui4ElYUYQBEEQBEEQB4wmhRlBE ARBEARBEATRLkiYEQRBEARBEARBdBkSZgRBEARBE ARBEF2GhBlBEARBEARBEESXIWFGEARBEARBEATRZ UiYEQRBEARBEARBdBkSZgRBEARBEARBEF2GhBlBE ARBEARBEESXIWFGEARBEARBEATRZUiYEQRBEARBE ARBdBkSZgRBEARBEARBEF2GhBlBEARBEARBEESXI WFGEARBEARBEATRZUiYEQRBEARBEARBdBkSZgRBE ARBEARBEF2GhBlBEARBEARBEESXIWFGEARBEARBE ATRZUiYEQRBEARBEARBdBkSZgRBEARBEARBEF2Gh BlBEARBEARBEESXIWFGEARBEARBEATRZUiYEQRBE ARBEARBdBkSZgRBEARBEARBEF2GhBlBEARBEARBE ESXIWFGEARBEARBEATRZUiYEQRBEARBEARBdBkSZ gRBEARBEARBEF2GhBlBEARBEM8dP/74I77++mtcvXoV2WyWjIyMrKP2+9//Hv/rf/0v/Pjjj57tEgkzgiAIgiCeK3788Uf84z/+I9bX1/H48WP88MMPZGRkZB21x48f45//+Z9x9epV/Od//qeybSJhRhAEQRDEc8XXX3+N9fX1rg/UyMjInj9bX1/H119/rWybSJgRBEEQBPFccfXqVZopIyMj64o9fvwYv//975VtEwkzgiAIgiCeK7LZbNcHZ2RkZM+vZbNZZdv UnDDbTCPCGJjSksi30lp2iHySgUXS2Az1Vg27t+Z w0uwBYwyRdLi3u0sVhV+fxdufbqDW7aA8w2xeext nP7yDvfa6inRk/8tbtfBrnH37U2x0pcDkkWQMyX1uPDqTf2Gw4u2f1 5u49vZZfHinM6HMJxnYfid8q2xew9tnP0SHkmR/ySdb7De7U3fazX63Pyphtr29TUZGRtYx67gwe+1q BZWKbE/wVN+hfRuANiXMqtcRNxjMeAbFcgXf71Y7FbyW2Ux HpPjt4MqEAWPiCnb2NyCIsAgOpIZteQDk5t6cCWb O4V4b3eyWMNu5MgHDmMAVp8Dsa152Z3Dpyr8OlBF/3MLMLZTuYc5kMOcapcxd31sIwWEUZvfmYDITc+2t eN2BhBkARfujQwtpR8KMjIxsv63jwqz1juCAC7O2 xbPztHOg1mJAnith1hm6I8zcwXj2hZk7GAdRmLl5 7oXZswQJs+bpkDC7PX8ck9nuD+I6b7cxf3wS2a6H g7csJvlVWMfncbupZ4ItO9n8u035xRgYO475291O Y7JuWXeFWT4JxiJY/GoFM6O9MBiD0TuEqdxDa2ldPiktgeQGgLWHWJk5C bOHgbEemCfncGu3xjnNwBKXkZsaQI9mhyQKM2vgy 5JLWEufwYDjz6sprO05UYx4L9HcW0P6zBB6DSd8M 1h5yK2/sAe0F5ZSeKXXqPtrhft3uDXXiNvAmTTW9p7iQeYM hnoNMGagd+gMssJ6jhoerszUl1QavUM4k3lgz0xa nTIfVmuQ58Qx7+9Oeo1bxmUPEhe/wsrMqBU/oxdDUzk81Fhekk9Ky1q5gePeWhpnhqxywHpMnJxZ 0XLT4emDTP19o3cUMyuXkZDzns8XoxdDZzJ48BSN tODDpjmKqT1cwcxJEz1MdpOLMxfPZsqmFW7redYz gDPpJVxwCbM9rKXFMpKpByS4PNuJiKUpO19tN9Lc A1aZt8q5Mi+3MhhjDLEcP3Ns+W3EryPMfHLtId8u hM1PQLes1nZv4b1Tdtoq6moj/9RlpHbnHPpYPxbW+cDnkTQYBlP3NWLK5xtDj3kSc 7d2ueXFnDBTLBG30oMXb171Xb0k0iW6ag+F9BqdW cHlhFwf/MpaOGq7tzDn1B9V2fZoK8U+QBEGu39xnLHycRFfr cxgtB7uKeTEwoBb752y64eVFzMrD/WXervafUW/FBQGuw2u/z46g5XLiVDiotW6s5mOgPXNolB/uIpcjIHFclwdXsdCP0O/UPDVOG1evVzV+zU5+fz7AL79CW7Tmm/THTyF2e15HGfsuRBmt+ePg7GDJMxuY/44A5vMiv8XxJPOM3q2b8IsO0mCjAzb2wdCmBkwel/Cu6slVMpFZOImGBtDZgvA0yeoVO7h4jDD8MV7qFQ eoVoDgD3kkyaYOYH03TIq5btYiBpggwtYrzlOMzC jBwOnU7h64wa+3QoOslKYGT0YSFjLFEur5xE1GPr O3UENQK36CJV7FzFcX7JpL9GsFTBrMhjHprFcqqB Svov0hAlmJpF3OqLNNCLMgNE7gpnMDdy4vYGqEwb Wg5feXUWpwvlpmjgykcJqqYJKaRnJQQY2mIIz7Nv LxWAwE/GlEiqVMoqZOExmIH69CuApnlQquHdxGGz4Iu5VKn hUrUElzLay4zCYiYn0XZQrFZSWp3HMMBBNO/vQrMGdYfTaYXT8YhjLBCfy0ycVO82GcfFeBZVHVS stC7MwmYFj08soVSoo301jwmQwk3m9vT17K0j0MR jR8/U0mj5mcANXALUNpKNGI19KS4ibDEYshz3UUH1UQe Xqa2DsNVytVFB5ojHQ3MshZjCY8SUr3MWM5SYnQp TCLFTZ3MSlqAFmxpEplhvlSRhk17CRjsIwjmF6uY RKpYSluAlmxJDjByk+5Rmo4nrc8mepVGnUR2McWT uM/MBInZdbyIxJA7itDMbqZVGT6k1Mm63kJ6BXVu8jN chgRBdwt1xBpbSK81EDzJxFgW9LImlsepWR2h2c6 xMHqJZYG0SwLqthfWEQzIhi4W4ZlUoJq+ejMIR3O UFVq+JRpYKrrzGw166iUqnAKqa86PKq7zrCrIqb0 yaYEcX5VascLU8fswbKjYQPKGshqG1gMcL8y7ayr dxDLqYqq3Fcb1Q8tzAzDPS+9C5WS426ysYyqJeGl CovTMwWNKRZbR0LqrLEtdM6YajenIbJDETP233A8 jSOGSH2Zrej7qwvoF/4EGp9aBDS97tLiLI+zBZcIXDh6tfsODXqql4foBR mnm1ak206BwmzAyjMVALm9jyO83/TeUbTSJiR7bd15fCPeueQT4KxPpy7w3V6O1mMC4J OsWTr3hxM+T178JfM2/IhKXZ2OiiFmeRGYbZPXB6kEKBbmTH3IMUevPU5vd hmGhE5Dk4YJpYEMVKY7QNjMfCTENVcDIyNI7sDAI/x2etHcfTNm9yX3Q0sDouiy720SRJmdhgHF9aFL8R bmTHOL2tw1xjMA8AOsuMhvka6lr9Zg3m+k7aCcw5 9mh3/ZjriTvO9JUxwebNzZQKGI/oFP7iwhFz28viz13H06Ju4ySXYxuKw4IZSmIUpm4 VZ9LFBLKzzX/bXcKGfqxc7VzBhSOLYzk9hdtS3PCsG7tUCfn32LD 75V+u/4sAIyqWMO9lxobzuZMfFAZ0G1jut5qdGWVV9QNq8 hrfPfoB/svexuJY4K8pIYbYPrH8B6/z/uQG5N0V88OJRvPobLgFrK0gI+aCzlNH9jLu+awiz nSzGmYGYmPBYmuCfCSpr+tTySRhBZVvVVj7+DK8f PYo3xYqHYVf/IgmzvnMQu5txxQyMUBhw7e2z+OCfNDY1FT/Ai0dfhZiViZBhsMqn3BbuLU1ot0vtqTsFzPY1Zr5 r+SSM/ggifY0+tpqLgRlJ5HVXSgizbc7HRMc/vT5AKcyC+uh2L2XMTopjmvqsjCNiGr8Jws0RBllL 1DnPHJ+/XRd67mVs1kzP8fmsNeOj8LNuUriOz9/mfrfcmZxv+FMPmxwfzv/G0jruHaXAsZYN1v3MToIdn8e88z4nbEQ33UIkO+k RPz/TETWawkcInxMHSZgFxaE+Q1fPr3lpBk80udyEjj/ZM2VdOfyj/tFK6jjtP0pr4d3CzBqET+Om4KG1rMJ5rpk9Eeqlj KIbrsGOa2BXw0qCgY1nXQdqCB2Gx94cVbhdg2HrQ UXaCW+5wh8ozDYWMawSQoJY1lwO5Yccd3sgOp51p RhmNQd7+SQDi17Cd+JfhbKkfKaaQ8w1mGtt/5CcX0phFqJsqsu7VC/ySTAWxSUxctbyo2QeeuXZmTE7ibmlIsqKr8s6wsx JU2tQZ4XBSOZDnfzZnvzUKav2jNmxBNKrJXtmSRG WoIHe+gL668sZxbYoPHK491GYKcuRzjN8WdNHq2z r7mOU22LlUkZpz52Ul9aM2TEk0qso2bP5LRE6DFY eRd0ZoN0utafu1JBPGvV6W5jtQ99sof4v7L/JYss3THLZ4PsVzT5AvZQxoI/uxB4zxYyZNbjmBun2M3WxUhdfjdmnxgBf/pvz/8YAvyG07L1T/ODdFleN8MjPOO5IIkIhVkT/FTNmusJMITBkt93hbsbkZYvNPuMVd5Ww9IuDxzLK IMFFM2Zkth2ApYzhhdm9OVM5E8cYgzF903a6W8JM/Z7r3XYLs6dlLM+dqu9TUa2pDxRmnmKPz5MOCDPPs qJ7wMV/4Fpc5T8f7se4MqEuM4wfCIXuxJ+ivDyHU86+iLq1 WZi5DnEQ0+bxlQnPuFkDMM3yXHuIFa4c9Qycwnvc fictYeYIvFgO1WoOMW4mWxd1GoXNT82yureGzBS3 V2l0CkvcXiUtYWYLvP6FdfcysABqu99w/jese8LMXf75Z4LLmj7/+t5gYNn2aiuflpcxd8rZz9WwVoQZsIe1zBS3x3YU U0sPNE8RrmH3mwymnP1ydQsvzNxFP6Qwa0NbWM3F 7FngdSz0WzOW1szZAtbtFRluIRU+TPFr/6HdBxxcYSYJE9sEUSMLte1ttTARBugee6NUz8iDf o1nlLNTkkBoXpiplhK6RVgrSwV1DsvQPlBDGT4p/XXikJ2Ea+mnI8pJmJFp2KEUZpvpCNjQBRRcx/A31pB3fcZM8SXx5rTRIWFmDYStPQWNqwhkt/RmzKRDDAB7L0HnZ8zEAyMA4CamjRAzZq5ZSsVX4t gn2FKUm/pMSchOvHo9DsPejyPOBLdZmAkb8QH1jFkMn2wp6s SjKmq65Znj6ZPGHhvnyHE9YWanC4sh89s4DGnplg 7tyc+wZbWG6vfOXqXGkdx6wsyebelfwG9TgyGWql qCzoxnUPzemaGR27z9FmbOsmW/Z/zKmj5aZVs5K3sdccPeh9WoeGLf0ZQwa1Crfl/fqzuhcz77/RQGmYl4pojvnfZECruuMHMJnrDCrB1t4WYaERbFp ZtpRJwli7U8ksYgUn/IIRbi44OyzvH9imYfcGCFmdegmhcxqkG9SuQoBJU s+Bwh1FhaqJp14p7xdKdhXsvzmhdmojjx3KumEjJ hTWfPX9AzHuHgRZdOHNRCU2PGjoQZmW2HRpgNL27 Un3DWwi9Kt0zubW97ihId2iPMwuwxa5cwUw24pH0 hjjvDi2ikZPN7zFoXZsNoZGnre8x09lVsZcbA+hJ YEQ4oqGF3mzsBL58EYwmsaI4uVQMteT9Iq8JMa4/ZVgZjrA8JMXKo7W7DOhROozz/n1/jvx49iQ+FjVFifquFGZ+XjsfWYQGGYUh7vPRoT34 Gl9Uf82dx9OgbWBEOkRTrtFqYKcqIc0iFvP/KD1U7KeetlzBLrKhPbqw7Ldd31Sl68v4xjT1mgWU tBDplW9VWqvoOqXyEFmY/5nH26FG8seI+UVSnvqra6draBWH2NFiY7c8eM622 0C4vg4OD3IdGa8lqJBq1Z8706OgeMy1hpt+m84QT Zl6zkPsjzLz89xVmQrhtP9s2Y6YSZl7hbP1wEZ2Z N79nvETX7fnjkjDzjwMJM7JWrbsXTGsJM3uzfuR9 fFv5Htb9zc4pdfapjJUyikvTOGYcwZuFHy1XuijM PE9l7InjunAqY7uEmX0SnhnHR4USysXPkTp9RDpJ zdlkHsH73zoXYeufyviz1Lr2YDcQe29B5P1vUfl+ F1V4n8jVE7+udyqjdBJZubjkPonMecbJl0oJq6kJ mMYr+NgZRxdm0cf6kMiVUd4O9tkSrSbiHxVQKhfx eeo0jkgnqLUszORTGUurSLlOZXRO03NOyqugtJrC hGnglY+3oFWenVPl+PSRTgh0lUVFXlrUcOdcH8TD fb7Dx39zFH/zscZit7bkp0ZZdU7VnEhbJ+kpTvdzDaY9y4hdD6V DFXyxP4YY0fP4vFhGqZDBzEiPlLfueBRm+8D6Esi Vy7CC4H7GXd/tPHFOHSwXseQ6cVE6ldH3Ga+yBnz99lEcfftrjQT QKNuqttK+lsGMf4RCqYzi5ymcPiKVj9AzZs5Jj1y/Ipxu648lIgxEz3+OYrmEQmYGIz1hlzLKpzI6fRtz 9wFetKsthHPwlDiDZ5Ur7iOjBtapjCYmUuJpwzqn MvJ9QFPCTFFfq4UPcOrUPAoB2dryjBlv7RRmvFta J0Sq3NFZArkPM2ZtslaFWUszZoF+kDAj07eunMpY b1i1hBlQLczbHRy34Vy4w8baCzPH3TfTVWEGaN9j 1q49Zu67gL7BUtIQv5hXC5i3B33WPoIW7jFrRZih isL8iBVWbk9Kq/eY1Tay4e4xs/cTZYTLdDZxxRa1zn5Ff093XXfOfbOUhMHNIrUuzJ xwh7nHzN4fk3HyTrM8y+kzFLDHzCMvAeDp8mvSCX ThLsUOfReTKz/1yqpwDx3rgXkyYI+ZTxl58P5Q6NNgXffvLX+FxSg/I6aIx+YVW4gYsIKgPlFTrO8Qy5HhcUdZ6HvM5LIW sozv3dG6x0zMxhp2b83V26megTNIf7OEpMGtrmhm KaPcr5gnQ+wxk+6aHJ3B8leLiDKGxAp3WnDgcsou 3GOmbAudUzOlpa32rGqYfaPqe8zE+x6tIDVzj1nQ 8mx3fd25MgGDuwbEC21h5iWO+MF+C8JMvcfMEQjq/W2i2yphxi91bJi1pDFImKni4S/MvIQHPyOlM2j1Ekf8fjmdZ1yms8dMJw60x4ysReu cMCOIfaZWkwYK6wvo11wKSbQba9+j8FW9eh1xw31 FxLODtV9M90CEZxcrHXSXc7rqrX06IKXjs0NTH6M OAC2dyigLplaEGXOfyuh/iIj6ZEDljBkviriljY5bbpHjdeJjgDDbVpxo2NR9 cApB6UpHnWfc1tSpjK44eJ/K6LfHj4QZmWMkzIhng+9+g5d6RzCzVES50li+Y0Q vKQ+2IDpFDdVHJRQ+isOULlj+PhfDSFLzwvBDxVM 8KRfx+fkojJD3tT2L/Me3FzH6UhobOvr7x68xc+QITttL3OpLGc1p3HzO0/FZ4pkTZtvcYRncoF3egyQMxFsRZs49WCp3hfe4lU nC7Iz/XjVhn5Tr9MjGM+6j/x0RJ7nvc6CH8m40+ffAe7wU4W7qmYDwad1jphKWt 6X8ygYevkLCjMwxEmbEM0IND1e4Y+uNXgydSWPt2 VMBB5zvcClqLUmbyj0MfejH4cQ6Oc7ofQUpKnCh2 Vvjj5hXLPsmDj3PojDbH9O7f4vsoJt62SgZmcpIm BEEQRAEQUiQMCMLa+4lrZ0/+ITs2TISZgRBEARBEBIkzMiaMXmpI4kysjBGwowg CIIgCEKi+8KMjIzseTMSZgRBEARBEBIqYUZGRka2 X0bCjCAIgiAIAiTMyMjIumskzAiCIAiCIEDCzGXF FF5I5Fp2p5h6AYwlkGvy90NtuQReSBX3zT8rLbn9 bqr8yyWEZxK5JsqF4j2X34y581XyOzhtckj4PPes lR0SZgRBEARBECBhJloRqRc8BvYh7fkVZv6iot1m peMLSBVF/4U8zCWkZ35ALhFGnNnlQiHMcomA8iILOvv//ulDwgwgYUYQBEEQxHMGCTPeSJi1bvspzKz8cvklC DGPZ4opvKCZ/vysmCjMPNzmLJdgYC+kUJTdk/4WJg2ftbJDwowgCIIgCAIewiyXcA/8pC//zuAyJyzlEmcl5EGtcjBpu1t/Rhqw5hIML6RS1iyIM1jNJcBeSCGVcL+TSzDf8NRn VFzLysS/C2HVWIomxzOlKcxSQekj+S3HqZh6ASyRqs/oNERlY5bH8z2P/BPiohAQnmnsl5cBaajMZztPmlt26ITLww3hGQ23c qqljDkkdNxQpV+7hZmQvi8glXLPEh5Ua58w20wj4 lpXKlky32qbSYQgn4XlUGQAACAASURBVGRgkTQ2u +J7FYVfn8Xbn26g5vPUZjrChVHvnYNMPknlfD/RTW/KFyIcm7j29ll8eGevA27nkWQMzRTHzXQksH+1nkm i26V989rbOPvhHXQiBVVUC7/G2bc/xUaLnUdLwkwlBFyD8cbg0DUgtQeTjQGo2w1HBAgD YmcQKs1sWc+6BVXjXWlGzLVvSDFj5nLDvVTOtZyu PkgOEmaquMrhdy/B459x3BEH8XYYObflMLrzjxOm8t+4uAansUJUaKS hMp+bNaH8+gmzIP+48qB63iWa/fNc39+QwkwuJ/VwPW/CrFbFo0oFFdvuXRwGY6/hKve3ypOnrbWYB5l88kB0hjzdFWY7uDJhwJi4gh2 fp0Rh5n5H/P3gQwJAgzbWFRJmh6+OHA7uYc5kMOfudcDtVoWZ1 K9K/Ws3hJmqDN6bM8HMOXQiBVXsXJmAYUzgil+Ho0Frw kz11V5cQua9LNDjd8kf5eyCQrB4DXiF91Xv+YbJI 4yCO+pBtEvAKAfXclhEt5T7l6Q4qPJBvdRNjIvKf 1WYhfTTSWNXeuikoc4skq6p81C93DFAIPH1QBF3R 9wKbngukeSEb2A85dlblTl+qONn5eXzJswkDspXu 32DhFlTBA0qD9ug81kWAG2DhFlbOWx1hGhVmPnXn YMizA4rrS5l9BZMQXuNvH4XB9be4kRHjIjPBu/NCZpRE8OeyP3guSROa4+Z1zJBhZj1Wj6ocsdL5PB h8hR0Pm7ppLErX3XS0CfeYU1PqDaEj7cwk2batGa 6GmXIb99ZcDkMMWPmFa7AjxAHx7oizGoPVzBz0kQ PY2A9Jk7O3cJuffmB1WklfncLc/VnBnAmvYa9pw+QOTOEXoOBGb0YOpPlli3Y711ewc xoLwz+PcH3Paylz2Co1wBjBnqHziDzoDGTl08ysM Rl5KYG0MN1nntraZwZctzlw7yJdES9pEQpjKRBqZ d//mmkh+X/Ir5amcFoPb5TyD10HLLDLo0QxE7Weiby/rKQ9qMzK3j4dBe35k7C7GFgrAfmyTk0Vv6o3LbSf sB+fuBMGksX3H5Z71j5yadrJL2BO+f6wPoXsM65W ssnYbBBpO7rp413fqLud2TxK6zMjDbK21QOD/k8qD0Ufh+dWcHlRAih4Fs2nLRYEtLMfDWFNaFA72 EtM2XnL0OPeRIzKw8hBpMrS0Yvhs6kRTfySTCWwO XclOUPl/6JyzlMDfQIZZZPO6N3CGcyDyDMhe+tITNlpwvrgX lyBisPa/CrK65wqsp8q+md+J1QXgfkdEAND1dmcNLsAVPGTS 9NWI+JkzMrQlmx6tT7WM5wbc/oDFYePsXurbm6nz3mScxJy+e800VVR5wSJcalxzy JuVu7jXKhzHN//OuM3U5cWELqlV4YLAInKM22ZV5tI/bWkBb6gQweiAUQd6R8FtsZu36nN93+1T2Rn/HK+4B0duI/6tSXUcysXEZin4WZZ53dW8IEMxC/XuVDjHzSABvLYEsRR7FeeJdBdxuncEfon3XbPN14 P8WDpUbb6PZPTaeFmfbAVxrYNifM/GcXgg9dUAszL3cTOZ8BsCoN5fAGCTN531DR7Z+nm FKInPYIs6AZHLUw801DnzCHMh8x4trrGCC0XOEJK cz849LsRwt3PpIwC9VI2uzlkTQZzIk07pYrKN9dQ NRgGFxYtzszu6HveQnvrpZQqZSwej4Kg/XBNI9gIrWKUqWC0nISg4xhsD4ad7+3PH0MBjMQyz lNcQ0b6SgM4ximl61nluImmBGD80g+ycCMHgycTu HqjRv4dguorS9gkBmILtxFuVJBafW8FebUfQA1VB 9VULn6GupLTOwlJdrCTPIvOI30sNw20PvSu1gtVV AuZhA3Gdfh6gszZhxBIlNEuVJGMROHyRhM8wiOTS +hWK6gfHcR430MRvw6qh5ub16KwmAm4rY7d9MTMB nzEGZP8cRZEjt8EfcqFTyq1lC7cw59rB8LdWVWs8 TaYAq6usw/PwGnLBlGL156dxUlLs5jmS37mSpuTptgRhTnhfLW ZmFm9GAgkUGx3Ahn37k7djmQy7OTpiamb9oDra0s xo1GWaqUljF9zIARTTc+auSTYMxAz8BppK7ewI1v txpp0DOA06mruHHjW2wBqG2kETUMHJteturhUhwm X8dqG0hHDRjHprFcqqBSvov0hAlmTuNm1buuBJf5 NqQ3M+rltbSawoTJYIxn4eToXi5mlc8lKy2tPOcH rR5pUpiFyRppUr6bxoTJYCbz9UGg1R4aOGLnZb0u miaOHJvGUrGMSvkuFsf7wIw46l76pou6jlivJWEy ExPpu1ZdW4jCYINYWK/55Lk3wXXGKq+G0YuRmQxu3LiNjapOvgbkmdw2yuW rtIS4yWDEclJaN9qZYiaBIwZrizCT8z4wnas3MW0 yGNHzWC016h/bR2HmX2eryMUYjGS+kR+1PJIGw3jWWhPoXy+8y6D cxm1lx2HU06qC0vI0jhkGomlnT7FOm6cf7+r1uDL c41n/sn5QZ8yCl/NpzpiFekZ3xkxOl3bNmPH+6y0BDD1j5jP71fSMmV ++agqaloWZztJEn3RUxcFThPqGk4RZWNt3YXZvzg TrO4c7XCu7lRkDM5LIc1+BJ5b471oFzPYxsFgOje 96VofCxrP2fiTrvViO//K3h1zMaHQOO1cwYfCDawC1OzjXJ33lqwsXi+IHL+ Loq78RvvytJKSBtWJ5lrYwk/wLTiM98knmcmcnO66YlQkWZv0X1riOcQfZceaauV pf6Afrm0VB6baVh+KArIa1C/0ewkwVloY7/XVlZrsbYrosOD+tsiQOBuw4O2HbyWJcEP0AsIeli TYLM6lsFGb7Gu/ZAyihPDtfu8ez2KmL1gWs8+VmK4Mx1hh4Wf6OQXD GTgPRbWsPoBgm2w87TNbspeSWNNBT1ZXAMt+O9Jb S0hq4OTM7j/HZ60dx9M2bXJ5vYHHYPVgX02QLmTFRGACwPyD0Yd aqDFY57r+ANVdd5D8yAFhfQD/3nk5b4K4j1v4osfza4XQG4Mo89ya4zljlVR5At9K WqfJs58qEq3xZae3ko6qdsdumNggzMe+D03knOy5 8+ANgz1K1+/CPRn0S+97gOlvNxcT8KMyij43Dqq469UK9lFFo4+ x+Vs6XrcwYWN0vjTYvMG2kvlV4zzpc6uwn/+rrjrcwkwZ10sA3WJi1cY+ZhjDzGogK4Qy9x8xjg Kw49a+5PWby77xb6hlFee+QKh/095iFE2ZaaexKD500bE2Y+e+nUpez4NnTHxThFfN DLYAt/6znvOqA3myy3uEftMdMu5G0/2p9VZ2+KT68voD+eseqWn+vFhBiw6tety8IkXwSj EVx6Tv+CVvg8csPmxlYtyLMBP900kgP/eVyGksZVYMYyW0xzyW3N9OIMANytJSzcwEd/vpCf0MUNpEuKlRlyXfgpixLLZSfupsh8mZ9Af1sG IsbXr5YA6g+Z5RfRxKZyj1fqvpk/S0qRbqai9XfX1/oBxtehGeQlP5plPl2pLf8XDWHmO8AWc4DRZrUVpD gRW4dSyA4ZUi5ByefBJPLrn26reWHXlvgctujrgn ipA37/MQyrGonWmvLVHmWTzKw6CWITTiXj1rtTPPCTGyqg 9NZGd6OHP7xpL7kVmyHg+uslX59OGer58JsH/fBUxkKrXZaKB8bixjmPjjU2cliXCrv/v1RUNq4Z8xOzi2hWH4C3aPHlMLMdQmue09OsDBz/199mpzGqYw6wuwHhRgKPHVR46CKoJMd6/Fq96mMXqdcauSD9qmMIYWZVhrrnMroTsNmhZnOaY 5el1CHOgFSNTOlmi21r3IQ8yw4nUVr16mMh+Ous3 0WZtYXRvUXP6eDa68wswYgcVz7D+DxlQnvqVi781 QO4Gq7+CYzVV8bX7eOCDOdNNLj4Akz92CsGWGG+y kM2jMN4pdwTQLzU1eYuQe2+yrMVAN70RdlPPTioq hPj69gwnM5gyWatA6ccfmnUebbkd7uxkFMn6dlLM +dsveAcWHwE2aCkOIR601zwkyvLXC5fW/OWiKsMmMaN+t+hxBmgXVG1U601pa58+wxrkx4uWe LD612pk3CTCOd/crdvixl1KizQBXX44b9AWcdC/3Sh4bAeqEhzDzbKj4t2ivMrD1tczg11Nhzfuq94P 2NnhdMu/Y3iYNZLWH2AydA6u6oB7xey8TCCDN+oC4LGJdo8f BPedS4fCy65/4t5xnNe8zke8S8BBbnbk4Szd6DfPkes+Cln7rLIo PSuJEW3nfBaeVzkIDS3L+mVQ4D9gR6LhkMuIdPt/yo4t38PWYJ5ILic4CsKzNmQxcK7qN+KxVY203aK8 y+uxSFOGMWwydbiqOGH1VRg7ojvZ8aBDPjyBS/R9Vr+VCbZ8z800iPgyfM3F9MmxJmuI/UIEP/wm+RGpSXFwUTnJ+6wsxZguPxjA/7OWPWL6yVA4DvcCkqx0V/xiz2yZaibD5CtdbajJlvmW9HenvMmCVWanAGp9Ze oMbXddVgXTVjJi6hBoCbmDbaM2MW1BaoZ8yGcKGg aOecmZWQwiy4znjPmDXblnnOmMU+wZbCvUfVmmY7 084ZM/90zieZYvZpP09lDK6zgD271DeLwv0UBoV6plMvdG fMpGW7APDdJUQ7Jsw4nj6p71cLugLBU5iRkZEdWg u9VLOLts/CzFnbvihdArmH7e16k9+SMPPdY7aVwRjrQ2JFOvV sd7v+Fc1LKIl/k/dGAc4pZytcvIQld06IliYChJlOGukRPPi3l3EKe/fU+75aFmat7DFTDPQ30xEww3DvZwpEJz81Bm4t7n kKLhsagxSPPWaF+WEcff0zPA61x0xHmFn7Z/oSK+LJZrVdbNsVSL3HrID54aN4/bPHnH98XdEo8x3fY6bKc9l97zTR2mMWWpjptQWuO uLsm12ULmrf20ajmQ0jzHTqjKqdaK0tUwmzrcwYW F8CK9JpmrvbzkmIOnvMrFkh8YOFOq99hZlGOndmj 1kYYRZcZwEA1euIG/2IxSJSf6BTL9TtdNN7zNoizP4Pfv1fj+Lkh+LeY5 0ZfRJmZGSH2dyXdQcfLnKwbP9PZdy8ZH21ck6JKx exNH0MxpE3UfgRaFWYMXMCKeE0R34w55zs5pxi55 zOZuCVj7cabqqEkhHF+c+LKJcKyMyMWEc/8w18YRZ9rA+JXBnlbcs/a3DmnGRWRnFpGscMFiDMNNLou4/xN0f/Bh9L+21kdGbsrI7RObmqhNWU+qTE1oUZpFMZvf3i 37H2CEbw/rcVfL/LiW5bXAiDba100clPnS/q0imBTh4xPaEQXDZ0BinuUxmtk8dMJPN2mfc6lfF nqYZY0xZmQPXmtHACYaW0itSECeOVj618cJ3KWEQ mboKZSThBUtWV4HahtfT2PJWxLqisASwz4/ioUEK5+DlSp49I7qvTxOtUxp74dfGkwNDCTCdd1H XEqWvOCXjl4hKmjxk48mYBP3rmuRc6dUbdTuiE3w v1LKd9yqFTvpx2xHgFdhPuOv3VfSpjIz4Ld8seZU lDmOmks3Qqo/M7E/L4GqZOncEVjfXYzVwwHVhnradwPW6FS/y4qVMv1GVQ91TGn6UcsdZOYVbD+sKg1NfLJ4mqIW FGRnbITbGk87CIsh9+OAj3mLEeDJyas+85AloVZq 57zOQ7loR7zKx7ZaYyjbtNlIMB6f600ZllfLUYlb 76b+KK3WE1Nrvz93bZ9xZdTgQLs6A08thHIaMjzI S7oXzuFmuHMAt3j5lNtYD5EWtfi7iB/QHeH5JmizTTJTg/dYSZlHZGuHu1gsuG7iBFLM89A6cw19Q9ZnrCDJDu szJ6MTqVEd3j75ly1W8rbu66EtQuoAP3mIn3X9V2 5bsTv8FS0uBmAjTTxPMesyaEmU66KOuIeGcU6xnA qTkuTGH3mAXWGQ9hphN+DzyXqQrly0Dv6BQyYgEM uMfMcWOgXifcZUlPmAWmsxN/v3vM7s3BZCZmC8Fp4n0qYyPsQfeYKessnBnkGORV ucH1Asoy2Pw9Zu1ayij39UOt7TEjIyMj2wfrmDDb f5pft3/YsPYDiEdQP3e49kJQuhAEoUZ3cE8QKmG2vb1NRkZ G1jEjYXao+R652EhjqdrzxtMnKBc/x/mowV1mDTz36UIQhCckzAhdSJiRkZHtt5EwIw4vN6 dhMAO9r6RcS3EIgiBUkDAjdPEUZtlJMDaJbDcGbr fncZwdx/xt72duzx8XwpedZGCT2cYz2Ukcn7/d5rBlMalYVuvpT3YS7Pg8body153mt+ePi3EjIzv k9owKM4IgCIIgiOY5kMJMw2RhJpoldNouzDQEo/gs0xJmvKi8PX9ceieLyQOcD2RkzRgJM4IgCIIgCA kSZiFMM02ssNkzYIHCTAqr5Mft+eMdmPkjI+uukT AjCIIgCIKQCBRm2Ulh2d5ktjG4cs/uOO81ZpWc2aDsJL/8zxIewt/4pXqKmSlB7LBJzHstZXRmqjhhND+pFkhZ/u8aoktnSaETzsms5L6n+Qkzmi0jezaNhBlBEARBE ISEvzAThYUlpMTZHC1hxgsPTjjJfxP/33DDEjucUKuLRa89ZiqxIy9BDDurdhvzx0PsL9vW FWbeSxlptozsWTUSZgRBEARBEBL+wkwSM7aAcmbN 9IUZP+tjCxzhPftvjrAShJlaQMnu+goz2X2v+Pma fUCHFN/spLc40xVm6sM/aLaM7Nk1EmYEQRAEQRASofaYNSvMFGJGXBLoI8w8 DtzwP5XRLeaUz2uJpgDzWQLZih+354/X05lf8skvJSUjO6xGwowgCIIgCELiwAszr5ktKXx BwkwMexsPB/GZeWtamN2ex3HV3rcwp0KSkR1gI2FGEARBEAQhce CFWZtmzISwhF7G6GMdEGbZSSbOltXdsOJFs2Zkh9 1ImBEEQRAEQUi0LMykZ+SDOloWZm3ZY7bNxek4Ji cVgjLIpLgLbnq41ZQw42fLPOJFwozssNszK8w2r7 2Nsx/ewV4H3M4nGVgy3wGX1WymI2AsiZZ93LyGt89+iDt cotR2b2HupIkexsAiaWy26se+k0eSMexjdnQAKw6 R9OFK/baVS6Kj6LZXm+nIIW0DDgn5JBiLoGvVfDONyKFvK 2U2kY50rj9uRZg5pyPW/18/cbGdwqwNpzLWrXHIRjPLGL3C7SWUmhFm/GyZKx9oKSPZM2LPrDC7N2eCmXO41wG3D60wuzcHk 5mYqydKFdfjBpgZR6ZYRuX7XVRb9WPfOaDCbDONi PYg7BAIM0V8SJh1kHyybWn77Asza3B+oOsPQMKsH bjqxQEWZtvu+8WyknhohzBT+eN5j5nref8ZvbppX h4t3sfmP3sVWph5zL7R4R9kz5o9s8KskxxaYeZ2u aOd2v5AwmxfIGG2v5AwCwEJMy1ImIXGU5g9o9a20 xjJyMiats4Js3wSjCVwOTeFgR6+4dzDWvoMhnoNM Gagd+gMMg+eCq/u3ZnDSbMHjDH0DJxBeumCMCjMJxXL7qQGW3zG7rg vLCH1Si8Mzq3awxXMOEv5ekycnLuF3Rrnbu0hVmZ G0WswMKMXozMruJwI0RHsrSF9Zsh6n/XAPDmDlYcND5zB7dJaGmcG7DibryK1tud6Jg+gdu cc+lg/Ftb5MOaRNBgGU/f9w8IPDOxOmv+65RulrQzGGEMsx8+pWelqxK/bM201PFyZqeed0TuEM+k1bjmpWoCEEbq1hyuYGe2 FwRiM3lHMrFxGQg57QJp743TyS1hLn7HKLeuB+Wo Ka8KaWP945pPSRZuBg107XRa/Esra0FQOD11l8STMHuauO3tLmGAG4tf5/KkhnzTAxjLYqidNGmeGnPQbwpnMA4i1TxE6j/jolN1m/az761vPdfNrD2uZKYz2GnYYT2Jm5SHEpOXaAaMXQ 2fSohvK9szKt8TlHKYGeoT2JzDOe2vITI0qyqgdJ z69ucLdyfbKEmbvYznDtc+j7rrDx80dBs221ieNf 3dLav/X9vD0QUZMz+yGlX/5pHSpLSd8hPrSA/PkHG5xiZVPMrDEZeSmBtAT0P7tLU2AGXGI1ctqd8 cyWwr/FH2bJMyUHzYUH0CarT8uNIWZTtkV29dGumqlk8YY QBF4j3rRXJvdY57E3K1dBPUKz5cwoz1aZGQHwTos zAz0DJxG6uoN3Ph2C0ANG+koDOMYppdLqFRKWIqb YEYMOacRtTsPM55BsVxBuZhB4oghdGjNCjPD6MXI TAY3btzGRhXAXh5Jk8GcSONuuYLy3QVEDYbBhXW7 wa7i5rQJZkRxftUK7/L0MWtAoiMkagXMmgzGsWkslyqolO8iPWGCmUnk95 zoRux0SljLCUurOB81wPrO4U6Nf8aOW+0OzvUx9H PKzBJrgwjSZcLAoFbFo8o9XBxmYK9dRaVSwRPfvn ELmTEGFss1ljtuZTDGiYGt7DgMZmIifRflSgWl5W kcMwxE0/YgqlVhVr2JaZPBiJ7HaqmCSmkZ08cMUVRqpLk3di dv9GAgYZW/0up5RA2GvnN36p14UDyfPqmgcu8ihtkwLt6roPKo GjAAsNLFMHrx0rurKFXKKGbiMJk4mMnFrGWnS6UK KuUiMnGTGwRVkYsxGMl8wy97QDSe3bH+u5FG1DBw bHoZpUoFpaU4TGYglvNPGK/46JTdZv0EQggz3/yS25wy7qYnYDIT0zftkryVxbjRaAeccmVE09io8f 7K7Zmdbz0DOJ26ihs3vsWWTpxrG0hHDUUZncbNag 3VRxVUrr4Gxl7D1UoFFadidri9svKTwZxIYbVUQb m4ZNUvcxYFJz/XFzDIDEQX7LJvp3fjo5BHW6udxgw9L71r12+nPJk wj0wg5cQpOQjmtHdPn6Bit2PDF++hUnmEag0A9pB PmmDmBNJ3y6iU72IhaoANLmC9xpUvowcDp1O4euM Gvt2CN9UcYsxAMt+oybV8EgYbh1W9guonmhJmrdQ fFxrCLLjsrmNhkMGILtj5aOfRYAr3tdJJYwygDpl HvdBrs/fySZj1NruMuwtRGGwQC+v+LfPzIczspZLtOiKfjI ysJeuwMBtDhu/sdq5gQvhyhrrQcAbrhdk+ofMEAKwvoL8NwoxvqAF 7Hxo3iASArcwYmJFEvgZgJ4txVye4h6UJvYGO5Zb U4djx7ZstWCFLR9zpVJhFn08HXpjtA+tfwDr/f6dj9MO1lCbcMpCd7DgYi8GZNNvJjjcGHna8GoNE Lg3qnXJrwszyT0rPvSVMcIMNnTT3xk4PboYJsNPX KUta8URTSxnF8rmD7DiXLo8/w+tHj+LNm5yvG4sY5uJezcUaZdcKOPrqYdrBlQlD ilsNd8716S1f81zK6Fd2W/NTW5j55pf8td4KQz5pgI1nseOER25z7BliR9Qq2z M730S3g+NsDVQltyQRrVrK2On2ajMdcbmP+ykMcg Pt4gcv4uirv+HypIaVRFBbGyaNJ7DEB78wiz55pr 6aQ4x/T7WU8d4cTNaHc2JiYYyLSz7pLjveuD98FGb77DIE rfoZXpi1WGdlAoWZhn/FD/Di0VfxG87z2kqCi1dAOmmMAXzxWsro1wbgHuZMuU xaHxqFD1kKng9hRkZGdpCsw8JM6nTySTAWxaXv+D 9aDTm/LMGYvim6JQ0Km17KKDT8Hn7xIlAZXl0hYQ9YnA6J g+80dL6aup5ZX0B/fTnjOhb6w3RqzQszZ0BkDZKkDnhjEcOsDy7ts5PF eH0w0JowyycZWPQSxOzg95jppbk36vQQ9t5oxRNt 2WMWmC7yQKuaQ4wbjAoDItuPqFSYq7mY3l4m3T1m wnOt+am/lNEnv9YX0M+Gsbjh5csGFodVol0Sxso9X6r9jcFx Xl/oBxtehGeQlP51ur3y2mMW3L4Et7UtpLFSTMj1xe3 nZjoCZkxDTC0xLmH3CldzMU64FjDbx4tDBXLYQwu zFutsUHhcNOmfFC/fdAocAwSgucdMKMubaUSYAXfV6Q/sE1TCjIyMjGy/rOPC7PGVCWk/AGfRS/jOaxN3R4SZ9RVNHR67EffYgK/XoXuLHr7TaEqY4T5Sg/ZyRmk20ZdWhZlzimMsh6q8ZMVzYzs/eG2DMHM9x7uvl+beaHTyWvFER4TZ0/Iy5k45eztUewOt/LEGwNYgtD4genwFE151TzGYdydNE8KsRT/bIswCD1zwPnhFSH9dYaYRZ2W83J5L/nW6vfKqI1Ia13bxTWaqvlfHvY9S1da2kMZNCrN7c 6ZnX+OI29CHOFWvI27YH2XWF9DPz5BDo36GFWat1 lmZIGGm5V8Nu99kMOXsFVTt7fNJp+AxQADNCLN7c zC9/HSJdxESZmRkZN20fZoxi+GTrQoqFckeVVFzlsHIX 1Y7OGM2dKHgDouz3yqfBJM637rbujNm/J4sm5vTRovCDLifGgTrX8BvU4P6y3FaFmZA9XocB osh89s4DH7Z08YihuVDSQDgu0uItlOYuWbDFDNmA Wnuje6MWVA80X5hVr2OuGEgen4VpfpmQLcwqF6Pw +ibReF+CoNC2bWejX2ypSjvzr4cv6RpfsasWT/3c8as352huBRtfsbML86tzJh1rr3ynzEbthPwfmr Qvl7j+3r+ie95z5g1lcatzJgNXUBBkVbOnr3wp+s 2PnzcTw2KbZFO/WxyxqzpOiujOWPm69/9FAaZiXimiO8bBUBqG3zSKXAMEEDTM2ZDuFBQ+Fl 54nuQCgkzMjKyblrnhdlWBmOsD4kVcZdvbXe7fqq Xzh6z9YV+YY8VYJ8GFUqYOWvnFxubzy2XsL1tN9X 7tscsvDBzlmcYrv0zPrRBmDl7YQzDENfsa+29sgZ 54gBNPz33bY+ZXycfao+ZnyDg0RBmqpkfKe4A7AF iP2KxiCRQrT0VfYkV8dL12i62dzVGeIr4BJfd1vw Mruc6+aXeY1aYH8bR1z/D41D7n3SEWXCc1XvMCpgfPorXP3vM+ZfASqOCdby 947dN2gAAIABJREFUCt5jpkrvGtYu9Ou1tc2kcQh hNswVTutApAgWxcTC3vZ2fSDezLUn1etxGP0xxCL Svjed+qla8sft2QWA2toFrq9rsc7KBAqzYP9UdV4 Msx03r3TSGAP44qoX+m12ZHFDFH5729gOOAyShBk ZGVk3rfPCrH5qmHMiUwWl1RQmTAOvfGyPUjYvIWr 4n8podbrOyWBlFJemccxgIYUZ55dzUli5iKXpYzC OvInCj3x47VPOnN+ZZofudUJgTxzXhVMZmxBmzim JrgMJfGiHMHMGWfLGenifVvizlCNi7HeNKBbulsO np3QqY/3UOH6woZHm3mh08lrxRH3PWeT9bzUu7tYQZvYg1o x/hEKpjOLnKZw+IsXdSiRruSmTrzYAqjenYbLGiWuV 0ipSEyaMVz4OnnFVxEen7LbiZ3A918kv96mM1omX JpLOMZ1eJwb+LNUQEtrCTCPOrlMZ7RP8+JNDC7Po Y31I5MoobzuNRWfbK89TGeuCqlF/z39eRLlUQGZmxFrSFtTWNpvGWsLM3qsWeR/fVr7HbtUKx6Wo0TiVsV5+juBNK7GaEmbWhw/mElRa9VNuf+vvLFknIK6mMGGKywIDy1K1gA9OncJ 8wb+F4dPytaves4hB/tXr5PnPUSyXUMjMYKSHuUWpVzrpjAH8cNULvTZ78 1JUaLOdsn3kzQJ+9PGOhBkZGVk3bR+EGSDeYWLdR TWVWRO+0AXdY+a4MeDcFzM6g5XLifDCDNLdOqwHA 6fmxHt79ukes/DCDHjw/lCIU8XQJmEGPF1+zf1lHUDwPWaw02OgfpdR2PTcn 3vM/Dt5rXiiisK8PWgN3Duhs8Szhl35fqdvlpA0xJkCo LHcNKcYqwl3UBm9GJ3KSPf9eOGOTzP3MIXzM6ie6 +aX2Ob0DJzCXFP3mOkJM604S2XU1e5gE1dOH7HKO XdqQSfbK/U9ZuLdX3j6ABkn3EYvRmeW8dVilJvF0GxrDc001h JmQLUwbwsEbu+VcK+YO9+bEmb8PlsxdsH109X+Wu 1I/X49ZV8XUJZ2rmDCMDCe1egFFHdXqu7K8y+7T/FAuudu+atFRBlDYoUvv17pBOiMAXwiIdWL5tps1j OAU3MrCOoWSJiRkZF109orzNpJqP06zwvWASC+p4 J1BP6ACYIgCIJ4NiFhRkZG1k0jYXYoeIon5SI+Px +FwV9e2nFqqD4qofBRHKbOZdYEQRAEcYghYUZGRt ZNI2F2KLiJaYPB6H0FKb31YG3CPkGtZwBTuYfBp2 cRBEEQxCGGhBkZGVk37eAKM4IgCIIgiH2EhBkZGV k3jYQZQRAEQRAESJiRkZF110iYEQRBEARBgIQZGR lZd42EGUEQBEEQBEiYkZGRdddImBEEQRAEQYCEGR kZWXeNhBlBEARBEARImJGRkXXXSJgRBEEQBEGAhB kZGVl3jYQZQRAEQRAESJiRkZF110iYEQRBEARBgI QZGRlZd22fhdkm0hEGlsx3xvkQ4bj29ll8eGdvX3 3dW0vjzFAvDMbAjF4Mnfr/8a9hHMgnwVgE6U3fh5BkDMFJbOVFxNexzuTXZjoC FknDNxrPNVYe+ufNYUWn7umUTQ3ySTCWRHBVSCMS WK+I5nmWyzNwcPo1wh+9vlElzLa3t8nIyMg6Zs+d MMsnZT/vYc5kMOfu7V8gqtcRNxjMiRSu/lMBhX+6gUwmj60wbpAw0x9sHyLc6fEsD2R16h4JM 10Ox0eOZ6w8u8oVCbNO0r4yTsKMjIzsYBoJs26wm UaEDWNxowU3SJiRMHsuIGGmCwmzLkDCbF8hYUbWK bs9fxyMsYYdn8ftEO9nJxmOz992/3Z7Hsd5dyezzT0jWBaTzMO/elwmkT0A6UoW3jorzPbWkD4zhF7DXq53JoMHT50f VR3YHtbSZzDUa4AxA71DZ5CxX6itXUA/G0TqPu+B5UbfuTuoAUDtIVZmTsLsYa73rQEXEyqe 5bVioKBwJ73GLbey3UourSF9ZgA9jIH1mHg1tYag BZGb6YhY+e1OPZ9kUodTw8OVGZw0e8AYQ495EnO3 dq14AkphVnu4gplRa3mk0TuKmZXLSIQRZu8vI8Pl 1+jMCh7WxGeE/PJL73pck1haS+PMgBOPV5Hi0lLuaGsbaUQNBjOZ9 0lLOyx8OtbDJaab0TuEM+ngfAHgIXblDryG3Vvv4 ZQdH9Zj4qSQToBfOfbxHEmpfFpl0i6fi19hZWa0U Zemcm3ws+Fv4nKj7LCeASnNnGdymBro4Qaifmldw 9qFfrDBFMQqm0aE9eHcnRqUdW+Pr1MDOJNewgVZm AnlrgfmyTnc2uUTwwrXqJMWozNYuZwIJczeX87Ul xpbdekhxOTm2jZVGPJJMJbA5dwUBnq48hnUtjhp/btbmDtpcumwhr2nD4T6OXQmi41a4x132XHnkbodU YRTxd4SJpiB+PWqkNb5pAE2lrFn/BVlIvMAjZIo5blWnUNAX+JP7eEKZpy0VL1b28Wt9 05Z8bfTyJXfLrzaIKedXMJa+oztZg/MV1MQsjkoXzxRC1vhg6Nu/7S3hszUKFeGZ7AiNirikntFW5dPMrDEZeSmLH+sJ LDq0IWlFF7pNbj2PbiN2lvLYGpU5V8LZRzN940kz J4Ty06CseOYv+38zRI+wQLJMkfUuYWS5c5ktvG37 KTsrs4zspEwe5atc8KstoF01IBxbBrLpQoqpSXET QYjlrM7B3mgX8NGOgrDOIbp5RIqlRKW4iaYEUNuD wDWsdAvdUj2IG+2AAB7yMUMMDOOpVIFlXIRmbgJZ sRxvQqgVsWjSgVXX2Ngr11FpVLBk6eAu6PbQnbcA DMnkL5bRqVSwvL0MRhGFOmNGucvg9EzgESmiHKlh NXzURj1AadPslQfoXLvIobZMC7eq6BSeYKncAuzv XwSJjMxkb6LcqWMuwtRGGwQC+u2+/KApnoT0yaDET2P1VIFldIypo8ZnAD1wxlkmJhIra JUKaO4NI1jBoM5W7A7ODm/AtIbjjAz0DOQQKZYRqW0ivNRA6zvHO7UuGeceO/lkTQZzOQKdn2TsYbqowoqV18DY6/haqWCipWZ2MqOw6inWwWl5WkcMwxE0xvBgx6dQeL 9FAaZgeiC7f7qeUtI1tMpqBx78RRPKhXcuzgMNnw R9yoVPKo2xIth9OKld+28ycRhMoaxjLP4tVk/G/FjPS/h3dVSo7wzA7H6y3YYegZwOnUVN258iy2dtF5fQL+ UnpvpCFjfLAqcu426t4lLUatMZYplVMp3kZ4wpUH YHvJJs1E/y3exEDXABhfgVI3qzWmYzED0/CpK9XA1PoL44nzAMSeQWi2hUi5iafoYDGZitmB7U FvHwiCDEV3A3XKlUa55EZpP2mX/NFJXb+DGt1vQalsU+eG0LaZ5xK6fFZSWkxhkDIOp +z5lR7cdkcPpRRW5GIORzDfqUi2PpMEwnt2x/MvFYDAT8aUSKvWyyou5JoRZYF/iw14OMYPBjC+hVKmgXMxY78avwwnR/dQgmBHFgp0nVnpz+a3Eqw2y20mjBwOJDIrlRhtR/4Coky+e6Asz3/5JTlOnrpnTuGknTK0wC5MZODa9bKXd3TQmTPGjWT 5px/V0Cldv3MC3W47/BozeEcxkbuDG7Q1UNdoo66Ocwr/pm6i2UsZb6BtJmD0fphRC2UmNWbPbmD/e+FggCyWlQMpOCn/TecZtJMyeZeuYMNu5MgGDjSHD9fO1O+fQV++EpYH +zhVMGPxgE0DtDs71NTqh9YV+QbzsZMcbg7zHn+H 1o0fx5k2uY9tYxLDU+LqXMoodnRVGuYPcQmaMgY1 nsQPUOz4hrChgtk9ziY5iuZQozKy9N3xH7oShPii SBjQ72XH3QHxvCRMhhJnonzNgSSJfazxTTzuN9La EmVgGUJjlygAnzJyBQjSNjUAFZSMvI7LLy+DCuhC PrcwYGBuHPXYMcM9/kOjMAvJJunntbZz94J+ssqFRjv3wWsoo5s0OsuPh 6o5PpJFkDLEcPwtii+56OKxnVO77p7X8McUKd5/1JQWuQWZh1l33amu4wLtxbw6m/AFkK4MxZiCZr9X9kAfte0sTIYSZ/IHlPlKDXN0rfoAXj76K3/CTeCsJsezkk66yr9W22GkyscSH3mpbWCyHRi5ZIq nxnqrs6LYjUh31oZqLcW0C7Dxz8vsxPnv9KI6+eZ PzbwOLw3ybG16YBfcl3jz+7HUcPfomxGZqmCsLqp Ub1qE0H/xTUIMBdxvkuFefQbQozPaFa9+9PdQWZn79Uy2fdK WpKLLt8Ej1yEp352Oo7a8UV2UdCmyj5JlXJ0hJGF zb3UwZb6VvVAoze9kZP8Oxvb1t/52bdZGXp3nMimQnA5bPye5Iz1hL6OatGR7PwbozK 5OtP+d+NotJdhzz85P271xcspNCPLxmhhrP8LNPw b+rhJEoLiwBNDnfSIt6WgYtA5TzxWWW2644ab5nh VEtlA6SMBOXak5insTbgbWOCbN8koFFL+E7/o/VHGL1xlDqEPNJMBbFJfEFa/DhPLO+gP56ZyIP8hQ4SzpCCLONxWHui36Dnex4ow NWuBtqL0yQMLO/OE7fFF8ThKk0oFGmd6t7zIQZD429E1K6qESMHHer o11EdtYE60tgJczhmPKgaGMRw9ygoc5OFuM66RBi xuxYIo3V0iNU5VGUTjn2QXePmVCOW/JTXUaE8q56RjOt1xf6G4OtnSzGhXfEuG2mI2DGNM RiL5ZN9TO8ALTcjIqJ0fIeM/mjkAu57Cj802pblPmhrnvyLLur7Gi3IyH2aVZziH GD7sJsnyAO3chhDy/MgvuScMjtkvUB6hgS6VWUHlU1lhPyQdXbYybkjU6 +eHuov5TRp39aX+gHG16E5zbn2goSrDET2kAUeMo 926o6FNhGWXV4OGDjdTNlvJW+UT1jZg/IVULCEU0K8WYNjBsD/bogq7tju8sLL1sQNQbg7mccd1xCUTGQVwmahtvOM yqRwLsvL/NziwRRGAT9ri/MXILPFQdFGgaaeykh77Z/uopuHNSljOr/K/Ka7EBYh4TZY1yZkNbfc2YNmsQO7PGVCc/nG42q9eV6PLtTHyDwA8On5WXMnXL2fTQsjDBz7/Wqv7h/wuzeHEyvtHAGpSph5uplWhRmQjzdA46g9NYWZoaB IxMTiAQuH5KjJw2KPA9E0UwHzf0ue2sZTHF7Vkan lup7VvTKsTfNCLPW/PRIm3wSjMVx7T88ntFN6/spDNpfvKu5mCRMFMLMVffEsnlvzvSMqzF9MyA+zQ szsSzXsPsNVwbq5i/MtNqWdgoz7XYkzAE6VVyPG/YHMWswLQzen5axPHfK3kfE+de0MNPpS/x4ivLyHE45+6Tqxsd5D2uZKW5f3Cimlvh9cT40I8 x08sXbw7YIM8+y2Aiwwg0PdzSEWXAbpXcoTDNlvJ W+0Wspo3tGQpx1EUSaY9JA3xJU0sBYeEYtAJXuBA oR9Z6pIAHlGQZ+T1aQgNEQONrCTHpGGfdQgqoR78 4IMy7sdrls/hlFfvqamK9iPPjZvu4LETLROjtjFvsEW5UKKpJZa 8NVM2YxfLLlfr7CfcW8nxoEG89i83ocBj/Iq15H3LD3lTxxulR346s1Y9a/gHUpPt9diu6fMNtMI8KGcKGgSAt7T5pSmLm+XLdj xsw5PVLKL4301hZmfQms7NWwsRgBM5PI686aKWfM +rHgzjxE2yjM6tSq+N7ZszJxxUp7zXLsRfMzZs36 qY6fUN49Z8x00tr5mLLJDejVcRP3n9VTxD1jNnQB BUW7Yu3xsdx0felvx4yZM8NwP4VBZiKeKeJ7Z8pU fs9rxiyobWn7jJlOOxLuZNOq0/Zyotv+Bdfjhr2X50ld2IhtbpMzZr59SUBYjSjOr5 bQaKa841yrfl/fFzdxpYWljIEzZgH54u3hvs6YiUucAeAmpo1mZ8z 82qhWZsz807KVvtFzj5k8aHcdHtEw+bQ/QVC5ZkV4gec12BdFSvDsitfgfFtarqd4xlOc8M9y okIZjqDf9YWZe+mld/oEixudtGlRmCnKhUu06zyj658q7TzKJu1DO7jWMW G2lRlTLE2rYXfbOS1J6sC2MhhjfUhIa9lqu9viQR D3UxhkE4jFDPTzo0JVB69YR26dIrXCDVab32PWMW HmrL1flA6s2NvGtjC46OIeM4301l/K6MTbOlTB/0RGDvtEuRUn0K3uMVtfQL8sNoQ4/Yj82aM4+sYK+OGKEE/dcuzBZjoiDZg0BmIt+am/x0woRyHS+n5qEGwihpghC7nwe8ycvUWL0kbEve1t e0Db+T1mqnJtnRrrL8zC7DFrWpjxZUe7HQl55UT1 OuJGP2KxiLTvTVVW97A04SPMAuucTl/ijWpmSCgLP+Zx9uhRvLEi1Gj9I+/lNkhHmOnkiyeWgOkXE0xMY43+Sb3HrID54aN4/bPHCLXHTEeYBbZRHnvMCvMYPvo6PnvsOB2+jLd9j 9n2NpTiiB9IS/ueJrPb6pkuDWHmFgb7L8y8ZmVcy++432TR4Pd7K8 LMK2zdF2Yes40qUev7jK5/HmlHwuzQWedOZXROQnJOfaqUsJqagGm8go+3AHcH VsXNaROsfmpTBaXVFCZMA698zDfV1iCJyZ35VgZj jMGMf4RCqYzi5ymcPuI+eakw2wfWl0CuXMb2HuAe THidnPYzpNb5r+MdFGYANi9FhRPvysUlTB8zcOTN An60XoDfqYzO83L8PQLkeSpjY+CtEtL+6R1amAGo rS9gUNGBKynMoo/1IZEro2xlpudJgT9LrQfvHbE7eee0PVUaOqfONfJ FPuVNtxyrsfYbRfD+txV8v1uFljBryU/7FEDnFML6CW7uUxnlcqSd1vdTGGRMMVsUcCpjaRU p16mMzjNO/XTK6hG8WfjRSg3hVMZGWW7tVMaGoLIGpwai5z9Hs VxCITODkR6GoKWMWm1LC8LMXXZ025GwdwFaM2PMJ ehtkWnG8VGhhHLxc6ROH7GWEHoJM406F9yXeGN9K DAR/6iAUrmIz1OncUQoC87pslx5cp0k6YOrDdIQZtDIF 09quHOur3GKZL18hhNm7lMZ7VN1uRULXqcy9sSvi 6cy6ggzjTbKdSqj3bbyH+qaKuMt9I1+pzI2BrbuQ bLOEju1oOLd0psRakmYCYP2MDNm/ha0703+vb0zZmGt2cM/vPItwF3hWZ1ndP3zSDsSZofO9u8eM2agd3QKmfpl LkH3mNlr/TPuO6jupwYVg7wadm/NNe4yGTiD9DdLSBrS8ojNK7aAcDYMt3CPWQeFmXw 3C+sZwKk57g6Z/bjHbO4WN+Pivt4gKL2bEWZADYVZ6xjlpcDpnk1cs Qd+Rn33dwv3mMG+t2egsdfEnYZyvpg4ye0xs13RK sdKqgXMj1huW/tndIRZK3563GOmuHvKXY5009r6mNLvWvfYjnvMGH oGTmFOuHeq/feYifciPcWDDHcf0+gMlr9aRJQxJJypEy/Bo3mPWTPCzF12Gmnh346Ev6S9ej0Og8Ugr3Sr7cr 3r32DpaTBzXK48zy4ziGgL/Ghtotbc4077wbOpPHNUhJGfYk23OXJPKm/x8zVBukJs8B88YOvI4Z13+TlREhhVnencRffwKm5 5u4x0xJmgE4bJfqnSJNmyjg6dI+ZI1om5YGverDt LGkM3mPmuBVij5mmMPM9sEQp3jwEQLMnHXr8rhKy Yvqo3Gt2tsltnsflawuX8MKMnzHTOTQk2D+5rNEe s8NqnRVmBEEccHT3IRIEQTxf+N9jxu2d8hUV28KS QEGMCGJJITR0T2XUFWb8AN01G+Y3q8b/XQqnalYt6HAQaRZHPrGycTy/nzDbVpzKqHsYSlAcw10w7b/HTHFsvWuPWcAzuv7x7+ucyhg2ncj2xUiYEcRzDQk zgiAIFUEXTDsDXM8DOup7no5j/rY42HcExDy/90olBALu6QojzPj7ztxLDX1maaR7zLxm8bz2nwX+ vi3tQTs+j9uCYPGZgQu45013SaK8B052x18s+Qil oPDpPqPr37Z6maJwCM3xeWQDxR9Zt4yEGUE815Aw IwiCUBEkzFqxpmZ2mrZ27ccie1ZMT9CTdcNImBEE QRAEQUiQMCM79KZY7tnsoS5k+2MkzAiCIAiCICRI mJE9EyYvRSVRdqCNhBlBEARBEIREJ4UZGRkZmcpI mBEEQRAEQUiohBkZGRnZfhkJM4IgCIIgCJAwIyMj 666RMCMIgiAIgkAIYVZM4QXGkMh1fyAX1nIJBpbI hXqnmHqhtbjmEmAvpFD0Ck99L9QLSBXDuV1MvQDG EsiFcTeXcO3BajoMuURT4W46He1wvpAqdr0skbXf SJgRBEEQBEHg+RBmoa3VuNrvq4RZMfWC+PdiCi+E ETmO25Iwk8Wa9f8gd3NIsPCidf+EmRU+EmTPtpEw IwiCIAiCAAmzdsfVEkT2TJRLmKmERhGpF3TFh/Uscwmz5ty1ZtjcM2+BRsKMrI1GwowgCIIgCAI+wq w+M2NZIqUQK9Iz/MyLarmd+2/+4sFZgigs0VMtD5SX6UkzQMJSRmeGKieGvR4GD7d cM10Kc0RZImf72WZh5oQh57GU8YdAv9x5pyU+hTR 5AamUQphJ6abyVxCtLIGUXzzkstWMgCQ7FHbAhFk eScYQSW92x3tPatj9JoOpkyZ6GANjBnqHTmFu5SF q3Q7aoeWA5HW1gF+ffRufbhz2nNzEtbfP4sM7e90 OiMQByeewbKYRYQzJfDsdPVxpkU8ysFYToCPp2G4 2kY4ExbWKwq/P4u1PN57vNj+f9N6X04lM7kL5UQoze1DcGFzbS97 4gbzrGXs2xxEj/6+9942N47zzPPluXtyLRb0rhDhoCDQOMARBUESNl GsE5sIYz0IyDB7GACUi5gVgDw5H5CQggqMdc6DcD pOBBmkNbHjMCXOJ6F3T1tiWbxqKaMYRPbEcyrs7N qMZbriOZWncokbHtda0nVku3Pvqey+qqrvqqaeqq 7ur2RT5+QA/COquP089Vd39fPj8nueJpegFvT3h17zjJslBXcjq omWc47OoDEXKGpKzuJhFG/qxtL8cegftYtZBKmOoTEljzGLnSdkmqXyx8IXLvO +R+jK3sdwDe6plM+Gix2w3BGKWgfVKSQXH1eDEtB aXq6ouL2r65NfU77gaeqa1sq6Ui3KKZW2vK+wFvb jXXgMscs47FzTsuhq+cGcLy9EN3taZgqPCmbd7Wo r48709P9NN2TZi5u3TC7HZsWJWKclxSmoUKYuY3d GFYVfu8AU96N8UHVEpyXEO67tvV1WtGnF/s8ODW76ft4mYWRvtRuPbuk1EaIxGtS8gR46EGvBz Y83lwXw/7RyRsjbEwSZmUemylbU7Yhauy1Z6gsLXkCpdWSbL iEl1UvgibPRARkXWvk30HtgEPBB1xGy3B2LWjNqb OjXgaGDskqJ9ETW9eWpAzsApvdnCn1ARs4BtImaQ K4hZGojZtqAtMQNJft0V1Z2P83YVs4TUuixCZOwb EaK5sUZaov9as9kS7e+HzpEoUNHyWVMZl5K3756Y 2SQmvdewXnex3qZmQpcgTJn3TylbWLqa3IOxuc8S x6Q1LwdithsiPzFbn9Ww42r04kboxZoqJVfOo9O6 5f//w0sn9UihX47jyN1zUCem31fj72xGw8X6I2BpqKxf U/nEQe1xHTnuHh08Ma33O/3jXcCVCbnOXp29bnnv1i/12msLuhG65NqHl3QySHnsL+iRM/NaqzXKHU79aLWxWnvzlAbMstQqKrmODky957+wrm vlEzq4x5XjOOovPKKTkZRLe+Mw0ghbKavoFPX07J SO7nHbFsnkukgqR7jsrvYcPKFp/0auzw7LcUcVfby8a390+lZwQl06+YgK/U5s/3gKjv9c2X74LccpXwtpuf9cnnvjkk4+vEeu/yyPz7WZ2mptfMQbKZvvz2rcP5/3nJfVKJZRn8ExZ6+pfGJ//R48PnUt8geG2tq8ztTv0X6dKM/q6bbkNen59st17g1dOvlw4zM6PqcPI5WVfO/bYv2apsf98zn9KjxyUpciJ4x/Ts7MrzXun+We1D68pDOP+XXpNqn/4NWI3Fi2CX93Of0qPHJG8/6HZKVcNJ7ZhkxEPluxssh/Rsf03Ny49ve3Jx2VkiNn7P/R/Jngs9Cv/eZ5JK1fK+vEwcbnIPKdbnu2Y9ccvjfecz9werGx/cacRhxHI3OhD//1s9qb9L2ciC9gsfS7QMxmda18wqsvp1+Fx6dC1xq Xt9ravP40eB6sz1hrNLun3vNQ0uy1sk7s7/ef28c1ZdyQ9O/dDmkqZtk/B2PPzWl8f7/3XDf7fm7yPRb9zo5+jurnH3tOc+PeMdI+DnExS2o MhxvpjdRGW0THa3kN77mxUCP9yJSWfHFIE5JsYmZ LA9ymYpYmKIlphXE5yixW1vMlC1sskuohXIexsWD RQMyIZpFjj9mG5kYcuaVKo3HjN5yPzXjJH+tzI3K dgkZnl1WtrmppelSFiMy1IWa1GyoPuXIHJ/TKclXV5VmNFhy5I3PKY7RN8GOYqVmzXlGp4KgwXN bV1apWr57VkOvowNnrqmlT96tVvf3dw3IOf1dvV6 u6u9Hir6Xfe7c31BrxZO2APC+rafF0QY47qIlXvD q+Wh5WwSmoVAlqI6uYuXL3fE0np1/Taws3tKEWSa0LWzlqulEeklsv+7JmRwty3BHNrct vnLkqVRp1VquU5DrH5D1e65obceUURjW7XFV1dUn To4WGzG3eV7X6tr572NHh776tavWuNmqyNBxvaea YK6cwrPLVVVWry3plYlCuO6RyMA6tUpLjuHL3/L7++PJy41zOowocsSWyiNnGRY26jgqjs1quVrW6N O0958dm/D962MXM7d+vseklrVaXdfmpIbnOgE4FXby1GzpXd OQURjW9tKrq6lWVhwtt/dFAic+3Vy7X3aPf/+PLWq5/7kNC3ezet4p23RztAAAgAElEQVT5nRBcV2FCVza8 810/e0COO6Sz/j326ib4HCl+T4znubr8iiYGXblDz/h/tGhDzGrXdfaAI3forH/My3pqyJVzYErvSapt3FW1+oKedBw9+UJV1ep9T3h uzeiYaytLWfWhkv4z2r//CU298Jpe+2XrD2al5P1hYnBiVkurVS1fntJw5JmT ajfKGnJdDU68ouVqVcuz3nf6SHDjzHqsLep0wbHc m5KCr6jrZ/dG/hjkfc4duaMX699DHzwzJGfgtEL6loGaNu5WVX3hS TnOk3qhnn7nS5fbr/1j0/61PqUh19HAqTf97ytTzN7TlO3eFU5rsR0JynBPvd 8iV/37x7zPa3DOcNZG0+/dDslRzNz+/Xpi6gW99tovdavJ93Pq95jWVSkVGt/Zq1d1dsiVc+CsrtdC53f7tf+JKb3w2mtK+zjk22P 2mWWfI5paWtLUkXBDPph8I31slV3MQufO0ltjHqf nYhYXkaypiYnik1QOqxC1Ijud9Jg1KwdiRniRayr jxtyIHLekett58bQG6g3ne3rpm/u079tXQj8QN3TucErDJYOY3bkwLNdoEHuykk+6RS ti9vaZQiy18db0o5E66TSVcfH0gJy9Z3U9/H+/Iadb03o03CiS1Ei5DBoxWcUs/MPXOs3rwijHnQsaDvd+SXUR9baJi//i6QE5x2a8MR/3XtI39+3Tt6+ETnjjnA5HhKd5qkwgumevh6/9lqYfdRrnqpTkmPVzZ0bHmvwlNpEsYmb5LGws/oW+9a0f6++8DaxiFqlPLer0QGMbr8FrXGvtmp7e2 37qYVIqY6OBK0l3NHMs9Lw1vfet4V2XIcmRPxIt6 ftf36fHnw8du3ZJY7Yex/pHohhPW/Y/J17nThtitvR9fX3f44oWY8y4z2aGgP95DjU6Jfmf/cYfwbznpc0/FITLXs928Ni4OCq3Xj5v3FV0G798wTNg1KP3HWAI d5AuHvSSLZ7WgDOiOV+iKyVXe4tFDdS/Oyx/BGztwuypjMa1Lp4OXYcpZrbP7MrL+s63vq+ftjwI Lds99X6LjHu6eDryW5flN6gjEif/COoz++fg0djDmfz9nPY9prfPqGB+H/u/hcEf8mzPchLtjTFL6nUxG/K+5I2N6Uj9eH5j+0jzWQ6Tx5hFxy61PsZsG4pZlo k4wtuHj5NUXtv5Wlo3LcsYs4R7YLlPjDEjbJHvGL ONOY2EviAjDWcr5l8hWxezSsmRM/SMPoiVI5+89LiYmekwQfm8192JK9EDXD+rvaFr6H iMWSSF57rOhhrRXqMuEOEQkR/v7KmM7Yttlrqw3eshPRO9kZobaZRrY24k1Ojwfpy PxS42XAyz8dRczG6cO2z9S/ydmWON5yBrim1WWukxe+SMZpdWFR9nn5DKmHLMlX JRjjuh6F3qbBxe1jFmkectw71vhetn98o5fE43Wt orrf78soxdShGBNlMZY4cxny3zufL+mBVJ9ZMUk9 2YfLSOdYxZ5LvVK9tQ9MZ5n9Pg3JF6rOnSmGP9TY hIUK2ikhs0qhd1emBApxeDf6Xgsx9JbWztwjKNMY s+ywk9ZoNjKl9ebj37IUK2e2r9I2Hkuzrbb1BHJE 7+4ffmtvA5iH+0s44xy/I9Fv1tbGW8ZH6zMtplpD77njlLYoYGd+KsjLHZ/lqdlbG3Y8yi151hjJkRtp6meO9iQs9nkwlXYtHWr IxJ98kyK2OqkCJmuyFynvxjQxdHXf8HxvtijDScN 1f1ypnH6uM64tPstipm93RhOLlL22wwtIP3YzimS 438TC8dphqkxATl82bFs5fFVfBb2fnkH16DYO/Z63bpszXGIj/eWyFmWeoiWo57F4aT0xMC8d64qFHXb5xdP6u9hoR urr6iM48FY1ca0YqYVUqO/f6EG3O9EDMFY5waY3P2P/anoXEUrYvZ3/3pAcu1br2YZbr3LZB4D0PU1n6h6fFgTEoj7PWXZX KIdsTMXIbD/GNPY5/GqZPlLi67XRCz8PnvXdBw0n0LRDtjPUafG0+E699 xA6f0Zs3vOTt73e8Jt/wBKvuF5SBm8scxhsaiPjyu2bbGRWa7p83FLNtvUE fkmMqYl5i9faaQ+P0RSGrHYvbZZ+2tY5ayxlh8jF TzXptAbqbC65jZxkY1WUOrZTH7LCSF/jW12quVNitjZF22mJQ1X9csKQUw/bjp+6ZGG+uYJU860qjXuaZ1ipjthsh9VsaNi6NyB 05r8b0pHYj8eHrS5g49pcvL9+uDw1MbLll7zEZ+r Fvm1L3tjOGysXhaA0lpfZHyeT8WB59ejE8jXK3We zjymJXxvakDcvae1Y+mDkTSM7wesyAFKMSViVD60 db1mKXXhe1ej+jHtyzTMN/d8HsqGuL/3tSB6F/eNy5q1HU19NRlLde7k8wGQMYes1CqaMAHzwz1XMw abOp+fUzLGb0dOn/LPWax3sFe9Zg1u/fZad5j5v1xozA6raWPNiJjiLa0x+y9KR1wChqdXt JHG/VcZ+OzZ+8x2xub9eIDPTO0BWLm95iNXWqMHxz58S 3L59w2htPvMRuZi41ZvTIRnWRopVyUM/SMrpSL9ZTFWqUk98CU/nZupLPv0LzErE5NGx8FY1qH1frKG9nuadYes2a/QR2xDcVspVyUc/BpLVquOZjCPxcx2waRea0t4oGMZrNyErsj8p8uf+ OiRt29GhkpGj/A9ln4ZodTGi62mbfWZzUc+qK+Nf2onIExXYpO0aS 122v5DHauD/IODayvX1L4RyoYW3HO2G5dt283fhFXysU20qwMgs k5zHE5mcaYeT2Z0UaAcR86FrMsdWHc61vTetQZ0N glY4axtduRGcU2Lo7K3TuikaKRymRrMBjPSvCDfv hcqPbbHmOWo5jZZp0zxnr96i/+lfY98gO9F94vUo7Wxcz7o0MXxphFnu8MDbWM9z4 r9jFmi5o8vE/ffOmevW7M684yxuzWBZ3Y93V9f0nK9Lky6sLW0K5 de9pIO/NnsKt32bcyxiwHMUsdY+Z9LmJLidTWdHstLJotjj GT/O/+AzpwIPS52JjTiFPU0JBrkZiWLszIgmhdzP658i3 t2/d/6tJGZIc2p3ZvZYxZmphl+w3qiKZilv1zkCRmad/P4e3qKfz+mPJzxg/0+u3bCX8ATgcxI7oetnXTckgXJXZGdGEdM69XwzE bmkHjtjCq84vLWl16VVNPPORN/Z04a5n3gx3MfLW6NKuJQTeanrZxRRPhWb6qy7o8N ayCe1Q/vOWVZ/H7j+mxycXWZxb08WYea4zvqVZXtfRqWWODbmimN0 krz3jbBTNrrS5pdmJQ7kPf1uI/e5t4Y5WK+t4vq/pord0S+XUZG9yfNCtjv0Yvrte3efPUQGNGuqCMTp 5ipgx1YTbYN3RlIlz2YBY4V0d/GLpIf6xVrGfQb8QURs9rcXlVS69O6YmHjGclGLNR/J5+Wf1Iaxuy/PAnzcr4e5pqTPGVr5iFPhuzy94Mb1PG7Ii162d1w GnMfmfO4NeWmGlFzwy5jVkZLedtlfjzneUv6Bnvf VZiszL6vRnBzH/175Wn9OrSqpYXp3Xya/0pqYyyzMro1X/jDzYZPldGXXgNSldDT72qpdVlLU6f1Nf6zVRGbzz VwNicVldvewKUNIPf7001GvZ5iZltVsbQjLcbVyZ UMJ7LqeGC3KM/9IQu66yM/aO6GLE777qjY2b9z299wpU28bMgxuZWtXp7XW31m K3PacT4fovMAtsqGe5pczFThu/dFb08/phOXGjzy72pmGX/HMS/K7N8P3vXYP8eC76zV7U0O6FB9yF92//hRcyIbReW2SWRMuKzz7q0wLT3V9V4Sl18zaRfaLb khv7CHm/ErYfWbHH3PKyTl57TmPlFHVkXx8v1n66v7eLNHBa e4rkdzPFL7p6H9Mj4tH5h/Ek/soaM06/9j52Jrm2zsahJvxHYyRi49793MGGWqWbrmMmvr8Z 6TA+fvKTnxnIWMzWri2brmHn3e3zaWK8mEP9YOlR Na/Nn6mvk9e8/ofIvZlVyo3+B3Vic9Bu/tjEw9YJnWscsPzHz6ypYoyxhPbHwelGOu0cHOxxj 5h30zZzWMfOJPd9ZxEzKdu9bwFgry/wcbr4/HVp762GdfOUNnRsKpSsmrGMWXmfq4fHp6JpezT5X sbrY1PvTobXbHj6pV944p6FID5m0cuEJPeQ6kQkO sq1jloOYxdYxi68RaT6XkXppeR2zAH8NTGOikDsz x3KYYXBFF/w/CnpjkNpLZTS/3wqPtDvGzHI8N3kds1Qxs5Qr+ux749AKpxc7mNGy yW9Dxs+B7bsy0/ez7Xss8p3tqH//YzoT+t3bKWJGEMTOj66IGXQbL70ydUZCgAzUakbz zE+r5NkCgN2ITcxu375NEATRtUDMHlg2dX91Sa8+ NSS33ZQZgIB//plOPvSQnpi6HElDi6TnAgDsIhAzgiC2OhCzB5Yrm nAduXuOaupa20leAHXWr4Wna09KKwMA2B30RMwWJ nXIOaTJhR42Dhcmdcg5rpnU7RY0eciRc3ym6fFmj kfHTx2aXOh545cgtmsgZgAAAAAGu7PHbEbHHUdOE zFbmDzkiVYTMfOkLHSshUkdQs4IIjEQMwAAAACDX SdmM8dDPVspYubLVXMx8yTv+Ez0dU/qmvXIEcTuDMQMAAAAwCBVzMJy4jg6Pun9P5CQhcl Dco5Peul+EYEJeqQSUvuMVMaZ496+0XRAU2rMYxq pkDPHm4uQL2WHJheaiJOXwnhociZzKqP9XIgZQdg CMQMAAAAwSBSzhaiEhSUtImaxlD1PoCKv+UIUPZY hZpF9fAkzRC98zE57pNL2b7yXfYyZ9RiHJrWwDRr BBLHdAjEDAAAAMEgSs6AXK9yYCkQsKmaG3Fh7igy xsomZITGRY5uSmEMki1k4NbFdMbPIKUEQ9UDMAAA AAAzsYpYgFguWVMa0XqHIeK4mYmaVwECcFizpkp1 FkphFy9KemNlEkyCIRiBmAAAAAAb5i1l0LJh3jAw 9ZqliFtoupynps/X2tS5mTPpBEM0DMQMAAAAwyFvM7GKSj5iFI5C0dt Mbs4hfNJrLlnfMHq/PRhAPQCBmAAAAAAYdjzEzxMy2X3g2xNu3b+ciZo2 ZE9vrNcvWs5W1xyxItaSnjCCyBGIGAAAAYND6rIw NoUruMQv3GoVSGwPBaVXMbJN/zBzvqHcqPzELpIyeMoLIGogZAAAAgEH2dcwOaXIm KlRJk3+YKYHHZ3x5CbZtp8fMWFMtlsbY4rphnYhZ pLzGBCfRQNYIwhYPuJhVVHIcFcsrvS6IJGlj8S/0re/8O92o9bok3WBF5WJ36rq2Nq8zjxTU7zhyimX1/m6mX+uvZ36ivqM/0Z///RYXCwAAtoxUMTODRZMJgsghELO2T12S45RUCb105 8KwXHdYF+5sfXG6T7fEbEMXR105hVFNL62q+tGaN nI+Q+sgZgAAux27mBk9XLdvq/01vQiCIKKBmLV96riY7Wy6JWbecZ3SdqpJxAwAYL eT3GMWnfY+zzXECILY3dFdMVu/pvKJg9rjOnLcPTp4Ylrvb3pvbb55SgVnQGOX1uub rzwzJNcp6tyNmuqN46dnVT6x30tzc/fo4ZOX9GE9VdAiZrUPdenkIyr0O3IcV3sOntB0cF JJK+WiHKek2WtlndjfL8dx1F94XFPXGuXwil7WiY N75DqOnP6CHjkzr7Wa6uWKfCH7UhEcu5J2nEj5pU rJkVM8pzcundTDe1y/zOOa+zAtH3Jd16bH/e0d9Rce0clLHyq8R+3DSzoZpAcadd+QoVldK5/Q/n5HjtOvwuNTMqohhH8/vveKpkP39GHjeqSaPrx0Uo8U+utlOzO/JuvVrJRVNH7cGn4WPY6756BOlK+pUTy7lFdKIcnz j1+avdZ4hvoLenwqfBz5z2nw/n6dKM/q6Qxi9n//v3+rb/wfz+t3jv6l/tcXPvTe/PID/fDMj/QvHn9WfUf/UgNnFvUPX0rSh/rzP3pWfX9U0YXn/q3+xeOe2NV+tajh//15/c7RZ9U3/CMNv/iBva4AAGBLaSmVkSAIIofonpjVbqg85ModnNAry1 VVl2c1WnDkjsz5jeINXZkoyCmc1mJN0vqcRlxHB8 5e9xumvjy4D2lsekmr1VVdLQ+r4IS3MRvn65ob8d LiZperqq4uaXq0IMcd1UU/P86TJ1f9+8e81Lnly3pqyJUzcEpv+i3i2vWzOuC4 Gjp7VavVqpYvP6Uh19GBqfck1bRxt6rqC0/KcZ7UC9Wqqvc3Q8duiFlt8bQKjqvBiVe0XK1q9Wp ZwwVHhVKlLgaVkiPHdbXn9/9Yl5erWl2a1mjBkfPotG7ZK1Y3ykNy3UFNvLKsar 1eCpq44l+kX5eF0VnvvP4x3dGLfppgULf92j82ra XVxjUOnHozQQwCIS1oeOqylqurWpqd0KDrqHB6sb 7PeqWkglPQcPmqd8/ODsl1DujsdctRaxu6W31b3z3syHnyBVWrVflVqVs zx+TWj1PV8isTGnRdDZVvJNz7UH0aYub27/efoWVdfmpIrjOgU8HN1oqeGQqlUq5eVXm4ICelJ9 YTs+fU/yd/q1/9+m2NPPGs+v5oQb+W9NnrL+t3jv5IE/Mf6YPLl/Q/H31O/9vrn6suZkef17/8q/f0wXv/Sf/w6ee6+K+fU9/Y6/rprz/S30zNqO/xl3XxU+tpAQBgC7GJGUEQxFZFrmJ258KwXOdRTYf sovbmKQ04RTU86pLGBhwVyze0eDokaZICEdh79nr oqDVdP3tAjltSpSbFGuf3XtI39+3Tt6+EJODGOR0 O9cR48hQtlxZPR8q19P2va9/jz4cmoajp0pgxMYUllTEqZrc0/WhYRMN1MKDTi8FhnIgUStKdmWPJaZK1ikquo0cjF 1BTpeTKOTajO5LuvfRN7dv3bUWr4XDomL5kGfK3e HogZfINbx9T3N6bCt+Pt3WmYG7j10Opki584VTG2 ps6NRAWcP9I04/KcY5p5o7UiphF62pRpwdC+y2e1oApjrVrenpv1lT GoCfME7O3zj2vvqOv+vV8XU8efVb7Zz5sbDc+r39 o1J7+ryeeVd93/Wf8p6+SIgkAsE1AzAiC6GXkKmaVkiNn6Bl9EH5xY 04jkXQ1aX1uRK7ryg33+EhKHOcTkagMY8yCdLaIm BnSs1JWMSyMSdfTipjVLmnMcXRsxpwJJCoGseMmH LvO9bPa6xzWuRvJZbURvW77uK6VcrGpmMXq+vpZ7 Q3qbqWsouNq4oq5yd6mx42U5cY5HQ7Ja507MzpWv 5ctpDJGb3bkOlbKRTnuhKJFbmWMWVTMKt99Vn1Ho/E7U/8+tp1fM3ryqLn9cxpfsJ4WAAC2kHbFbGnqiJwjU1 rquGE2pzHH0ZGppa1tEM6NyXHGNBcuRy7XkxRLmj riaGwuoS7DQx4s5TC3sR0nNZamdMS2n/96cFz7ffDuUVr50q4pfsw5jTlHNLW0hfeb2LaRo5 jd04XhpLUrHA09E9K12i/0nf/FkXPwe3o/coyExvFKWUXngP707yRb43xz9RWdecwfA2UZu5RJ zGpr+sX0eH18Uz1aETOrFMSvq2Uxq5TkNJFIaVOr r5zRY8HYtnp0QczC1/n2GRWS1iyJyU/0uJGyJF6jd79zF7PYNXcqZhc1+4//pDtBrP/32HYevpg9/beNbf/xn3T/v1lPCwAAW0jve8x6JGZGzI1lE46Ojm8To7kxORFJ 8SVobC55m7mxFuXMk8LYPhZZW5o6YtwLU6L8Y6XV 1dKUjtT38a4n/RzEbo78e8xGfqxb1aqqRtzdaKSNrTwzJHegoILra mQunPSX0Di+MiE3qcds46JGXVdDT13WcjBYKdKYz yZm700d8MccfaSgqLEGfMYes5E5c/L3K5pwu9tjtnFxVK47pKcuL6tRDaXuiFm4PCtlFZ 2Denoxfs+r1fvaTDluvMdsryJZrJL0wTMa6oaYDZ xWtHOuUzELUhnv6Prf/FI/+9Xnse38yvPELEhl/Ojv9drf/Ef9A2PMAAB6DmLmRffELNrbZMrU3JghYZ995olXv Sy+CBnbWPdLiHDvVfj89mNERczaMxoRr6TzBb2RX vkb93dOY5GeSmK3R65idmv6UTkDY7oUmf6uprXbo Rn6bs3omOvq2MxvvLFjke3bGGNm62lZn9VwS2Jmk 5aarj291yJmY7pUCx+mzTFmrYhZwhizxcnD2vfNl 3Qv4Zjrs8O5iFnqGDN/bFjx3I3oeLL127pttzJ7WTKNMbuus3vN52Nds8Ot iVneY8zmp55T39G/1qUvJX35S42YY8wiYvbvNf74s+r7k1+qJqlW+WvG mAEAbBMSxcxIcTMb9dEGu5+mN9XYJ7k3JyoqR6am LGLW6OHxwmjIB2mIfs9RqvQkpenVUxnNcx3R1JTZ ixXeJ7knKPFaj0xpyZpKaEpLuO7TUv3sspZ8H49o as48f8K5I9eVtE16pIkZvWWEGfnOyrhxRRMFpzEr Y3VZl6eGVXCP6oe3pPoMigfO6npNUm1RpwuOChNX jJkDBzUx683KuDQ9mj4r461pPeo4Koye1+LyqpZe ndITD7ktpjLW9OapATnukJ56dUmry4uaPvk1byr1 sLQsntaAM6CxuVWt3l63HjtpVsb+0YvRWRlbETPL rIxevRRUqqz71fCoHKeg0fOLWl5d0qtTT+ghN59U RtusjGGB8pY8aMymuLo0q4lBVw99e1H/nHZcoyxJszL+3lRwrsZ9Ont1VdXVJc1ODHqpm62I mTkr4/JlTWWaldEuZmsv/jv1HX1ej8+t6oPX/lrO0ef05E//R2w7j3/SD089q74nXtKP3vtIc3/yvPoef1WVLyVpQ4vff0yPTS5ugwW3AQB2H1YxS0h xcxJ7UgK5aTZuyEzTa0hRo7EeT5Uzzx2k8oW38SS sIXCxHjDzmowxZtHt7b14HfWqWcUsQe6SxoN9Fi5 7ljFaIYGLHTNdzLzXG+WLSG6zOkhMZaS3jIhHd9c xc1zteXhc0/5CWeuXxjTgFHS6MQ2jNxFI/bWEdczq64lJ8XS2mtbmzzTW0Np/QuVfzKrkOjrs5/5lGmO2+b6xVtcreuPckNFDtqILTzwk13Hk+rNdtL +OWStiJknrulY+oYPBOmb7H9OZ8DpmtTXNnwnWcu vX/hNl/WK2JLeeAtlBKqO5jlnkfnj3ILz+mNO/X4+dMdc6ix83vsB0s3XMFF1/zPXWVHturFUxU9vrmNnELFjH7H86+qz6Hn9eB3/wd/ovsmwXXOWvFjX85F96k4T84QV9++f3/Xfu6MKwK/fYTMKyCQAA0E1sYpacvtZo2FvFrEkPTrQnJXrcui BYpcM4vm2bSPkylCdVzGxl7TDlMg8xC/diZuktC1+j5ZjWVMbw/Viy94BmmfjFNvkHvWWELfIXs45IH+cDAAAA0C2aj TFLmg3QJmbNGt3JY5oa+yb1SkXOF5tR8TO7ONrSI INoImb2HrYOZhLMs8cspZ4Sj207ZuyajB5MU5qbl Ts1QrNehgWzqzNhEg9CIGYAAAAASk9ljMhYhh6zd DFL6sWK7muOC7NOI59BzD6rb5eQgtdMzIzydjw5S M5i1mybmAQnbR+poyOaWgqJcuI5Wu89nBuzj1trZ RITYmcGYgYAAAAgu5hZJaRjMeusxywSWcUsto+ZD pkmZp+FepRymDky18k/ml2vse6YGWkiFDluUs9Yi/WxNKUjRm+Z/TkidmNsMzEDAAAA6A1xMbPLQpAa2ImYZRljZt3mM 0Pq2hEzs8xZxCwQkLGx5qLULBLKlzhdfr1sCRKUR d6anD9ZRo16SRiHljWVsdFbFi83YkYgZgAAAABK6 TELi08otTEiUC2KWbuzMtoXWE4TM1vapCE4mcQsl FrZqTw0SSVsvB5fYNomLy2nAKakeqbO1GgRwJbSO sO9ZZZzkMpIIGYAAAAASpr8w7K211JUGNoTs8/U3jpmRs9Qph4z8xiGAJjHSJiBMLcJMFJ6mWLj6pI mP4nUm6VHM02WMo0xy5gamVmk/PXt0maXpLds1wdiBgAAAKDmszLu+uh0NkaCIFIDM QMAAAAQYtYsSLUjiO4GYgYAAAAgxCwp6qmDpNoRR FcDMQMAAAAQYkYQRG8DMQMAAACQXcxu375NEATRt UDMAAAAAAwQM4IgtjoQMwAAAACDlsRsYVKHHEfHZ 7a2ETdz3JFzfCZajvD/uxEzx+U4xzVTf21Bk4dC/2/2frvRozoO6vnQ5ELr9XRoUgux9xY0eSi8DEB63Sx MHore42bPQ3j6fst+C5OHItvY6jN6nGz3rrHPIU0 ueNffcp0RiBkAAACAyYMgZtHwG/xbLGZeQz+58d7s/czRozoORKYlyfDLahOzmEzHRNas62z3NFbPfhnC5 Y5Jnn/8cJ3OHDfLPaPjze7fzPGGkNX3aUNmCcQMAAAAwAQ xS4hdI2bRnq2skhHpkTLFzHoNnsSY1xXptWp6T72 ymmWMiljKeYJtFiZ1KCJYtuMkPROIWR6BmAEAAAA YpIpZ0CMSpINNWhrcxjZmw3Zh8pCcQ5OaiaSWmY1 ir4Gb9H6jUW1ud1zHYz0foX2sKXZJ5zQa2CExM1P njs+09r5ZV2n1104dJ4lG8wik7LhmWpCMQMqOzyT Uc0Yx8+rtkCYXssq2XboidZ3WM2fb3vKs2p4ZMzX SOXQoek9SnzXCDMQMAAAAwCBRzGIpYg2RqTeMY9v 4DexQI7XeoK03us1t4kJg9j5F0+KMRnysF8N+TFs DPy5ioWtr1mPW4vtWYcmpjvOJ9np/kgS4pVTGrL2gSQIaegbqcmUK74y5fYKYpUkdPWa5 BWIGAAAAYJAkZtYGtyEvWXpLrI3dcAM3Q+peqpjZ GvVWWWvWMDca2VsgZnnVcT6Rr5g16iRLj1J+Ylbv vYyNHzNlN34cb1/EbCsCMQMAAAAwsIuZfSxPVAHTh8kAABZESURBVAi SGqXRfa3pYZEGbmiMU0LDPF3MEnrYsvYoBRNPmOm MXRez/Oo4n8hTzCzHSk23zFvMmqUpJsk8YrZVgZgBAAAAG NjFLKnBGe55iI/RsglOczELNfATxns1E7NsMhO/jui5trrHLL86zifyE7OklMBYemM9chYzi5THy2RM 5398hlTGLQzEDAAAAMAg/x4zS4M4g5jFGvBmOl+amN0ONcibpTFaG+mW69nWP WYthtEraJePnMWspQlZ8pv8I+ncWWbNbNrTipjlF ogZAAAAgEH7Y8ySGtPRxnM7YmZKSxYxC455/HjyzHqRBrh1/7zFzLjGLOPH2qjjfGKLxKyTHrO06fKD86WNH4tsY 9ZfhvRQxCy3QMx2IB9X13T1rXf02us/3bFx9a139HF1rddVDQAAO5R8Z2WMN9SbipmtkWw0 gDOJWah8mXrxLA3syDi3TsWsrfprr47zifzHmMWn/O9wjJnt3iXVT2Kqa+h84XJnnmYfMcsjELMdyNrd+/rk0y96XYyu8smnX+ijj/+/XhcDAAB2KLmvY5al98Rs4JrHMM5hn3rdifVIxYUr OeJrjxmN9VhD3RC/Zu9HyhmUNUlYOqvj9tcxC0eCZDQ5dtP0xMj1J527 lZ5B87h2oYuuO2Y7t3GcLKJr6QVtnCeHxcV3USBm O5C1u/d7XYQtATEDAIBukSpmD1h0pyeJWJg83qH0EUQ0EL MdCGIGAADQGTtHzLox7orwepboDSLyja6K2Uq5qF Kl7e/EB4gVlYslbZdLRczirJSLcpytuUfeubwUgN3x/AMA7DwefDFrpKQx1qcLsTCpQxnGfhFEK9E9MVspq 7hLGqZb2ejPAmIWZ8vu0S567gEAdjIPvpgRBPGgB WKWA4hZb0DMAACgW9jEjCAIYqsiPzGrlKKzwoRaq eE0r1iq10pZRaeocsVr3AbbFMsr9Qav91pR5ZX6T ioXHRXLFZWL9nMmlavYOEj9OKVy4zz1Q5jXEzp/peTErye4jpXIyVUKn7NSklMsqxzsXyxrRbZjmsfx 309p+UfF7KbOD/apry+IQZ2/meW97U+amEWfs5LKFjFLfRZ9IvciuF+he2VsHH1O krYDAIBtzwsvvKB79+71vHFGEMTui3v37unFF1+0 fjfl1mPmNYRDouFvU5eVunw1GtCNhrH5WvD/lbqQNUTLk6CIvPiN5sZL5jbBcQwRqpRir0XPb+mN ySpmFoE0jx0vd3MiYnbzvAbH50P/HVTf4HndbPbeA0CSmMWes7owmfcs5VmUfy9swpwm XPSYAQDsCBYWFvTuu+/2vIFGEMTui3fffVc/+9nPrN9NOYmZISb1zUJSY2kcW8UkIku+UJmNZds2 Zms5wzbW3ilD1toXM2ObhEa9KQjNSE1lvHleg33j mm/1vW2IXczsz1lUeLM+i/Z7iJgBAOx8fvvb3+rChQu6fv06PWcEQWxJ3Lt3T+ +++64uXLigzz//3PrdlI+Y2USkvp3/uq1Ra2sgW4TKbGQHjehGaqGtsRzaJvE44dPaUwzb FzNbap1lHJRl2zTSxGx+vE+DCfmKae9tR6xiZq17 o24zPItJ96KpJCNmAAA7ht/+9rdaWFjQCy+8oJmZGYIgiK7Giy++qJ/97GeJUiblKmZOQmyNmCWdP1XMIuX2z5lbj1n6mKd odCZmN88PJo4jS3tvO2MVsyTpCtd3hmcRMQMAAAC A7UZ3e8zS9qm/1oaYhY+VqbFsO06WFMgt6DFrkdRUxvlx9SWlK6a9 tw3JvccsafsQiBkAAAAA9Ip8xCypwRoWlA7EzD7G LH1MUfTYNjELpzqGD50lldF2HeliliQMK+VizmPM EnrG0t7bhrQ9xizzs8gYMwAAAADYPnRvVkazEd2J mFlmZUyfRMTsDUvpMQs3xENpcMGu8d6VpBkfm4iZ LLMyttHQj4jZ/LhCEy9GZ15Me+8BINdZGS3PTOKsjGk3AzEDAAAAg C7RnpjJPr24OY4qIkKdiFmpHFnHzDqJR8r6as3Gq kXGesVmj2xsE5/6P5A44/gpE3pY10Yz38+6jtnN8xrsC69VFkpVTHvvASDvdc xsz0zkXpQqTeseMQMAAACAbtG2mG0NCePAdjGpqY w7iDQx6w7NZ+4EAAAAAOgWiNkDBmKWA03XzwMAAA AA2FoQswcMxCwf4ssXIGUAAAAA0Du2uZiBCWIGAA AAALDzQMweMNbu3tcnn37R62J0lU8+/QIxAwAAAIBdBWL2gLG5+aXufvL5jo/NzS97XdUAAAAAAFsGYpYDH1fXdPWtd/Ta6z/dsXH1rXf0cXWt11UNAAAAALAjQcxygPRCAAAAAAD oBMQsB5iQAwAAAAAAOgExywHEDAAAAAAAOqE9Mau U5Dgl9WR1sZWyik3WnPLWqGqUr1Iy1kKrlFTMcdE qxMyvY39NsNiycytlFXv1vAAAAAAAPAA8eGKWAVP MolRUchzErA0SxSz8PFjEuVKyyBoAAAAAANRBzHJ gt4tZpeTIKZbl1ahXv3URWymrWH8PAAAAAABsdCZ mlVI9fc1MYVspF0ON9fB+jd6UIMUwnAYXCFXktei BYz0ynog19i8npTKulFUMldcpllWOSEW4qKHXm4h oVMxu6vxgn/r6ojE+H95jXuN9gzp/s0k9bzPaETN6ywAAAAAAmtOBmEWFxhOphrxkFrNw 71VInMzXov9vHMOTspCo1WUxaYyZ0WNmlMm6TRNs YhYVsQbz44Gs7RwxS0xlpLcMAAAAACATHYiZITO+ QAX+k13Mwj1RKyoXzR4s/7XGgUNiZhco87ipYmYeP+n6UmhFzDx2Vo+ZZJ/8g94yAAAAAIBs5DfGrF0xM7aJzaCYJmYJMzSmz8o Ylznr9i309DRLZYxL2s4TsxgrZRUbhmZPSwUAAAA AAEkPupgl9WwZ5WsmZtGytz45SNrkHzfPD1rSFne 6mK2oXIz2anp1693LPCdeAQAAAADYCTzYYpZTj1m kLC2mMUrNZmWc1/gOn/wjRqXUqO+ECV8AAAAAAKBBd8XM2MacqKNjMctljF n4mooqlSxC2QTELEy4t0xNei8BAAAAAEDqopgF44 oi61k5Ts5ilsOsjI0zq2TOCJmRiJjdPK/BkIV5qYzjig4z28FiFu4t814glREAAAAAoAndEzP F1xerGFKVh5jZzpO4jlls+/QevdTrDRHtMfN6yBqTf0SlrDFdvh+D5/Wg+FlzMauolFh/TP4BAAAAAJBEe2K2Q2l1NsaA9FTGnUNLszICAAAA AEBmELM64ZS71kDMAAAAAACgExCzIFWyjbFlAYgZ AAAAAAB0AmKWA4gZAAAAAAB0AmKWA2t37+uTT7/odTG6yieffoGYAQAAAAB0CcQsBzY3v9TdTz7f8bG 5+WWvqxoAAAAAYEeCmPWIj6truvrWO3rt9Z/u2Lj61jv6uLrW66oGAAAAANj2IGY9gvRHAAAAAAA IQMx6BBOGAAAAAABAAGLWIxAzAAAAAAAIaEvMVsp FOU5JbazFvP1ZKavYzirTLYKY+evHJdV1pSTHKar NpeUAAAAAAB4oELMITWQhRxAzxAwAAAAAIAAxi4C Y5Q1iBgAAAADQnI7ErFwuynEcPyyiVimF3ndiDe2 VclFOqew10J1wI32l8VrSfsWyKpHze9ushF8rlmW 26yulpONWVIqUNXQ9xnUUDVuolBwVy+X6/t773vGSvCMqZjd1frBPfX1BDOr8zfDb5zVYf29c8/ZDtngc470ukauYRe5DUeUy8gYAAAAAO4MOxCwqPp 7wmDITbTSb2wTHiYqOL0ihY3vbNY5VP3+9UR+SKv O1UMPfXsawPFlkIbZN0nGTJcxGRMxuntfg+Hzov4 PqGzwvz5s82aq/PT8ees8g9TjzGu9rHOfm+cEmkpcPuYmZ9f9xaQcA AAAAeBDpQMzMBrEnLIFkVUqWRrfRuLalRNrTJKON eNv5Y9IVvBYI3kpZRYs8RbaJyUKCPBjXET1GNlJT GW+e12AgTTfPazDcuxV+rxmRbec13u5xOqCpmDlp EdSxt62tpxIxAwAAAICdQPtilpQmaOkBSUoftB0n SXLCwpYodCnHShwXVymFXjdELEHmzDTFpOtOI03M 5sf7NBgYlClQpqilEDmO//+gl+zm+UH1jXdby3LqMUu6D4xDAwAAAIAdQvfEzB wPtCJ7j5lNpiyN9XzELKlnJl3MkvbLW8y89EJj/Nf8uJFyaPR8WbAeJzjW+LjG/XFmW+BliBkAAAAAQAZyFLNwQztbCmDLPWYpvV9t9 5glXoNSeszMy8q3xywiYx30mMWPYwpf9ycAQcwAA AAAAJqT43T54TFm9hkJzTFBNpnKPsasNTFLasRH9 zNlITpuLrSTiuYYszzFLCxRHY8x8/e19rx1v9csn8k/GGMGAAAAADubLs3K6De6w6IUSm1sdEjZet6yzsrY opjFyihLT0yWWRnj23QsZvPjEUHKPiujPz1+8Gba cfyp8iPH2Q6Tf3Q8K+NOXE8PAAAAAHYbHaUyRtYR SxKs8DguX4SCno+ksWrxGfuaz9yYNS0yOhFJUnqc kyAB5pT8oWPGD5R9HbPI+mK2tcrm6+PCou8ZYtbs OPPjyWucdYnurWNWUiUycQsAAAAAwINLW2IGnZOa yriDSBazzkkWewAAAACABwvErEcgZq0QX9Q7cfwf AAAAAMADCGLWIxCzFrEsXYCUAQAAAMBOATHrEYgZ AAAAAAAEIGY9Yu3ufX3y6Re9LkZX+eTTLxAzAAAA AIAMIGY9YnPzS9395PMdH5ubX/a6qgEAAAAAtj2IWRf4uLqmq2+9o9de/+mOjatvvaOPq2u9rmoAAAAAgB0BYtYFSFMEAAAAA IBWQMy6ABN7AAAAAABAKyBmXQAxAwAAAACAVuiam K2Ui3KKZW35SlMrZRVDCxFXSubCxN0HMZPqi0I7T v05qJSKYukxAAAAAIA4O0zMVlQubr2ImSBmvhCH7 3+lJMdBzAAAAAAAbCBmXQAxQ8wAAAAAAFqhAzELp ao5TkzCbGK2Ui42tnccNfwpSai814v11ry/Xfi89X2M8jglVWRPZayUnIRyyEuFdIoqV8oqhrYp RozCO1eS/8XE7OZ5Dfb1qa+vT319gzp/09hhftx/r099g+d107rfuObtp+sZdjGL36NiMXrfi9gZAAAA AECENsXMlyBzLJcvQ1JczDwpC/WYrHjiEzTSvfcb+ze2CfaxyJtxDNs2UTELpCF0nk opKmcrgZAZ19JCb09UzOY13tencd+qbp4fjErW/HiCdN3U+cHGfpofj0rbNoAeMwAAAACAfGhLzKwS5 ctaRLTqDfPoe9bj+EIU9a7QMSKSVt/CELEmYpYgBxGJsJQjqfxJxMUs1Et287wG6yJmyFe Ym+c1mLjf9gAxAwAAAADIhzbELHkcV1iCIlKV1Ch P7RFLkaGVaJphVjGzC6VRPqsAdiJm0vx4IxXx5vl B9TW6zzTYN6jBwb56KmNd0kwRM0VtG4CYAQAAAAD kQ/ti5iREopgl7dNorEfEKdaQN85bqqjVHrPECUm6LG aaH1ff+LjGTfmaH4+OOQunNcZSHI2et20AYgYAAA AAkA+59phFtsrSYxbfqZ5GmK1h34aYJfaYhVMqcx Qzs6crLGNW+fLFjR4zAAAAAIBdQ1tjzGKNbknmDI rx8WGWWQzDQhQ6hlMqxUTI2tsVpDTmPsYsRzFrKl 9h2Qr1ijHGDAAAAABg15DbrIxmb1TTWRlTJwRx4o 14c/bEcGpj/Tx5zcqYd4+Zmb4Ynfxj0Lev6IyNzMoIAAAAALBby G8dMyNFMMs6ZqkTe1jGgtn2N6fpb4xn8ySg+Tpmh ixkErMW1zELr1MWS0ecr489S39ve/WWSS2KWVike7wAOAAAAADAdqMDMYMkYmK2Q0kTMw AAAAAAyA5i1gUQMwAAAAAAaAXErAsgZgAAAAAA0A qIWRdAzAAAAAAAoBUQsy6wdve+Pvn0i14Xo6t88u kXiBkAAAAAQE4gZl1gc/NL3f3k8x0fm5tf9rqqAQAAAAB2BIgZAAAAAABAj0 HMAAAAAAAAegxiBgAAAAAA0GMQMwAAAAAAgB6DmA EAAAAAAPQYxAwAAAAAAKDHIGYAAAAAAAA9BjEDAA AAAADoMYgZAAAAAABAj0HMAAAAAAAAekzPxOzOf/nvevnnd/SDl36jf/OTVWKbxw9e+o1e/vkdfby+2atHBgAAAABgx9ITMfsPv97Q1Ox/7rlsEK3H1Ox/1jt//1978dgAAAAAAOxYtlzMfv2Pv6WX7AGPcy9+oP90+ 4utfnQAAAAAAHYsWy5mr751t+diQXQer751d6sfH QAAAACAHcuWi9n067d6LhVE5zH9+q2tfnQAAAAAA HYsWy5mvRYKIr8AAAAAAIB8QMwIxAwAAAAAoMcgZ gRiBgAAAADQYxCzJvGNr/epr69PfV//qw6O81f6al+f+vr26g/+7EEoL2IGAAAAALCV7GAxe0N/8LuepHxl5I1dKmb51AFiBgAAAADQXRCzLYmtE7Ot rAMAAAAAAMiH7S1mp/7Q6/2JRFhuAuFpxFdPee+dHNlr2fcP9Y1EaUo4R70Mf6 hvhLb96qmgd8p2zM7K/m/+7Dv6in/Or3698X5ErizH/8rIG5Hy/oG1DvbqKzZZC/b73e/oJGIGAAAAALClbF8xiwiRrdcp+H/wfqN3yBOcrL1Ff6WvhmXEPG+CmH3ld/cqUfZCYtVW2ev7m//397dI1MmRvTEx+0ZCHdSlNbR/kALZSs8aAAAAAADkw7YVs/jYrqjc1OUiNPYr+lq7aXyGRCWJWcoxOy57E7EL9w bWe9msYplUB81EETEDAAAAANhKtr2YNYQiKhPfCK X4xaJVMUtLO0xJZexa2RPFLDivLf3Sfy+TmBllDP ZpcYITAAAAAADIhwdWzGy9TtHIJmbxtL5sPWadiF nTsjcVM9u2/vEyill4u2AcW9o1IWYAAAAAAN1j24pZbByVOc7K/H9ov0BCskx1H9smaTxXC2LWcdmbiFl9PFla75e/b3IdNKSt1Uk/EDMAAAAAgHzZvmL2E2Nmxd/da5EZQy5i47/MlL8MszKa52lHzH5ipCu2WvYMYpZ4zYmTpsTrIHy cdqbTBwAAAACAfNjWYmZP2dvqtcB2cHRYpwAAAAA AkA/bWMyi09jbpngnOossqZ6IGQAAAABA99neYmbOPIi U5RjZ0zIRMwAAAACA7rLlYvb867e2gZQQncb067e 2+tEBAAAAANixbLmYvfzzOz2XCqLzePnnd7b60QE AAAAA2LFsuZj9+vZv9ecv/qbnYkG0H3/2bz/Qyq0vtvrRAQAAAADYsWy5mEnSO3//X3suF0T78fav7vfisQEAAAAA2LH0RMwk6eP1Tb38 8zv6wUv0nj0I8YOXfqOXf35HH69v9uqRAQAAAADY sfRMzAAAAAAAAMADMQMAAAAAAOgxiBkAAAAAAECP QcwAAAAAAAB6DGIGAAAAAADQYxAzAAAAAACAHoOY AQAAAAAA9BjEDAAAAAAAoMcgZgAAAAAAAD0GMQMA AAAAAOgxiBkAAAAAAECPQcwAAAAAAAB6TJ/6+tTn/QMAAAAAAAA94P8Hi706I9v5lLoAAAAASUVORK5CY II=[/img]
Old Mar 4, 2019 | 07:31 PM
Yourconfused
LMFAO That is a total WTF post there! hahahaha
maybe this is better
Old Mar 5, 2019 | 02:18 AM
Poppacapp's Avatar
Poppacapp
As long as you have the pertinent numbers to put into the calculator you should be able to get an accurate DA reading. I only worry about DA at the track so the airdensity site works great for me so far.
To Help with DA
