PDR icon dissappear on the screen
Old Mar 8, 2019 | 04:55 AM
Norway's Avatar
Norway
3rd Gear
Default PDR icon dissappear on the screen
Hi guys, I have a 2015 Z06 With the PDR. My problem is that the icon for the PDR are not present at the screen, so it appears that I don't have that feature. I do know that I have it. There has been some modifications to the system, I got a DAB+ radio module installed, apple carplay, also navigation map for europe, all original GM parts for the 2016 model.
Do you have any suggestions what it can be?
Thanx
Thomas from Norway
Old Mar 8, 2019 | 08:37 AM
Flame Red's Avatar
Flame Red
Dissappeared? Perhaps it moved to one of the other screens? Swipe right and left and see if it moved.
That being said, when I replaced my radio module, the PDR ICON was present but would not work. There is a vendor that can provide a properly programmed radio module so the PDR functions. Reference this thread. https://www.corvetteforum.com/forums/showpost.php?p=1598698089&postcount=247
But I am not sure if he can deal with a Euro radio.
Old Mar 8, 2019 | 09:23 AM
Jeff V.'s Avatar
Jeff V.
If you installed a 2016 module into a 2015 car, it's likely it has the wrong programming. I'd go back to whoever sold you the parts and ask them to try to make it right.
Old Mar 8, 2019 | 09:34 AM
Norway's Avatar
Norway
3rd Gear
Thanx guys, there’s no icon if i swipe left or right, it has just been removed. Maybe it’s an software version issue or a bad wireing. Im very thankful for your tips, Ill read them and give a update when checked them out. The problem with contacting the dealer, is that the car is now in Europe and the dealer in the US. Every component are GM original parts...
thanx
Old Mar 8, 2019 | 10:57 AM
Jeff V.'s Avatar
Jeff V.
I understand that they're GM parts. The problem is, GM does not endorse installing parts that were not specifically meant for your year and options. There is no GM process for installing 2016 parts into a 2015 car. So it has to be 'hacked' with workarounds and software tricks.
Whoever programmed your 2016 parts didn't use the correct files for the options your car has.
Try contacting infotainment.com. They might be able to help you.
Old Mar 8, 2019 | 05:00 PM
Matthewstorm's Avatar
Matthewstorm
thanx
It's not bad wiring. Your new module has not been programmed correctly. You need to go back to the seller and have him fix it.
Old Mar 9, 2019 | 07:38 AM
Flame Red's Avatar
Flame Red
Don't use infotainment.com - they don't know how to get your PDR to function. SMS Text Anthony Brush 1-919-995-9523. You can try calling him but often he does not answer. He does not answer emails. Text messages he responds to. You will need a new HMI and Radio module, but I don't know if he can deal with the Euro frequencies.
Old Mar 11, 2019 | 04:42 AM
Norway's Avatar
Norway
3rd Gear
Thanx for helpful info, good to know that the issue most likely can be solved With proper software progamming. Thanx, I really appreciate it :-)
Thomas
To PDR icon dissappear on the screen
