2017 GS won’t start
Old Apr 10, 2019 | 11:57 PM
Iceman2000's Avatar
Iceman2000
Awesome! Thanks, Laser....there are no pin numbers at the connector, but base on the wire color order I should be able to figure it out..
Old Apr 11, 2019 | 10:11 AM
Osman's Avatar
Osman
i had same symptoms when i put my engine back in... everything you are describing.. turned out i forgot one of big grounds that goes on driver side engine, right under headers... i had it tucked in with brake lines and just didn't see it..
Old Apr 11, 2019 | 02:59 PM
laserdude2215's Avatar
laserdude2215
Pinouts.
File Type: pdf
Old Apr 11, 2019 | 03:51 PM
Iceman2000's Avatar
Iceman2000
Thanks, because the sequence by color was not working at all. I also found a damaged L/F brake sensor, which I’m ordering from the dealership.
Old Apr 11, 2019 | 04:19 PM
laserdude2215
Once you get the GMLAN connected (the stuff shown in post #19), it should start.
Old Apr 12, 2019 | 11:29 AM
Iceman2000's Avatar
Iceman2000
Laser, where can I purchase the first schematic your sent?
Old Apr 12, 2019 | 01:27 PM
laserdude2215
Helm 2017 Service Info
Old Apr 12, 2019 | 05:47 PM
Iceman2000's Avatar
Iceman2000
Thanks! All connected but still no start...verifying continuity of all that soldering to insure no disconnects.
Old Apr 12, 2019 | 05:50 PM
Iceman2000's Avatar
Iceman2000
Helm wiring diagram is on-point and straight forward.
Old Apr 12, 2019 | 06:07 PM
laserdude2215
Try your scan tool.
Old Apr 12, 2019 | 06:24 PM
Iceman2000's Avatar
Iceman2000
U0073
U0100
U0101
Using truck for jump; no battery issue....
Old Apr 12, 2019 | 07:42 PM
laserdude2215
Those are GMLAN codes. Probably history codes from the cut harness. Clear the codes and check again.
Edit: I just noticed that there is another white wire.
EBCM Pin 20 connects to Power Steering Control Module Pin 5. Wire color is WH.
EBCM Pin 33 connects to Power Steering Control Module Pin 4. Wire color is L-BU/YE.
Maybe you have a couple of the white wires swapped around.
Old Apr 12, 2019 | 09:08 PM
  #33
Iceman2000's Avatar
Iceman2000
Cleaned the codes and now starts.... Laser you are the man. Thank You So Much!
Old Apr 12, 2019 | 09:30 PM
  #34
Iceman2000's Avatar
Iceman2000
I was so excited to hear that horsepower, I forgot to open the garage door for ventilation and now have to stop working.
