Stock 500 hp engine ?
Old Apr 15, 2019 | 09:06 PM
Johnp94's Avatar
Johnp94
Default Stock 500 hp engine ?
Someone I know bought a 1969 Corvette. It has a big block with an oil leak. Restoration builders recommend a LS engine. My question is what aluminum block engine has 500 hp stock if any. I don’t think one exist. Another question, how do you get over 500 HP without a super charger, pro charger ?
Old Apr 15, 2019 | 09:14 PM
Kingtal0n's Avatar
Kingtal0n
The cheapest way which is reliably daily drivable that I know of to have 500rwhp is using 2002-2006 Truck engines 4.8/5.3/6.0L and a turbocharger
WIth pump 93 and 15-18psi of boost any of those engines with untouched crank/rods/pistons and 150-300k miles will easily produce 500-600rwhp
If you up the ante and use E85 + more boost, some of the 5.3/6.0L versions (e.g. L33 and LQ4) Will support around 1000rwhp using original internals.
here is my favorite example:
Thats an OEM 6.0L engine with a cam/spring upgrade on E85, 25-30psi of boost iirc and 1000rwhp
Old Apr 15, 2019 | 09:19 PM
kc stingray's Avatar
kc stingray
ls7 505hp
kc stingray
ls7 , 505hp
Old Apr 15, 2019 | 09:49 PM
Johnp94's Avatar
Johnp94
The restorer mentioned aluminum block LS. So LS7 looks like the way to go. Where can I price this ? Thanks for info
Old Apr 15, 2019 | 10:34 PM
Kracka's Avatar
Kracka
Why not just fix the oil leak?
Old Apr 15, 2019 | 10:54 PM
cv67's Avatar
cv67
St. Jude Donor '05
Really? 500 is cake with a big block, not to mention very cost effective. Hope your friend has real deep pockets.
Old Apr 15, 2019 | 10:58 PM
UBNZO6D's Avatar
UBNZO6D
FYI. I have an over the counter LS3 in my 56 BelAir that has 525 HP on 91 gas...It's hooked up to a 4L70...Bought both on line for $9200.
Greg
Old Apr 15, 2019 | 11:09 PM
Bill Dearborn's Avatar
Bill Dearborn
It must not be a numbers matching car. Is your question about the aluminum block related to the LS engine or the old Big Block? The reason I ask is aluminum big blocks were sold over the counter and installed in C2 & C3 Corvettes and two 69 Corvettes were factory built with an aluminum big block. Finding a third would be interesting. Those old aluminum big blocks were factory rated at 430 Gross HP but were under rated. They were basically L88 engines with an aluminum block Vs an iron block. L88s were rumored to put out closer to 600 Gross HP in stock form. That level of Gross HP would probably give you something close to 500 Net HP.
If you are talking about an aluminum block LS engine the LS7 put out 505 Net HP right out of the factory. GM put 28,000+ in C6 Z06s from mid 2005 through mid 2013.
Bill
Old Apr 16, 2019 | 12:16 AM
Avanti's Avatar
Avanti
If you already have an LT1, for instance, the very, VERY cheapest way to get near 500hp without any issues whatsoever is to use the GM aftermarket engine hp formula instead of the one they use with production engines. Car magazines like Car Craft have published the "correction" and for a 460hp engine with simply the use of a calculator the horse-power becomes... VIOLA... 478! Now, I know it's still not quite 500, but still... look what it DIDN'T cost ya! (and, you just can't beat it for a "sleeper" mod--no one will know!)
Old Apr 16, 2019 | 12:29 PM
lakemg's Avatar
lakemg
If money is no issue: https://www.chevrolet.com/performanc...ines/lt376-535
Old Apr 16, 2019 | 01:07 PM
Zjoe6's Avatar
Zjoe6
LS7 but make sure to address the heads issue of valve train slop.
Old Apr 16, 2019 | 09:02 PM
Johnp94's Avatar
Johnp94
Car restorer said the big block has clearance issues and it has a oil leak. Recommends LS motor. My boss owns the Corvette. I’m not certain of the year yet but it is a C2. Thanks for the help. I’ll post an update.
Old Apr 16, 2019 | 10:04 PM
Johnp94's Avatar
Johnp94
Its a 1967
To Stock 500 hp engine ?
