Slight hesitation when maintaining speed
Thanks for any input. I'm supposed to pick it up tomorrow.
Bob
A big thank you to DTOM and Akcajunz for your very informative replies. I texted my service adviser this morning asking him to look into the TCC Shudder issue. I have 17,000 miles on my car. I also sent him screen shots of sites and this link, which I found to be invaluable. Here are the highlights.
1) To ensure TCC shudder is diagnosed correctly, drive the vehicle on a smooth road with transmission sump temperature between 122°F (50°C) – 158°F (70°C). Constant throttle input on a smooth grade is needed.
2) A shudder condition may also be a chuggle, surge or vibration condition. Use GDS 2 or the CH-51450 PicoScope to confirm that the concern is TCC shudder and not a tire/wheel vibration or a driveline vibration, for example.
3) If TCC shudder is present, a vibration peak will appear within +/- 2 Hz of the frequency listed in Bulletin #18-NA-355. (there is a chart displayed for this section)
https://www.midenginecorvetteforum.c...rvice-bulletin
Fluid Exchange
The TCC shudder condition is related to moisture content in the transmission fluid. The current fluid tends to be hydroscopic, or absorbs moisture, which increases the chance of TCC shudder. There are three different fluid exchange procedures to follow, depending on vehicle application, so that an acceptable concentration of the new HP fluid is achieved in the transmission.
The new Mobil 1 Synthetic LV ATF HP transmission fluid is now available to U.S. dealerships through your local GM Oil Distributor. The new Mobil 1 Synthetic LV ATF HP transmission fluid is available in quart bottles (GM Part Number 19417577) and, for a limited time, in 55-gallon drums (GM Part Number 19417904) in most locations. Drum production ended in January 2019. The GM part numbers are not on the product.
The Mobil 1 Synthetic LV ATF HP fluid and the required tool kit will be available to all Canadian dealerships by the end of March 2019. GM Part Numbers for 0.946 liter bottles will be provided at that time.
TIP: Mobil 1 Synthetic LV ATF HP transmission fluid is required for all 8-speed transmission repairs regardless of the repair being completed.
Quart bottles, which can be identified by a new blue banner across the front of the bottle (Fig. 12), will be limited to 20 cases/120 quarts per dealer per week during the initial launch of the new product. The new bottles also feature the HP license number J-62120 on the back label.
https://www.corvetteforum.com/forums...8-flush-2.html
A8 failure tracking thread:
https://www.corvetteforum.com/forums...-tracking.html
I just modded my Z06 and had it tuned out. It's for sale here:
https://www.corvetteforum.com/forums...-disabler.html
This is the reason I have become comfortable driving in "M" and using the paddle shifters. And from what I've experienced with MPG's...there is a very negligible difference in the MPG's from V4 to V8. I still see 25+ MPG's driving 80 on the interstate!
Bob
https://www.corvetteforum.com/forums...post1598646214
Having the triple flush done can't hurt, but if it doesn't solve the problem and they keep telling you it is normal, please give us a chance. The hesitation may very well be related to the throttle.
Soler Performance LLC
support@solerengineering.com
www.solerengineering.com
(251) 468-9786
