Another exhaust question
Old May 1, 2019 | 09:46 PM
42Chevy's Avatar
42Chevy
It's 5 o'clock Somewhere
St Jude Donor '13-'14-'15
Default Another exhaust question
I need some advice/input. I have a 2016 nonZ06, no NPP M7. I have never been in eco mode so afm means nothing to me. It is my understanding on a M7 thats the only time it works. It is also my understanding that the engine sound management on my dash does nothing since I dont have NPP. Here is the issue. I want the exhaust as loud as I can get it. I am convinced the afm valves are doing whatever they want even in the sport mode I usually drive in. There have been times my exhaust has been so quiet you can barely hear it and other times it sounds normal to me. So...i put on Borla ATAK axle back system. Now when it first fires up on cold start it sounds great but the longer I drive the quieter it gets to the point it is not much louder than stock. Is it possible the afm valves are closing? I know I cant pull the fuse without a cel but could i put spacers and longer bolts on the valves so if they try to adjust they wont make contact with the valve? The computer would not know they are not actually adjusting correct? There is nothing else in the exhaust system that could change the exhaust note other than the afm valves correct?Any help is appreciated.
Old May 5, 2019 | 03:49 PM
TNSQUIRE's Avatar
TNSQUIRE
Are you certain you don't have npp, because that sounds like what is happening.
Old May 6, 2019 | 10:38 AM
42Chevy's Avatar
42Chevy
Yes I am sure. I now have the Borla Atak axle back on it and it is noticeably quieter when I go from Reverse into first in the morning and the longer I drive the quieter it gets to the point it is not much louder than stock. I am going to get some longer bolts with spacers for the AFM so the actuator does not make contact with the valve. I will let everyone know if that makes a difference.
Old May 6, 2019 | 11:18 AM
Dado5's Avatar
Dado5
Yep, i have Borla atack on my GS, eliminated NPP. It is louder when i first start the car, but it gets quieter when driving. Bola attack is not much if at all louder than OEM NPP exhaust when fully open. Im kind a dissapointed..
Old May 6, 2019 | 01:40 PM
LuisZ51's Avatar
LuisZ51
The main noise reduction is probably going to come via the cats. Throw an off road x pipe on there and see.
Old May 6, 2019 | 02:09 PM
MerakiAutoworks's Avatar
MerakiAutoworks
Supporting Vendor
Time to get a Corsa midpipe to make it louder too lol
-Josh
Old May 6, 2019 | 03:47 PM
Dado5's Avatar
Dado5
I have Borla mid pipe
Old May 7, 2019 | 11:55 AM
phalse's Avatar
phalse
I don't get it. If you don't have npp then there are no valves on your exhaust for the car to open or close either way.
Old May 7, 2019 | 02:36 PM
42Chevy's Avatar
42Chevy
Yes, there are AFM valves in the exhaust that sit above the axle.
Here is what I did. I pulled the actuator off (3 8mm bolts on each side) and removed the actuator gear. (One torx screw on each side). Put it back together and it now sounds better with no check engine light.
Old May 7, 2019 | 04:38 PM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Hmm, those valves ONLY work in ECO mode in an M7! No need for them t do anything, they restrict the flow only in V4 mode so it reduces the "missing V8" sound!
If yours do anything someone messed with the computer, IMO.
Old May 7, 2019 | 04:49 PM
LuisZ51's Avatar
LuisZ51
What you did there has zero effect on the vehicles sound. And I bet if you put it in eco mode the check engine light will now come on after what you've done. Like already stated above, those valves only operate in eco mode in the M7.
Old May 7, 2019 | 06:07 PM
RonC7's Avatar
RonC7
I've read that the car starts up rich when cold to get the cats up to temp quickly. That makes the nice loud bark on initial startup. As the cats come up to temp and the air-fuel mixture goes back to normal everything quiets down a bit. This is independent of NPP or AFM.
Ron
Old May 7, 2019 | 06:22 PM
42Chevy's Avatar
42Chevy
I understand what you all are saying. This is what I have read as well but the car IS louder. It may be the actuators were working when they should not have been. At any rate my sound issue is fixed and I dont have a check engine light. I never drive in eco but even then I doubt the cel would come on because technically the system is still functioning and since there is no sensor on the flapper I dont see how the computer would know of an issue. But again since I dont drive in eco it is a non issue to me. I am just glad to have sound.
Old May 8, 2019 | 08:08 AM
jazvet's Avatar
jazvet
Veteran: Marine Corps
What do u guys think about cutouts if i could find someone who makes them for c7 ?
To Another exhaust question
