Vibration and rattle issue
Old May 8, 2019 | 08:55 PM
KnightmareCS's Avatar
KnightmareCS
Default Vibration and rattle issue
Hey peeps,
Posting this question for a friend. Car is a 2014 non-Z51 Stingray. +50k miles. Auto A6.
He's noticing intermittent vibration and rattling. The conditions are:
-happens at ~2500rpm
-happens with the car stopped
-happens during driving
-burning rubber smell also occurs
I've only experienced it once with the limited time I was with him the other day. I made it happen revving to 4-5k in park and it would violently rattle from the driver's footwell area when the revs drop to ~2500. It didn't happen again repeating the same thing.
My initial thought is something exhaust related is loose. We haven't had a chance to get the car in the air to check it out.
Just looking for some things to look for.
Old May 10, 2019 | 06:57 AM
69 L46 4 Speed's Avatar
69 L46 4 Speed
It sounds like it could be a bearing in the Torque Tube. I have a friend that had that happen to his 2014 a few months ago. It turned out that one of the bearings moved out of place.
Old Aug 13, 2019 | 06:49 PM
KnightmareCS
Just to update this, you were right, it was the bearing in the torque tube. We got it up on a lift and pulled an inspection cover, the bearing was just bouncing the fudge around...
Ended up replacing the whole tube.
To Vibration and rattle issue
