Engine braking
Old Jun 5, 2019 | 01:17 PM
MrHix's Avatar
MrHix
Default Engine braking
Hi,
Is there any way to increase the engine braking in a 2019 GS M7? When I lift off the gas, it feels more like an automatic transmission coasting and takes quite a while until the throttle closes.
Thanks,
MrHix
Old Jun 5, 2019 | 01:34 PM
RelentlessSecurity's Avatar
RelentlessSecurity
Originally Posted by MrHix
Hi,
Thanks,
MrHix
are you using rev match or no?
Old Jun 5, 2019 | 02:08 PM
gtam85's Avatar
gtam85
Shift down, blip the throttle (if rev match is off) and listen to that sweet engine brake
Old Jun 5, 2019 | 02:10 PM
RelentlessSecurity
This^. These gears are incredibly long. 2nd gear gets you to around 82mph before redline
Old Jun 5, 2019 | 06:21 PM
thrilled's Avatar
thrilled
Downshift will slow ya down.
Old Jun 5, 2019 | 07:14 PM
Elk's Avatar
Elk
Why do you want more engine braking? You have more control while applying the brake yourself.
Old Jun 5, 2019 | 07:15 PM
MrHix's Avatar
MrHix
I would just like the car to slow down a little more when I lift off the throttle. I don't think that rev matching does anything until you push in the clutch.
Thanks for the reply,
MrHix
Old Jun 6, 2019 | 02:40 AM
dial666's Avatar
dial666
same issue here on my m7, when i let off the gas the throttle seems to hang around 2k for 3-4 seconds and slowly drops. bad deal when you expect to let off the gas and slow down
Old Jun 6, 2019 | 11:34 AM
spinkick's Avatar
spinkick
Use your brakes. Engines arent meant for slowing down. Brake pads are cheaper wear parts too.
Old Jun 6, 2019 | 11:55 AM
MrHix's Avatar
MrHix
I would think there would be a way to electronically tell the throttle to close faster when you let up on the pedal.
Cheers,
MrHix
Old Jun 6, 2019 | 03:28 PM
Obe1 GS's Avatar
Obe1 GS
Are you using a ported TB? There's several posts stating a side effect of a PTH is less engine braking
Old Jun 6, 2019 | 04:07 PM
MrHix's Avatar
MrHix
Stock 2019 GS M7.
MrHix
Old Jun 6, 2019 | 11:45 PM
dial666's Avatar
dial666
stock for me too. i actually tried a ptb and it made the effect more noticeable
pretty sure that its an emission deal and can be tuned out
Old Jun 7, 2019 | 09:31 AM
MrHix's Avatar
MrHix
Thanks, good to know.
MrHix
Old Jun 7, 2019 | 12:34 PM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
The majority of the pitiful amount of engine braking these cars have is due to the dump truck clutch they have. When you have 60+ pounds of mass bolted to the back of the engine, it reacts very slow, especially when transitioning on and off the throttle. If you've ever driven a car with a light weight clutch, you immediately notice how quickly the car will rev and decel.
Old Jun 7, 2019 | 03:13 PM
Avanti's Avatar
Avanti
Down-shift further. If in 1st... forgetaboutit. Throttle is controlled for emissions control, etc It ain't the old days.
Old Jun 8, 2019 | 05:06 PM
rrepp's Avatar
rrepp
That doesn't sound right to me. When I back out of my throttle the engine backs off, and if I need to help with scrubbing of some speed I'll downshift. If I backed out of the throttle and engine didn't back off that would scare the sht out of me
Old Jun 12, 2019 | 09:52 AM
Zjoe6's Avatar
Zjoe6
Like others have mentioned maybe you’re in the wrong gear.
Old Jun 12, 2019 | 02:05 PM
dial666's Avatar
dial666
if you have nothing to contribute ,why bother posting . do you seriously think were just in the wrong gear or dont know what were talking about or know how to drive a manual
how many people that posted here and gave their advice/opinion actually have an m7
To Engine braking
