Aftermarket wheels
Old Jun 15, 2019 | 03:20 PM
ROCCON's Avatar
ROCCON
4th Gear
Default Aftermarket wheels
I have a 2017 Grandsport with 4 bent factory rims. I understand this is an inherent problem with factory GS and Z06 rims. That being said I do not want to replace with GM OEM. I have gloss black wheels and love the look. I found some reproduction ones but unfortunately they are not forged or DOT certified. I am being told to avoid these as they will fail under heavy load. Who here has had good luck with aftermarket wheels that may look similar to my factory ones ?
Old Jun 15, 2019 | 03:45 PM
tertiumquid's Avatar
tertiumquid
Call Khoa @ Deity Motorsports for Signature forged wheels. They are true forged and certified,
Old Jun 16, 2019 | 07:52 AM
Fredtoo's Avatar
Fredtoo
The DOT does not certify wheels, the manufacturer self certifies that wheels that are compliant.
Who is telling you that the wheels will fail under heavy load?
Old Jun 16, 2019 | 08:30 AM
tertiumquid
OP is probably reaching the conclusion that the wheels are a problem after reading or hearing of the multiple cracked wheel threads on the forum.
Old Jun 17, 2019 | 02:42 PM
redman76's Avatar
redman76
St. Jude Donor '09
Roccon, welcome to the forum. I just went through the same exercise due to bent/cracked wheels. There are a lot of choices out there. What's you budget? Wheels can get very expensive, especially in the GS/Z06 sizes. I track my car a couple of times a year, so decided to go with the BC Forged monoblocks from PK Auto Design; I felt they provide the best strength/cost. Worth a look IMO.
Old Jun 18, 2019 | 02:05 PM
PK Auto Design's Avatar
PK Auto Design
Supporting Vendor
I would be more then happy to help you out with any questions or concerns you may have.
We are assisting a lot of members here throughout the board on concerns and new products they require.
Paul A.
To Aftermarket wheels
