Alignment tools
I confess to knowing slightly more than nothing. Is anyone familiar with these tools and their cost?
First off, congrats on going to Nürburgring that's awesome! They are utilizing a Hub Stand setup albeit one that they can't set alignment specs with alone (will explain later). The Hub Stands are sitting on scales followed by leveling plates around the vehicle to ensure accurate weights and alignment measurements. The Hub Stands they are utilizing use leveling pads to support themselves. This works fine when cradled with turn plates and such but in a standalone scenario they won't be able to allow the wheel to rotate back and forth for the Caster measurement. Similarly if Camber is changed it'll attempt to push or pull the bottom of the Hub Stand (at the leveling feet) in or out as the angle changes which will cause potential binding. The same occurs with changing Toe as the leveling feet will need to "slide" on whatever surface they are sitting on to move and see the measurement change. If not, this will cause inaccurate measurements. My best guess is that they use the Hub Stand on turn plates and they simply make it easier to access the suspension components.
Our Hub Stands incorporate ball bearings on the bottom surface as well as pivot pins for camber (and caster) change to ensure there is no binding at all. Think of it as a Hub Stand, turn plate, and toe plate all rolled into one convenient package. I've attached some photos below.
Here is our new MK II Precision Hub Stands
Our Original Precision Hub Stands:
You can check us out @: https://csmperformance.com/home/
Thanks!
Colton @ CSM Performance LLC
