Brake Pedal Hard and Engine Won’t Start
Old Jul 17, 2019 | 12:20 AM
KCV's Avatar
KCV
Default Brake Pedal Hard and Engine Won’t Start
Intermittently on my 2018 A8 Stingray when I attempt to push the brake pedal and push the Start button to start the engine nothing happens. The brake pedal feels rock hard stuck and won’t push in at all. I get a dash message that says something like, Push Brake To Start Engine. After several attempts the brake pedal will eventually push in normally and the engine can be started with the Start button. This has happened several times. Any ideas what is wrong?
Old Jul 17, 2019 | 01:00 AM
The HACK's Avatar
The HACK
Brake vacuum boost leak.
Old Jul 17, 2019 | 08:23 AM
Mr. Jones's Avatar
Mr. Jones
I have a hard brake pedal on startup after the car has sat for days.
Never had a start issue, just push harder.
If this is abnormal and a booster leak I would like to hear from others.
Old Jun 16, 2021 | 07:05 PM
jbenderl's Avatar
jbenderl
I just had the vacuum pump replaced to address the hard pedal problem (happens overnight). Sadly, it did not solve the problem.
Old Jun 17, 2021 | 10:23 AM
ersatz928's Avatar
ersatz928
The brake booster unit has a vacuum leak.
Old Jun 19, 2021 | 08:10 PM
Avanti's Avatar
Avanti
My brake pedals on all my vacuum-assisted cars is hard before start. I've no idea, though, why your car is failing to start, but it's not the fault of the brakes. I'd start by cleaning the battery terminals/cable-ends and checking the battery (especially if more than 3-years old). Battery longevity is a total crap-shoot. All the best.
Old Jun 20, 2021 | 08:24 AM
Tinkertech's Avatar
Tinkertech
Check the brake switch is properly aligned and functioning correctly.
Old Jun 20, 2021 | 04:23 PM
Sailez51's Avatar
Sailez51
Definitely check brake switch . My M7 did the same and message to press clutch appeared . Dealer replaced clutch switch on warranty and problem was solved . Yours is obviously auto and break switch needs to be looked at .
To Brake Pedal Hard and Engine Won’t Start
