Oil level sensor
Old Jul 20, 2019 | 07:27 PM
billiardcue's Avatar
billiardcue
Default Oil level sensor
2015 Z51 - car recently worked on now each time the car is started a service warning appears 'low oil level' 'add oil'.
Clears with the select button on the steering wheel.
Where is the sensor? Could a wire be disconnected?
The oil level is correct.
Old Jul 20, 2019 | 07:44 PM
Kracka's Avatar
Kracka
Bring it back to the shop, that's not normal. Are you following the correct dry-sump procedure when checking the dipstick?
Old Jul 20, 2019 | 08:00 PM
billiardcue
The shop is a 4 hour drive each way, would rather fix it here.
Yes I know the correct procedure for checking the oil level.
Old Jul 20, 2019 | 08:20 PM
rrsperry's Avatar
rrsperry
Had no idea there even was an oil level sensor.
Old Jul 20, 2019 | 10:00 PM
Kracka's Avatar
Kracka
What did you have done? That might give us some clues as to what was touched.
Old Jul 20, 2019 | 11:10 PM
robert miller's Avatar
robert miller
Default ttt
Something is wrong I run my dry sump about 1/4 to 1/2 QT low and no light come on in the car... At least call that shop & tell them how you did your check on it & it is full but this light is coming on HAVE they had this to happen with any other customer that they have chged the oil on.. ARE maybe ask them what to check for from what they did are how the did the oil chg... Robert
Old Jul 22, 2019 | 08:02 PM
ersatz928's Avatar
ersatz928
Dry sump cars do not have an oil level sensor, only the wet sump cars do. I suspect that the wire that goes to where the sensor would be (on the side of the oil pan for a wet sump car) is shorting to ground, causing the "Low Oil Level" warning.
Old Jul 22, 2019 | 09:25 PM
laserdude2215's Avatar
laserdude2215
The sensor is inside the pan. There a short cable inside the pan to a connector on the passenger side of the pan. As indicated above, this is only applicable to a wet sump engine.
To Oil level sensor
