Need tech help
Old Jul 22, 2019 | 03:26 PM
Dsampson01's Avatar
Dsampson01
2nd Gear
Default Need tech help
Hello,
My 2015 C7 Stingray was blowing hot air only out of the vents so i took it to a local repair shop for diagnostics. They said they attempted to perform a software upgrade but it failed. They claimed I needed a new air conditioning control module and when they returned the car to me none of the climate controls were working and no air was blowing out at all.
I bought a new air conditioning control module and installed it but the lights still stay off and I can’t do any climate controls. The LCD screen and radio/media controls are working fine. We checked all the fuses and don’t see any bad fuses either.
Any help would be appreciated!
Thank you
Old Jul 22, 2019 | 03:40 PM
DTOM's Avatar
DTOM
C7 of Year Finalist (performance mods) 2019
Could it need a recharge?
Here is where the LP port is:
https://www.corvetteforum.com/forums...-location.html
Old Jul 22, 2019 | 04:00 PM
Dsampson01's Avatar
Dsampson01
2nd Gear
I ruled that out because I didn’t think that a recharge would make the entire air conditioning controls unusable.
Old Jul 22, 2019 | 05:35 PM
raylo's Avatar
raylo
Were the hvac controls functional before you took it to the shop but just blowing warm air? If so, they may have bricked the module and the new one might need to be programmed or something. But I don't know if there is anything special the module would need to be activated. And then you may still have a separate AC issue.
Old Jul 22, 2019 | 11:01 PM
snomuncher's Avatar
snomuncher
Default HVAC Module Replacement
From the 2015 Service Manual, when the HVAC control module is replaced, it needs to be recalibrated, with or without a scan tool.
The procedure without a scan tool:
Clear all DTCs
Ignition OFF
Install/connect the module
Connect all previously disconnected components
Remove the HVAC module fuse for a minimum of 10 seconds
Install the fuse
Start the vehicle
Wait 40 seconds for the HVAC control module to self- calibrate
Do not adjust any HVAC controls during this self-calibration process
Old Jul 23, 2019 | 05:32 PM
Avanti's Avatar
Avanti
Exactly why we LOVE this place!
To Need tech help
