Info screen jammed
Old Aug 12, 2019 | 01:56 PM
TN Bob's Avatar
TN Bob
1st Gear
Default Info screen jammed
I put something in the storage compartment behind infoscreen and therefore jammed the screen from going up or down. Small opening at the top (quarter inch). Any suggestions on manually opening? Ideas? Help!
Old Aug 12, 2019 | 04:23 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Well, you can turn the car upside down and shake it a little, otherwise, you get to see how the dash can come apart. Sorry, there is no really easy way to get in there to fix this.
If there is an opening, maybe a piece of 12 or 10 gauge wire can be bent on a 90° bend and you might be able to hook the item enough to release the bind.
Elmer
Old Aug 14, 2019 | 03:33 PM
Avanti's Avatar
Avanti
Yeah, a piece of coat-hanger would be my suggestion. You've discovered exactly why some of us forget the screen even moves. Good luck (and I hope what you put in the bin isn't critical).
Old Aug 17, 2019 | 09:34 PM
TNSQUIRE's Avatar
TNSQUIRE
Depending how jammed the item is you might be able to brake hard and cause the item to move.
Old Aug 18, 2019 | 05:45 PM
snomuncher's Avatar
snomuncher
Default Display Screen Jammed
A few ideas here:
https://www.corvetteforum.com/forums...come-down.html
To Info screen jammed
