Battery swap-computer crash
Old Aug 31, 2019 | 05:01 PM
williammease's Avatar
williammease
Default Battery swap-computer crash
I don't drive my 2015 Z06 enough and the battery went dead so after 4.5 years I felt it was time for a change. Bought the X2Power AGM and made the change myself. Did not hook up any trickle charge while making the change and followed Forum online instructions. Problem now is the dash and starter electrical system are not coming on. The green light appears on the starter switch but I can't get anything else to work including the car door locks. Do I need a computer reboot by the dealer, the A8 trans is locked in gear so I don't know how you tow this for repair!
Old Aug 31, 2019 | 05:57 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Check your connections. Make sure the connections are exactly as you took them off. Any misalignment might be cause for a voltage issue. Also, verify that you didn't blow the 350 amp fuse back at the battery.
Elmer
Old Sep 1, 2019 | 12:46 AM
TNSQUIRE's Avatar
TNSQUIRE
Make sure the thin wire (yellow arrow) didn't break.Name:  photo378.jpg
Old Sep 1, 2019 | 09:22 AM
williammease
I did have a spark while tightening the ground cable and the wrench contacted the middle positive bolt on the plastic fuse panel holding all the wires. Are there inline fuses and where do I look?
Old Sep 1, 2019 | 09:29 AM
eboggs_jkvl
Moderator emeritus
There is a 350 A fuse in the piece on top of the battery that doesn't like to have the + post grounded out. I'd start right there.
It sits right on the end of the big red positive cable. You can see it in post 3's picture.
Elmer
Old Sep 1, 2019 | 10:20 AM
24/Eray's Avatar
24/Eray
not sure i've come across any electrical system that "enjoys" being grounded out lol....
OP - 1/4" ratchet short handle... that's the move.
Or they even make a medium length battery change ratcheting wrench you could pick up for future issues
notice the rubber end... it happens. hopefully just the big fuse or a fusible link.
Old Sep 1, 2019 | 11:23 AM
TNSQUIRE's Avatar
TNSQUIRE
Yikes....most likely blown fuse in the 300 amp block on top of the positive battery post.
Old Sep 1, 2019 | 12:26 PM
Null Pointer's Avatar
Null Pointer
Exception ID 10T
If the 350amp fuse is blown, most likely this is what you will need.
GM Part 84314829 (for battery fuse block)
https://www.tascaparts.com/oem-parts...e-box-84314829
A less expensive solution is offered in this post.
https://www.corvetteforum.com/forums...post1600063034
Old Sep 1, 2019 | 03:11 PM
RonC7's Avatar
RonC7
Check all fuses on top of the battery. (1) 350 amp, (4) 100 amp - 2 unused.
Old Sep 13, 2019 | 11:36 AM
williammease
Hi guys, thanks for all your input. I had the 350 fuse block checked by a mechanic and he told me it was still sending power thru it. Bought a new battery fuse block anyway and after checking all the inline fuses, I reassembled everything and prepared myself for a tow to the dealer. Guess what, either the new fuse block or a loose wire fixed the issue. My guess is the fuse block was damaged but not a total loss.
To Battery swap-computer crash
