MGW flat stick question
I installed a new flat stick shifter today on my c7 grand sport, and its a great improvement. Coming from an S2000 I really missed that silky smooth transmission, and this is still nothing close, but for the amount of torque this transmission has to deal with, I think it feels pretty damn good! But I’ve run into two problems...
1. I can no longer engage reverse with the vehicle off, but when on, everything is fine. Is this an alignment issue? Is the linkage bolt not tight enough (I couldn’t get it any tighter without moving to an extension and I was afraid of stripping it then)? Is there some sort of assistance when engine is on vs off?
2. My check engine light came on. I ran the car without reconnecting parking break, performance management toggler, etc. just to test mechanism before putting everything back. Did this just throw a CEL and will it clear after a few cycles? Is there something else I’d need to do?
Again, thanks for the responses, cheers!
1. I can no longer engage reverse with the vehicle off, but when on, everything is fineI![/QUOTE]
The car has a reverse lock-out mechanism that (I believe) is active when the car is moving forward above a certain speed. Since new, my car has intermittently behaved as you describe. Don't know why, but sometimes when the car is off this blocking mechanism won't allow reverse selection. Since everything works properly when the engine is running, I don't worry about it.
