Question about hardwiring?
Old Oct 9, 2019 | 12:32 PM
acnburner194's Avatar
acnburner194
Default Question about hardwiring?
Hello,
So I am trying to hardwire a dash cam onto a constant fuse so that I can always have it enabled but was wondering if it's safe to just unscrew the screw for the ground and place the hardwire piece under it? Do I need to remove the battery or do anything before that?
Old Oct 9, 2019 | 02:04 PM
us3rname's Avatar
us3rname
I wouldn't remove it, just disconnect the negative terminal.
Old Oct 9, 2019 | 02:41 PM
acnburner194
Sorry but this may be a dumb question, but is this the negative terminal? If so can I just unscrew it to add the hardwire clip under? Do I need to remove the battery or do anything before unscrewing it with a wrench?
Old Oct 9, 2019 | 02:53 PM
us3rname's Avatar
us3rname
If you trace that wire back it will end at the negative terminal on your battery. If all you are doing is looking to add a ground wire it will work fine under that bolt and for that, I personal wouldn't worry about disconnecting anything from the battery. If needed, send me a PM with your number and I can walk you through it when I get off work.
Old Oct 9, 2019 | 03:14 PM
acnburner194
So I tried unscrewing the area where my finger is and it started to spark a bit when I unscrewed it to a certain point. Do you happen to know why? I pmed you my number as well.
Old Oct 9, 2019 | 03:23 PM
Maxpowers's Avatar
Maxpowers
Removing the main ground can cause some small sparking as there is current running through it. Why not just remove the fuse of the circuit your working in?
To Question about hardwiring?
