Dash cam parking mode vs always on
Old Oct 21, 2019 | 09:49 PM
acnburner194's Avatar
acnburner194
Default Dash cam parking mode vs always on
So I have hardwired my dash cam and it has the parking mode feature. I believe after five minutes of no activity it will start recording again and saving clips/images from a little before the motion is detected and some time after. My question is if I turned off parking mode and let the camera just record the whole time, will it kill my battery faster or does it consume the same amount of power as leaving it on parking mode?
Old Oct 21, 2019 | 11:07 PM
SimCar's Avatar
SimCar
NCM Lifetime Member
NCCC Lifetime Member
Parking mode saves power by avoiding card writes. It also saves space and saves you from sifting through tons of video should you need to find a file. In addition to recording on motion, the dashcam should also trigger recording if an impact is detected. If your camera is installed properly it should shut down at a voltage threshold that avoids killing your battery. The power savings from parking mode will vary from camera to camera. You can always test the runtime each way to determine the run time differences. I haven't found a good reason to turn off parking mode on my dashcam.
Old Oct 29, 2019 | 11:26 AM
patron1992's Avatar
patron1992
What dish cam are you using? I'm looking for suggestions on one that can handle the Florida heat and perform well.
Old Oct 29, 2019 | 04:41 PM
f1reb1rd's Avatar
f1reb1rd
i have a think cam but i have changed it to run 24/7 and yes it does a number on the battery. if i drive every third day its not a problem but if it sits longer then i keep a charger on it for safety reasons. the charger is just a plug and play so no lost time at all. for me if im curious then i can go back all night if need to see if something i wanted to look for
Old Oct 29, 2019 | 08:33 PM
SimCar's Avatar
SimCar
NCM Lifetime Member
Blackvue DR750S 2CH. In the summer it can overheat and shut down in direct sun.
To Dash cam parking mode vs always on
