Has someone dogged this car?
Old Dec 14, 2019 | 03:34 PM
Street Rat's Avatar
Street Rat
Default Has someone dogged this car?
I had my 2016's transmission oil and differential fluid changed by a shop. They said the transmission fluid looked good. The rear end fluid was black they said. The car only has 11,000 miles on it. Does this indicate that someone drove this car hard? Or is there a problem back there? I'm the 3rd owner.
Craig
Old Dec 14, 2019 | 04:08 PM
spoolin98's Avatar
spoolin98
That's normal, probably never changed after break in. GM doesn't require it to be changed but if you research it the gear oil is filthy from break in. Mine was black after 1500 miles.
Old Dec 14, 2019 | 04:10 PM
Street Rat's Avatar
Street Rat
That's great to know.
Thanks for the quick response.
Old Dec 14, 2019 | 04:14 PM
spoolin98's Avatar
spoolin98
No problem. You should be good to go for many miles now that you got all the break in material out. I did mine at 1500 miles and it was filthy, full of metal particles and really dark. Looked nothing like the fluid I put back in.
I plan on doing it again around 5000 miles and then that's it for awhile, unless I track the car at some point. Is yours manual or auto?
Old Dec 14, 2019 | 04:32 PM
Street Rat's Avatar
Street Rat
It's an automatic.
I'm not too happy with the way it shifts either. I'm taking it to my tuner in January to change the shift points.
I put a device into the service port. It keeps the car in eight cylinder mode at all times. That helped some but it should be better.
Old Dec 15, 2019 | 02:26 PM
Bill Dearborn's Avatar
Bill Dearborn
I wouldn't worry about it. The diff lubricant gets dark pretty fast. For normal street operation GM says to change it at 45K miles I believe. 95% of owners will follow what the OM says or not change it at all. Most diffs will survive lack of maintenance until they have over 120K miles.
Bill
Old Dec 16, 2019 | 07:51 AM
mityaz's Avatar
mityaz
diff fluid always comes out dark. You're fine
Old Dec 16, 2019 | 08:53 AM
JasonAndrew's Avatar
JasonAndrew
One would have to assume that all Corvettes at one time or another would be driven hard, especially after 2 other owners.
Old Dec 20, 2019 | 02:24 PM
427C62013A's Avatar
427C62013A
Changed my differential fluid at 12000 miles, it was dark too. Manual Transmission fluid looked new but the new fluid improved the shifting 1-2 which was rough when cold.
Old Dec 20, 2019 | 03:57 PM
robert miller's Avatar
robert miller
Default ttt
I agree I couldn't believe how bad it looked just after 7200 miles. Robert
Old Dec 21, 2019 | 10:40 AM
Elk's Avatar
Elk
Appearance has noting to do with the condition of the fluid.
Old Dec 24, 2019 | 10:13 PM
Higgs Boson's Avatar
Higgs Boson
diff fluid is nasty when it's brand new. I wouldn't expect an improvement after using it in a differential.
To Has someone dogged this car?
