DIC setup
Old Jan 1, 2020 | 12:27 PM
2ndvett01's Avatar
2ndvett01
Default DIC setup
2019 Stingray: Is there a way to set up the DIC to see what the actual gear the A8 is in?
Old Jan 1, 2020 | 02:30 PM
Jeff V.'s Avatar
Jeff V.
I don't have an A8, but I think you can only see the specific gear when you're in manual / paddle shift mode.
Old Jan 1, 2020 | 10:53 PM
laserdude2215's Avatar
laserdude2215
I have an A8. The gear indication is there all the time in all modes. In fact, I can't find a setting to stop it from being displayed.
Old Jan 2, 2020 | 05:10 PM
TNSQUIRE's Avatar
TNSQUIRE
Are you seeing then actual gear or just D for drive?
Old Jan 2, 2020 | 06:32 PM
C5_Tom's Avatar
C5_Tom
The actual gear displays with a small number just above and to the left of the D. It does this in all dash display modes on my 17 GS. It switches to a large number when in manual mode.
Old Jan 2, 2020 | 09:40 PM
sevinn's Avatar
sevinn
St. Jude Donor '14, '16
This might not be an option on stingrays, but all the GS and Z customer cars I tune have it and I'm a little jealous. I might take a chance and try flashing my cluster and see how it goes.
Old Jan 3, 2020 | 09:38 AM
2ndvett01's Avatar
2ndvett01
Default Thanks
I found them on the D.
Old Jan 11, 2020 | 02:16 PM
sevinn's Avatar
sevinn
Are you talking about the small gear number indicator inside the circle with D? If so what did you do to turn it on.
Old Jan 11, 2020 | 03:17 PM
2ndvett01's Avatar
2ndvett01
They’re always there. Upper left of circle
Old Dec 5, 2020 | 02:17 AM
VettVertGo's Avatar
VettVertGo
Gear shows (when in drive) on Stingrays as well. I have a 16 w/Z51 (though I doubt it makes a difference) and the current gear shows. Though I don't recall the setting, you can also view whether the engine is running in 8 or 4 cylinder mode.
To DIC setup
