Tuning packages
Old Jan 17, 2020 | 08:36 AM
AHC's Avatar
AHC
Default Tuning packages
Hello - Noticing postings where members are tuning out CAGS. Found a shop near me that can handle the deed. They would have to purchase a software access license for the vehicle (C7 2019 GS). One-time purchase that would only be good for only that shop’s access of my vehicle.
Question - Should I be looking at purchasing something else that will provide me direct access down the line (or other shops)? Perhaps when I know what I am doing a little better?
Old Jan 17, 2020 | 09:17 AM
-ZEEOHSIX-'s Avatar
-ZEEOHSIX-
I'm surprised there isn't a CAGS eliminator plug in that the Corvette has. Camaro's have it so, maybe it's interchangeable to a degree? I'd look into a skip shift eliminator before I'd tune my car just for that--especially if the shop says it's specific to them only.
edit: Looks like there is. I'd opt to go with this before committing to a shop.
https://www.westcoastcorvette.com/pr...06-grand-sport
Old Jan 17, 2020 | 10:00 AM
AHC's Avatar
AHC
Sorry - should have been more clear, my bad. Looking to not use the skip shift eliminator. I know it is an easy install, and have one. Just trying not to install it.
Old Jan 17, 2020 | 03:07 PM
sevinn's Avatar
sevinn
St. Jude Donor '14, '16
The tuning shop will be on the hook for $200 for licensing your vehicle, and then charge you on top whatever they want to actually make the change. It will be licensed to their individual hptuners interface and the licenses are not transferable.
You could purchase your own hptuners interface for $299 and an additional $200 in license fees and be able to make this change yourself fairly quickly (or have someone use your hptuners interface to make the change).
Old Jan 17, 2020 | 03:14 PM
AHC's Avatar
AHC
Thanks, that is what I was looking for - Enjoy the day!
Old Jan 17, 2020 | 03:50 PM
Mike@DiabloSport's Avatar
Mike@DiabloSport
Supporting Vendor
We offer simple to use handheld tuners that will accomplish this while also offering extra power, better throttle response, and adjustability for things like tire size, rev limit, and more.
The device will grow with you should you decide to mod down the road (supports custom tuning from our CMR tuning dealers) and covers tons of vehicles in one device.
Old Jan 17, 2020 | 05:42 PM
m3incorp's Avatar
m3incorp
I'm sure you are aware that the tune will void your warranty. If I was going to pay for a tune, I would have them also tune to extract the safest power available.
Old Jan 17, 2020 | 05:46 PM
Mike@DiabloSport
Supporting Vendor
If he uses one of our devices there is no such issue.
Old Jan 17, 2020 | 06:47 PM
AHC's Avatar
AHC
Thank you, I was looking into that aspect. Since I have only 1,800 miles on it so far - might change my mind and go with the plug thing in the trans. Appreciate your advice. On another topic - I installed the MGW shifter, a couple weekends ago. Interesting item - the OEM shifter would very occasionally slip out of 1st gear when the trans oil was cold. Very intermittently. With the new shifter, the problem seems to have gone away. Perhaps the alignment tool, and the tighter box is helping. Thanks again and enjoy the day.
Old Jan 17, 2020 | 07:03 PM
Kracka's Avatar
Kracka
Much like the suspension, most Corvettes that roll off the assembly line are in need of a shifter alignment as well. Luckily, it's a very easy procedure. Quality fluid helps as well.
I'll also vouch for the Diablo product; zero issues when it comes to warranty work.
Old Jan 18, 2020 | 11:56 AM
AHC's Avatar
AHC
Thanks for the information. I will be changing Transmission and Differential oil this week. Two questions (1) Do you have a "quality fluid" recommendation and (2) would you expand the factory suspension issue(s) a little?
Thanks again, and enjoy the day.
Old Jan 18, 2020 | 01:01 PM
Kracka's Avatar
Kracka
Redline ATF D4 is the proper synthetic fluid for our 7-speed manual transmission.
The factory alignments are "good enough" but not even close to being perfect. It's worth it to have checked under warranty.
Old Jan 18, 2020 | 01:14 PM
Kracka's Avatar
Kracka
Related links:
https://www.corvetteforum.com/forums...d-service.html
https://www.corvetteforum.com/forums...7-shifter.html
Old Jan 18, 2020 | 01:32 PM
AHC's Avatar
AHC
Great Information! Thanks, very helpful. Enjoy the day.
Old Jan 18, 2020 | 06:20 PM
Dcasole's Avatar
Dcasole
I can also vouch for the Diablo and warranty work ...
Davev
Old Jan 18, 2020 | 06:23 PM
Dcasole's Avatar
Dcasole
You are changing the trans and diff fluids with only 1,800 miles on the car ?
Dave
Old Jan 18, 2020 | 07:24 PM
AHC's Avatar
AHC
I know it seems early. Hesitate to mention that I'll be changing the engine oil for the second time as well (dealership did it at 450). Thoughts are oil is inexpensive, can't hurt, and is better than watching TV. Off recommended maintenance cycle - shouldn't be any hassle doing it myself.
Also, if there are any shavings attached to the plug - that's an early warning indication. Perhaps necessitating a trip to the dealership, putting them on notice.
Here's a question - Guess the warrant is 3 yr/36,000 mi basic, 5 yr/60,000 mi powertrain. Is there a period with the C7 (e.g., first 15,000 miles), where the majority drivetrain issues occur? Thinking of when I am going to put the warranty behind me, and really get to work.
To Tuning packages
Old Jan 18, 2020 | 07:38 PM
Dcasole's Avatar
Dcasole
Changing the fluids early is really a waste of time , follow the schedule and u will be fine ... stop worrying and drive it .
As far as warranty is concerned , u will never put issues behind u , my motor dropped a valve at 34,000 you can imagine the ensuing carnage
Stop worrying about it and drive it like you stole it ...
That's what it is built for
Dave
Old Jan 18, 2020 | 10:03 PM
Kracka's Avatar
Kracka
Dave
...and we'll worth it. The factory transmission fluid is garbage and changing out the fluid flushes the break-in debris.
Old Jan 20, 2020 | 12:44 AM
poughkeepsie's Avatar
poughkeepsie
Is there any proof or a guarantee of this?
