2015 oil pressure sensor
Old Feb 4, 2020 | 12:54 PM
Rhettvette's Avatar
Rhettvette
Default 2015 oil pressure sensor
Hi, When I start the engine the oil pressure goes to around 80 after a while it drops to anywhere from 35 to 43. The computer says to add oil but it is to proper fill. I was told it was a faulty sensor. Does that sound right? If so does anyone know what the Approx, cost to replace?
was this a common problem with the C7's. Thank you
Old Feb 9, 2020 | 10:13 AM
Red86Cfour's Avatar
Red86Cfour
I haven't seen where this is a common problem. Do you have a dry sump tank, or the base without DS? There is a five minute wait period after shutdown for when to check the dry sump tank level.
