Hyperflash tail light C7
Old Mar 12, 2020 | 01:42 PM
RickHuntz's Avatar
RickHuntz
Default Hyperflash tail light C7
My left taillight signal indicator is hyperflashing. All bulbs are working and the right one works as it should. Is there a turn signal flasher somewhere? I thought maybe I would change it out but I can't find it. Where is it? Thanks in advance for any help that you can be.
Old Mar 12, 2020 | 02:57 PM
RonC7's Avatar
RonC7
No separate flasher module. I believe the BCM does the flashing and driver door speaker makes the clicking noise.
Old Mar 12, 2020 | 03:00 PM
RickHuntz's Avatar
RickHuntz
That's what I was afraid of. Thanks for answering
Old Mar 12, 2020 | 09:53 PM
KemahGT's Avatar
KemahGT
If the BCM does in fact control flashing I would disconnect the battery for a few minutes. A reboot couldn’t hurt.
Old Mar 13, 2020 | 12:08 AM
RonC7's Avatar
RonC7
True, can't hurt to disconnect the negative battery cable for a half hour. Lower the windows first to make sure you can get into the car. Also make sure the metal key in your fob will open the hatch. You will probably need to reindex (reprogram) the windows.
Ron
Old Mar 14, 2020 | 07:49 PM
RickHuntz's Avatar
RickHuntz
Thanks everyone. I tried everything that was suggested. I dropped it off at my dealer today and they said they will get it fixed. They thought it may be a loose or pinched wire, but we'll see what it really is once they have time to look at it.
Old Mar 15, 2020 | 09:49 PM
KemahGT's Avatar
KemahGT
Good luck. Let us know what the fix is.
Old Mar 20, 2020 | 02:49 AM
Bill Dearborn's Avatar
Bill Dearborn
Usually if a light stops illuminating you will get a warning light on the IP and a message in the DIC. I had my LED turn signal in the passenger side headlight stop working last year. That required replacing the headlight assembly since the turn signal and DRL are integral to the module. Not a cheap price to get it repaired. GMEPP was charged $1839 for the repair. Of course the headlight module was more than 50% of that price.
Bill
Old Sep 19, 2020 | 01:57 AM
Ray Hemsher's Avatar
Ray Hemsher
Cruising
Bill
Expensive turn signal bulb replacement!...my right signal blinks normal three times the the console shows bulb out and hyper flashes the right signals front & back ... ALL lights working just fine! ... I think for $1839 I'll ignore for as long as I can since out of warranty!!!
Unless someone has a fix for this recurring problem OTHER than changing out the entire WORKING headlamp assembly. I would be be willing to alter the software so the damn thing just flashes normal, since ALL lamps are actually lighted .... obviously the diagnostics are seeing a voltage/amperage that is out of the normal range GM designed for.
Last edited by Ray Hemsher; Sep 19, 2020 at 02:07 AM. Reason: addition of last paragraph
Old Sep 19, 2020 | 02:09 AM
Ray Hemsher
Cruising
What was the fix? {regarding thread #6 by RickHuntz .... tail light hyper flash}
Last edited by Ray Hemsher; Sep 19, 2020 at 02:22 AM. Reason: add to indicate what thread Im addressing
To Hyperflash tail light C7
