Z07 brake job
Old May 16, 2020 | 10:28 AM
Sloblk8's Avatar
Sloblk8
Default Z07 brake job
I've looked but didn't see anything definitive for my specific question on doing a brake job on a Z07 car and that is, do you have to compress the pistons? One thread here I saw a guy say he did not compress but then a few posts later he said he has a piston spreader and that it was invaluable. A video I saw showed a Ron Fellows car getting a pad change and they looked like they just slid the pads in no problem. Just making sure if I need to get a specific tool or not, don't want to get stranded in the middle of the job so to speak. Thanks.
Old May 16, 2020 | 11:42 AM
Basil2000's Avatar
Basil2000
I just used my finger to push pad back. After you remove the old pads you could put 1 of the old pads on and use that to push piston back. Very easy. You won’t have a problem with it. The hardest part of the job is replacing the wear sensors.
Old May 16, 2020 | 12:16 PM
Sloblk8's Avatar
Sloblk8
Awesome, thanks. Good to know.
Why are the sensors a pain to replace?
Old May 16, 2020 | 01:14 PM
Basil2000's Avatar
Basil2000
One side is hard to reach. I used needle nose pliers to pull them out. Also where they connect to pad I had difficulty putting them on correctly. 2nd time I did this it was easier.
Old May 16, 2020 | 01:18 PM
Ratboy's Avatar
Ratboy
One thing I've picked up over the years is anytime you push the pistons back in, you should crack the bleeders open to avoid pushing any contaminants and old fluid back through the system. Wasn't such a big deal before ABS, but modern systems are more susceptible to this issue, plus there is a hell of a lot more volume with these big calipers!
Old May 16, 2020 | 01:50 PM
Sloblk8's Avatar
Sloblk8
Thanks guys, I appreciate it.
Old May 17, 2020 | 01:31 AM
Bill Dearborn's Avatar
Bill Dearborn
I push the pistons back in but don't open the bleeders. There can be quite a bit of pressure on the pads and pulling them out may be difficult. Just pushing them back a couple of millimeters will make it much easier to get them out. Before the pads can be removed you also have to punch out the caliper pins, remove the caliper cross bolt and remove the pad springs that hold the pads in place.
Hardest part of job is releasing the wear sensors from the connector on the cradle. The connector is hard to reach and partially wrapped into a harness so you have to reach in the length of your arm through the wheel well or reach the connector from under the car either way there is only sufficient room for one small hand. Luckily, only the inner pads at each wheel have the sensors so you only have 4 of them to play with. Other than the connectors and running the replacement wear sensor harnesses along the control arm it is like any other brake job.
Bill
Old May 18, 2020 | 05:15 PM
Dr.Ron's Avatar
Dr.Ron
From: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
When I had my 2011 Carbon Edition C6Z and I changed the brake pads, I remember just leaving the wear sensors off and didn't have any lights or issues.
Is that not possible with the C7Z?
Ron
Old May 18, 2020 | 05:26 PM
Basil2000's Avatar
Basil2000
I believe you can disconnect the connection to the pads and zip tie the wire up and you can run without getting a “ brake worn” message.
Old May 19, 2020 | 12:22 AM
Avanti's Avatar
Avanti
They have to be pushed back to make room for the extra thickness of the replacement pads... somehow. I've found about every different brake system requires a different technique and/or tool. Do what the others recommend who have done ones like yours, and don't put too much stock in videos not specifically geared toward teaching how to do precisely what you are interested in learning. All the best.
Old May 27, 2020 | 04:35 PM
RJ-19's Avatar
RJ-19
I just did my first pad change (fronts) a couple weeks ago on my '15 Z07 and I could not believe how easy it was. Brembos, where have you been all my life?!? Literally under 30 minutes including watching a YouTube video, jacking, wheel removal, pad swaps, wheels back on and torqued. I could easily push the pistons in with my fingers. The hardest part is that you push one in and another pops out. I eventually figured that pushing s-l-o-w-l-y was the best solution.
As a track guy, I would buy this car again just for the ease of brake swaps. The previous owner had the wear sensors disconnected from the pads and zip tied back as others have mentioned. I don't need a sensor to tell me when the brakes are worn so I just left the old ones right where they were.
Now when I can get the whole brake assembly with quick disconnect including the calipers and rotors like Corvette Racing... that will be the ultimate brake package. (Of course I'll have to make a lot more money to be tossing out calipers and carbon rotors at each brake change.)
Old May 29, 2020 | 06:26 PM
Sloblk8's Avatar
Sloblk8
Good to know, I'll be doing this very soon.
To Z07 brake job
