2016 C7 Z06 crankshaft sensor
Old Jun 9, 2020 | 11:21 PM
ChrisCorvette06's Avatar
ChrisCorvette06
4th Gear
Default 2016 C7 Z06 crankshaft sensor
Hello, i recently got a check engine code p0335 which is for a crankshaft position sensor. What happened was car was idling fine for about 30 minutes and then it revved up and died. I turned it back on and it died again then i started it again and gave it a little gas and it stayed on but showed the check engine light, rpms weren’t showing and stabilitrak light is one. So i ordered an oem crankshaft position sensor and replaced it and car turned on and i had to help it with a little gas pedal on the first startup but after it turned on fine. The problem is that it still has the code, stabilitrack light, and still not showing rpm’s. Do is it need a relearn? Or could something else be wrong? Car has headers, intake, ported blower and smaller pulley, 103 tb, and meth if that matters.
