Catch Can
Old Jun 12, 2020 | 08:48 PM
Kazman1960's Avatar
Kazman1960
Default Catch Can
In high HP car , how much fluid would be expected to be collected over say 15,000 miles of driving ?
Old Jun 13, 2020 | 09:22 AM
Clifftrail's Avatar
Clifftrail
Tough answer, not every car and catch can setup perform the same.
Old Jun 13, 2020 | 03:29 PM
Dcasole's Avatar
Dcasole
Depends on how much blow by you have... is it NA? is it Blown ....?
Dave
Old Jun 13, 2020 | 03:30 PM
Dcasole's Avatar
Dcasole
And let the debate begin ... 4 3 2 and 1 .... go
Old Jun 13, 2020 | 08:33 PM
Avanti's Avatar
Avanti
As noted, there are too many variables to give a legit estimate. It depends on things like what "high hp" means, how it is achieved, condition/clearances of internal parts, how the car is used/driven. Sorry, no easy answer to this one...
Old Jun 13, 2020 | 11:20 PM
Kazman1960's Avatar
Kazman1960
Car is not daily driven . Blown Pro Charger F1A-94 , 2015 Z06 . , Meth , long tubes . I do drive it hard when im out playing with bikes , other than that , car has a very easy life .
Old Jun 14, 2020 | 08:56 AM
Jjagg0125's Avatar
Jjagg0125
interested in the same info
Old Jul 28, 2020 | 04:58 PM
V8!'s Avatar
V8!
My Z is stock and this was after after 36 miles, mind you most of it was just moisture. Now with the heat I don't get the water, just the oil.
Old Jul 28, 2020 | 10:44 PM
LT4CMG's Avatar
LT4CMG
https://youtu.be/svgXyncM1vE
Ok, so now I know those were your uploads I watched a couple nights ago. I'm looking at ordering a Mighty Mouse for my 19 Z06. Seems like a royal PITA to install. Thanks for the video, but if you have any other tips on installation, please let me know
Old Jul 29, 2020 | 12:09 AM
V8!'s Avatar
V8!
All Catch Cans are kind of a PITA to install on the LT4 as you have to lift the blower LOL The Mighty Mouse is a great set up. I have a great video on my site about how to lift the blower so you can reference that if you need to. Its very well done (I'm a bit biased LOL) if you go to my channel main page and scroll down its in the "custom modification" section.
The only thing I would do is I would not cut into your factory lines. So for the Mighty Mouse system when you run the line to the throttle body. Get a quick connector and it makes the installation really easy, very clean looking, and really easy to put back to stock as no hose is damaged.
Old Jul 30, 2020 | 03:32 PM
KemahGT's Avatar
KemahGT
I drain my MightyMouse Wild every oil change (7500 miles) and just a couple of ounces come out. I’m blown with a built motor and run it hard quite a bit. No road racing and little 1/4 mile. It’s also mostly water.
Old Jul 30, 2020 | 05:09 PM
DTOM's Avatar
DTOM
C7 of Year Finalist (performance mods) 2019
What's the procedure to drain Might Mouse catch cans? They have a hose at the bottom whereas the other ones unscrew.
Old Jul 30, 2020 | 05:14 PM
Jjagg0125's Avatar
Jjagg0125
Yea pretty much, very easy to drain.
Old Jul 31, 2020 | 08:49 AM
Kazman1960's Avatar
Kazman1960
Thanks for the replies and Video . I guess i need to remember to check / drain the can a little more often .
Kind of embarrassed to say this but i had about 200 ml of fluid come out .
Lucky i guess for me the catch can is of decent enough size to hold this amount .
You can bet now I'm checking / draining it at least once a month now .
Just drained it last night after approx. another 1,000 km,s of driving , just 3 small drips came out this time .
To Catch Can
