Thinking about the ARH mid length headers for my C7 Z51. I am leaning towards these because I would be able to run the factory tune for now to retain my warranty and also these would bolt up to my factory X-pipe to keep the system at a reasonable volume.
Whats everyones opinion of these? I have watched a few videos and they sound great compared to the factory manifolds. I know long tubes will make slightly more power but they are also much louder than I would want it.
first year i used the high flow cats, bolted up to a corsa x pipe, untuned for a year. no check engine lights
I also threw my oem x pipe on the arh mids for a month and sounded great.
the following year I bought the catless connecting pipes for the headers, added a blower, and corsa extremes.
I really like the sound of the mids, I do have some corsa headers that im curious to see how they sound. The mids are fairly expensive but arh makes some good quality stuff bolts on very nicely.
me and two of my friends installed the mids on jackstands in 3 hours. very easy install!
so far in terms of build/weld quality the arh mids outshine the corsa headers all day long.
Reason: adding install time
I've had them on both of my C7's and I think they are great. I live in the city and Long Tubes would just be ungodly loud with my setup. I currently have the ARH Mids catted, with catless Borla X pipe. This allows them to be quite loud if I drive it hard but sounds great driving normal. I can still put it in Tour Mode and have it whisper quiet on the highway without a hint of drone.
If you keep the factory X pipe with secondary cats, they will sound like stock everywhere except full throttle. You will notice a better and louder noise at WOT. I think the best setup for mids is a catless X pipe. It can be pretty loud if you want it to be and also pretty quiet. But it won't be crazy loud like Long Tubes can be.
Yep, Build quality is supposed to be the best. I will be installing this on jack stands also. I think it should sound much better than the OEM manifolds without making it too loud.
Thats what I’m afraid of with going with long tubes. I just don’t want the car that loud. I want it to sound better when I get on it than the OEM manifolds. Unsure if I will go with a cat less x pipe yet. I also think the mids should fit perfect and be an easy install.
So just another view , Mids with no tune really do not have much of a power gain on a stock LT1
I have long tubes with high flow cats and NPP mufflers .. and my car is no louder under normal driving conditions than my stock setup , no drone no crazy loud at normal throttle as a matter of fact I usually leave the NPP in the open position most of the time and only close it if I am leaving the house real early in the AM to keep my neighbors happy
Now wide open throttle , that's a different story but isn't that what we want ?
No tune is needed just get the 90 Degree O2 sensors adapters for the rear O2 and you will not have any CEL
I do realize that you will gain more with tuning. I like the fact that with mids I can run it without a tune without any issue and tune later to get more power. I know I’d be leaving some HP on the table but I plan on supercharging it anyway. I’m more interested in better sound and not making it crazy loud.
You are missing the point , you don't need to tune with the long tubes either, if u are going to go thru all that work u might as well just do long tubes especially since u plan on supercharging ...
No matter if you do mids or long you should tune but i get it
And I don't know where u are getting this idea that long tubes are so much louder that Mids . On a stock LT , If u keep the cats they are not much louder .... i have heard them both
You can always keep the factory X pipe and change it later if you want more volume. If you're willing to tune the car you can pick up a bit of power with the Mids. But even untuned you will get a little more kick. Long tubes vs Mids tune for tune is about a 8-10hp/tq difference.
If you install Long Tubes without a tune you will change the drivability behavior of the car. It will feel kind of sloppy and weak at part throttle at times. The ONLY way around this is to tune the car properly. This is much less of an issue if untuned with Mids. So its a trade off of what you really want. Less volume, no tune, and no drive-ability changes means Mids are likely the right choice.
good luck with what ever ur choice is!
Dave
Considering he wants to retain the secondary cats I am interpreting this as he is far more sensitive to increased sound vs you or I. I'm used to loud cars and love it but I feel like the OP, with just mids and stock X pipe, would be pushing his comfort zone. Hence my advice. Truly there is no one right choice, just our opinions and then the OP needs to make the best choice that he/she feels comfortable with.
Also mids vs LT's at part throttle and full throttle is def a sound difference. It's not a huge one, but there is still a difference, particularly in Track Mode.
I was looking at some old notes and time slips and I ran the stock exhaust all the way down to 10.00s@139 and then the ring lands took a ****. Didn't run long tubes till we built a new forged short block that winter and got a good deal on some long tubes so decided to change them out with aftermarket cats which clogged up and almost caused a motor failure, cut them mothers off at the Fest and went a couple rounds with those big band clamps holding the exhaust together till I could get home to get everything welded up. No aftermarket cats for me, ever.
Hey guys. How about the ARH catless mid length headers on a stock Z06? I’ve tried posting to one of Higgs FS posts, since he had and sold his, but haven’t received a reply.
I have an opportunity to buy a used set. I don’t want to change the Factory tune for a couple more years, but I wouldn’t mind a little more of a radical sound and a few hp. I only have an Attack Blue air filter and mix a little Torco in with each tank of 92 at this time. I’ll get them Jet Hot coated, if I purchase them.
I installed the ARH catted midlength headers on my C7 Z51in about a year ago along with a catless x pipe. I have a very detailed self-compiled (from a ton of research) guide for install if you need it. The whole install took right at 8 hours for me. I've got lots of car wrenching experience but had no specific corvette experience prior. I love the sound -- and if you check my post history you'll see my initial thoughts on the headers. They are as loud as any street car should reasonably be -- and despite what others say, the mids are no louder/quieter than the full-length headers. The ONLY difference in volume between headers is the inclusion/exclusion of cats. I confirmed with ARH and others on the subject before buying -- there is no volume difference unless you opt for NO cats. There IS a slight difference in tone, but it's not significant, and not describable (as everyone has a different ear and definition of words like 'deep', 'throaty', etc). Definitely recommend going with ARH! No issues with CEL.
EDIT: I should also note that since last year I've put 15k miles on my car -- its my daily driver and therefore I can say that i've got experience with these headers.
Who asked for anyone's opinion on long-tube headers? The op clearly said mid-length headers in his subject.
Relax .... because we were trying providing information that if noise and a tune were the only reason the OP wanted to go with MIDs , as he mentions in his orginal post ... he could use longs as they all sound the same and plenty of people are running longs with no tune ..... in the end its his choice based on what he reads right ...
That's what we are all here for right , answer questions and provide insight from real world users ......
