****Problem Please Help*****
Old Jul 16, 2020 | 11:16 AM
vicq's Avatar
vicq
Default ****Problem Please Help*****
So Im have a problem no sure what to do here
im running the 19x12 with toyo 345/30/19
and fronts 19x10 295 30 19
im have fantom check engine light coming on with service rear diff message
No codes for the check engine light and it comes on at wot then turns off after wards
im supper confused and not sure what to do to fix it
Help Please?
Old Jul 16, 2020 | 11:22 AM
Creatre's Avatar
Creatre
How many miles? What mods do you have?
I would start with new rear diff fluid if you haven't done it recently or ever. They are filled low from the factory and fluid looks gross.
Old Jul 16, 2020 | 11:31 AM
vicq's Avatar
vicq
30k miles currently
long tube header cat deleted x pipe
afe intake
race fuel tune and pump gas tune
supercharger pulley kit
plugs and wires
catch can
dash logic obd monitors for wide band gauges
wheels and tires thats it i think
diff fluid changed at 27k
Old Jul 16, 2020 | 11:39 AM
mityaz's Avatar
mityaz
im thinking a battery issue first. Your voltage may be dropping during a pull.
Second. see what your R/F tire diameter ratio is. If too far form 1.03 then you may be messing with the stability control systems (although it would usually flash the sliding car light)
Old Jul 16, 2020 | 11:44 AM
vicq's Avatar
vicq
yeah it wont flash that one and i cant turn that one off or on with dial
Old Jul 16, 2020 | 11:45 AM
vicq's Avatar
vicq
what tire change would i need to make to make it right in specs
Old Jul 16, 2020 | 11:48 AM
vicq's Avatar
vicq
only thing that the dial will turn off now is tc
Old Jul 16, 2020 | 11:52 AM
vicq's Avatar
vicq
im wondering if its battery related also
battery says its at 12.5 or more so maybe intermediate bad cell in it
would i need to change the front to 285/35r19 and would that cause a rubbing issues at stock height on the bolts
Old Jul 16, 2020 | 12:17 PM
Internets_Ninja's Avatar
Internets_Ninja
You potentially need to have the car tuned for the different tire sizes. If the height difference is too far off the car will think there is a problem with the differential. This is probably what is happening. You need to measure your tire height/diameter/circumference and have the tune updated with the new values.
Old Jul 16, 2020 | 12:20 PM
vicq's Avatar
vicq
thats was another thought that i had and i mention to my speed shop who has the car and they said that the tuner says it wouldn't help the situation which i felt he was wrong on that
have you done this and know that it will work on this type of issue?
Old Jul 16, 2020 | 01:36 PM
Internets_Ninja
If you change the tire height ratio between the front and rear too much you will have to tune the car to avoid service rear axle warning but also its a good idea to update the speedometer as well.
See this thread for more info: https://www.corvetteforum.com/forums...lp-please.html
Old Jul 16, 2020 | 01:52 PM
vicq's Avatar
vicq
so correct me if im wrong here but
it go to 285/35/19 front instead of my current 295/3019
stay with 345/30r19 rears that would be acceptable to the car ???
Old Jul 16, 2020 | 02:25 PM
Creatre's Avatar
Creatre
295/30/19 combined with 345/30/19 is perfectly acceptable. Very common tire sizes. Stock tire ratio is 1.035% and this combo is 1.04%. If those are your sizes, that is not your problem.
Old Jul 16, 2020 | 02:30 PM
vicq's Avatar
vicq
that helps thank god lol thought i messed up
these are copy and pasted from my tire rack order confirmation
345/30R-19 TOYO PROXES R888R SL
295/30ZR-19 TOYO PROXES R888R XL
Old Jul 16, 2020 | 02:33 PM
vicq's Avatar
vicq
with those tire sizes would it be tuning that needs to done with it
Old Jul 16, 2020 | 02:42 PM
rodomotive's Avatar
rodomotive
Stock Z06 front tires are 25.8" dia and rears are 26.6" dia, a difference of .8" Your 295's are 26" dia and the 345's are 27.2" dia a difference of 1.2". The threshold or maximum differential between front and rear tire dia is 1" and the combo your running exceeds that. A 285 dia is 26.6" so the difference with the 345"s would be .3" well below 1".
Old Jul 16, 2020 | 02:46 PM
vicq's Avatar
vicq
would a 285/3519 fit with out any rubbing issues and still be within the threshold
To ****Problem Please Help*****
Old Jul 16, 2020 | 02:52 PM
rodomotive's Avatar
rodomotive
The 285 is .4 narrower than the 295 (11.8" vs 11.4")
Old Jul 16, 2020 | 03:48 PM
vicq's Avatar
vicq
right but i said 285/35r19 which would make the diameter correct? or would that not work then
Old Jul 16, 2020 | 04:11 PM
Creatre's Avatar
Creatre
It's the ratio that matters not the raw numbers.
26.6/25.8 = 1.031 and 27.2/26 = 1.046 which is fine.
Taken from Bill D in another thread: The car doesn't know what diameter tire is installed. It only knows the stock difference in wheel speeds when going down the road in a straight line at a steady speed. Use a ratio to set your tire diameters for the C7 it is the ratio of rear diameter divided by front diameter.
