Fuel Door Locking System
Old Aug 13, 2020 | 10:04 PM
2ndvett01's Avatar
2ndvett01
Default Fuel Door Locking System
2019 1lt: is there a way to to set up door locks to avoid gas fill door not opening?
Old Aug 14, 2020 | 12:51 AM
Jeff V.'s Avatar
Jeff V.
I've got this on my to-do list for winter hibernation.
https://www.corvetteforum.com/forums...ver-2-0-a.html
Old Aug 14, 2020 | 08:54 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
You can do what post #2 shows or you can put a scrivet in the hole and not allow it to lock. That's what I did.
Scrivet GM 963-021
Size of scrivet
Head Diameter 5/8"
Stem Diameter 3/8"
Stem Length 3/4"
5/16" body panel retainer Autozone 464340
http://www.clipsandfasteners.com/X_M...search=%205643
Just push one of those into the locking hole and be done with it.
Elmer
Old Aug 14, 2020 | 11:47 AM
2ndvett01's Avatar
2ndvett01
Elmer, Thank you for the help. What hole does the scrivet go in? On the fuel door arm there is a round hole on the side and a opening on the top. I can’t tell how the mechanism operates. Please advise.
Old Aug 14, 2020 | 12:31 PM
eboggs_jkvl
Moderator emeritus
https://www.corvetteforum.com/forums...post1600496890
That's all you need do.
Elmer
Old Aug 16, 2020 | 05:07 PM
Avanti's Avatar
Avanti
Just put whatever you wish into the hole the pin "moves" into, such that it can no longer do so. I did mine so long ago I cannot recall what I used. Just another lack of forethought/concern on GM's part. All the best.
To Fuel Door Locking System
