Caliper Rebuild
Old Aug 23, 2020 | 04:12 AM
olblue75's Avatar
olblue75
Default Caliper Rebuild
Looking for a set of caliper pistons for the rear of my GS with non Z07 brakes.
Rock Auto has them for 42 dollars a set but they are plastic/phenolic
Racing Brake has them for 200 dollars a set and they are vented and made of stainless
Really want stainless but 400 bucks just in pistons is ridiculous and I know they were on sale a month or so ago at 133 a set/per side but apparently that’s changed.
Anyone know of another alternative??
Old Aug 23, 2020 | 11:34 AM
99vetteran's Avatar
99vetteran
Have you priced just buying new rear calipers?
Old Aug 23, 2020 | 03:18 PM
X25's Avatar
X25
Sr.Random input generator
+1, at that price, you might as well:
Calipers (black):
23198738 23198738
23198739 23198739
They used to be $220/caliper, but Amazon jacked up the price once demand increased : (
Old Aug 23, 2020 | 08:01 PM
Bill Dearborn's Avatar
Bill Dearborn
What is wrong with reusing the pistons you have? Usually a fine Emery cloth will clean up pistons that have some deposits on them. Yours are only 4 years old at a max.
Bill
Old Aug 24, 2020 | 07:53 PM
olblue75's Avatar
olblue75
My calipers have been powder coated so new ones are not a option and my old pistons I trashed taking them out of the housing. I even did the air trick but still had a hard time getting them out.
Old Aug 24, 2020 | 10:44 PM
Bill Dearborn
I can't be certain but the GM rebuild kits may include a new set of pistons along with the proper assembly lube to make it easier to get the pistons installed. If you don't use the proper assembly lube the new seals will get torn when the pistons are pushed in. It should take almost no force at all to push the pistons in place when using the lube. The vast majority of auto parts stores don't carry assembly lube since they no longer sell rebuild kits. Ask one of the clerks and you will get a blank stare and then a recommendation for brake caliper slide lubricant which is not something you want to use.
Bill
Old Aug 28, 2020 | 11:23 PM
olblue75's Avatar
olblue75
Trying to get away from the plastic pistons and yes you can get complete kits from Rock Auto but again their plastic.
Old Aug 31, 2020 | 07:19 AM
olblue75's Avatar
olblue75
Bump
Old Aug 31, 2020 | 03:27 PM
ErnieN85's Avatar
ErnieN85
Try Zeckhausen Racing
Old Aug 31, 2020 | 05:29 PM
Bill Dearborn
Anything wrong with plastic?
Bill
Old Sep 1, 2020 | 08:39 AM
olblue75's Avatar
olblue75
Default Pistons
No pistons just seals and boots.
Old Sep 1, 2020 | 09:17 AM
ErnieN85's Avatar
ErnieN85
give them a call
Old Sep 1, 2020 | 03:01 PM
Bill Dearborn
Ernie is right. Give them a call. They may not have the pistons but they may be able to point you in the right direction or tell you there are no other options than plastic pistons. They have helped me many times over the years when I was trying to fix a problem.
Bill
To Caliper Rebuild
