Evap code P0446 below 1/4 tank
Old Sep 7, 2020 | 06:51 AM
n_brio's Avatar
n_brio
Default Evap code P0446 below 1/4 tank
I have a 2015 z06 and when im below 1/4 tank i got the code P0446.
Anyone else who has experienced this problem? Or know what the problem is?
Old Sep 8, 2020 | 08:31 PM
Bill Dearborn's Avatar
Bill Dearborn
The gas tank isn't venting properly and there is too high of a vacuum in the tank. Could be your Evaporative Emission Cannister, Evap Cannister Solenoid Valve or Fuel Tank Pressure Sensor. Need access to special test tools to fault isolate.
A scan tool that can read fuel tank pressures and that can issue commands to the fuel system
CH-44284-2 Fuel Flapper Door Holder this might be your gas can fuel fill adapter
GE-41415-60 Capless Fuel Adapter
GE-41413-A Evaporative Emissions System Tester (EEST)
Bill
Old Sep 26, 2020 | 06:04 AM
n_brio's Avatar
n_brio
i have now changed the following parts and still the same problem:
- Vapor Canister Purge Solenoid
- Vent Control Solenoid
- Pressue Sensor
- Hose/pipe from back of the engine to intake
Old Nov 10, 2023 | 07:31 AM
rsting3's Avatar
rsting3
4th Gear
- Pressue Sensor
Where is the vent control solenoid located? I'm getting P0446 code on my 2016 C7.
Old Nov 11, 2023 | 07:14 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
First you have to understand what sets that DTC…the EVAP Purge Solenoid opens and the Vent solenoid closes and once there is a certain vacuum in the tank the Vent Solenoid opens and the ECM is watching the vacuum decrease via the Fuel Tank Pressure Sensor as a voltage…if the vacuum doesn’t decrease to near atmospheric pressure the DTC sets….could be a bad vent valve but also a blockage in the EVAP cannister or maybe a bad fuel tank pressure sensor or partially stuck open purge valve keeping vacuum in the tank….without a factory level bidirectional scan tool you’ll only be guessing….the vent valve (#3) is located in the right rear wheel well area…seek out a diagnostic shop near you and don’t waste money shot gunning parts.
To Evap code P0446 below 1/4 tank
