Bilstein shock question
Old Sep 11, 2020 | 08:01 PM
First Stingray's Avatar
First Stingray
Default Bilstein shock question
Anyone know the differences between the Bilstein B8 and B6 shocks for the C7? Im planning on upgrading my base Stingray with these or the stock Z51 shocks. My Stingray is stock height and with the base leaf springs. Any input is appreciated. Thanks.
Old Sep 11, 2020 | 10:22 PM
Fast6.3's Avatar
Fast6.3
B6 is what you want b8 is stiffer if you autocross the b8 would be better but otherwise b6
Old Sep 11, 2020 | 10:25 PM
RacerRik's Avatar
RacerRik
Stock Z51 non-mag ride shocks are perfect for the Base C7. I put them on my car and recommend them 100%!
I drive my car aggressively and use it for autocross. The Z51 shocks are just right - much stiffer than the original shocks but not so stiff as to be harsh and un-compliant.
Old Sep 11, 2020 | 10:29 PM
Fast6.3's Avatar
Fast6.3
The b6 are a whole lot better than th z51 shocks
Old Sep 11, 2020 | 10:31 PM
RacerRik's Avatar
RacerRik
Better in what way?
Old Sep 13, 2020 | 09:34 AM
Fast6.3's Avatar
Fast6.3
Originally Posted by RacerRik
Better in what way?
they handle as good or better than z51 non mags and the ride is smoother
Old Sep 13, 2020 | 12:56 PM
Iceaxe's Avatar
Iceaxe
^^^This man knows what he is talking about. The Bilstein is just a better shock all around and the difference is noticeable. For the extra $100 to buy Bilsteins this is a no brainer.
Old Sep 13, 2020 | 02:59 PM
First Stingray
I thought the OEM Z51 shocks were manufactured by Bilstein. Is the B6 that much better? Which of the two provides the most stiffness? That is what I am looking for.
Old Sep 13, 2020 | 08:15 PM
Fast6.3's Avatar
Fast6.3
go b8 than
Old Sep 13, 2020 | 09:00 PM
RacerRik's Avatar
RacerRik
I have no experience with aftermarket B6 or B8 shocks. I do have experience with OEM base shocks and GM Z51 shocks on my base Stingray. Both OEM base and Z51 shocks are made by Bilstein to GM specifications. They both are stamped with Bilsteins name on them so that is not just an internet story. You can bet GM did plenty of development work to come up with shock specifications that are optimized for the C7 platform. I think you will be very happy with the Z51 shocks. I know I am!
Old Sep 14, 2020 | 12:49 AM
First Stingray
Are you certain the B8 shocks will fit on a standard height Stingray? I thought they were slightly shorter and designed for a lowered car...
Old Sep 14, 2020 | 12:50 AM
First Stingray
I will most likely go with the OEM Z51 shocks. Still trying to figure out best option.
Old Sep 14, 2020 | 04:48 AM
Iceaxe's Avatar
Iceaxe
Bilstein B6 and B8 shocks are the same shock physically. The internal valving is the difference and the B8 are firmer and more performance oriented. The B6 or B8 will fit any C7.
Old Sep 14, 2020 | 09:39 AM
First Stingray
https://www.bilstein-shocks.co.uk/bl...nd-bilstein-b8
Iceaxe - take a look at this Bilstein link. This is what makes me think the B8 shocks won't fit. I want the stiffness and performance of the B8 but am skeptical it will work after reading this. Remember, I have a base Stingray with the base leaf springs. Perhaps the B6 will be best. Thanks.
Old Sep 14, 2020 | 11:14 AM
RacerRik's Avatar
RacerRik
I suggest doing yourself a huge favor and just use the high performance Z51 shocks that GM spent a bunch of time developing for your car. You do know the spring rates on your Stingray are the same as the Z51 rate for the front spring and only around 7% softer for the rear spring right? If you add Z51 shocks plus the Z51 sway bars, you essentially have a Z51 suspension on your base Stingray.
I have to wonder about where the other guys giving you information get that info. Obviously some of it is wrong. Bilstein B6 and B8 shocks are certainly not physically the same. The link you provided proves that.
Old Sep 14, 2020 | 05:57 PM
Fast6.3's Avatar
Fast6.3
https://m.tirerack.com/suspension/Su...Standard+Model
Old Sep 14, 2020 | 06:02 PM
Fast6.3's Avatar
Fast6.3
Bilstein does make the c7 shocks to gm specs but the base shocks feel like you're on a boat and without the reat sway tons of understeer the z51 shocks do handle good but stiffer the ride a-lot the b6 or b8 are better valved gm went to both ends of the spectrum Super soft
super hard the happy medium are the mag shocks and to make another point most racers remove the magshocks and use Bilstein or penske coilovers
To Bilstein shock question
Old Sep 14, 2020 | 06:47 PM
Fast6.3's Avatar
Fast6.3
Old Sep 14, 2020 | 06:53 PM
Chris_G's Avatar
Chris_G
St. Jude Donor '05-'06-'07
Old Sep 14, 2020 | 10:04 PM
First Stingray
Thanks for all the info. I already have the OEM Z51 sway installed so I'm just going to go with the OEM Z51 shocks. Will most likely order from Gene at Cultrag. Thanks.
