Range Technology AFM Question
Old Oct 21, 2020 | 01:28 PM
LT1 Power's Avatar
LT1 Power
Default Range Technology AFM Question
Hey everyone, I have a quick question about the Range Technology AFM Disabler. Last week I had ordered on from Amazon for $194 (The RA003R Model) and the box shows its a 2020 version, but when I plugged it in I noticed the car still switches to V4 mode, not as often but still doing it. I see it on the dash and also of course the exhaust note changes. So I requested a replacement from Amazon and today but it, and the new one is doing the same thing.
I plugged it in before I started the car, so I assume there is not much more I can do wrong correct? LOL
2014 Stingray Z51 in case that matters.
Old Oct 21, 2020 | 05:47 PM
seniorstorekeeper's Avatar
seniorstorekeeper
That is the way mine worked, had 16 Stingray with A8, plugged the range device into the port, then cranked the engine and let it run about 2 or 3 minutes, the LED lights starting flashing and went through a start up sequence that lasted less than a minute, never went into V4 again. Pretty much bullet proof if the unit is working correctly.
Old Oct 21, 2020 | 05:48 PM
mliebs's Avatar
mliebs
You need to plug it in and hit the start button without your foot on the brake. Wait a few seconds and then start the car. If you just get in the car and start it the device doesn't work. I called range about mine and that's what they said to do.
Old Oct 21, 2020 | 07:24 PM
DTOM's Avatar
DTOM
C7 of Year Finalist (performance mods) 2019
When you first plug it in to the OBDII port, it does a series of blinks.
These blinks are the revision number. I think the latest version is 8.6.3. So 8 blinks, then 6 blinks, then 3.
Old Oct 21, 2020 | 07:42 PM
mountainears's Avatar
mountainears
2017 C7 of Year Finalist
I never do that. I just start the car, works every time. 2017 GS, have been running the Range device for about 15k miles now.
Old Oct 21, 2020 | 08:22 PM
LT1 Power's Avatar
LT1 Power
I know, but how does this help answer why it’s not working? Lol
Old Oct 22, 2020 | 03:48 AM
BillyC7's Avatar
BillyC7
You should have bought it directly from Range Technology, not Amazon. I did and have never had a problem. Others have said that Range will work to fix the device when returned with a problem if bought from them.
Old Oct 22, 2020 | 09:21 AM
LT1 Power's Avatar
LT1 Power
I am sending both back that were from Amazon, and going to re order from Range Technology directly
Old Oct 24, 2020 | 10:48 AM
meadowz06's Avatar
meadowz06
St. Jude Donor '09 and '13
You plug the Range device in, and that’s all. Mine works flawlessly. Send it back.
Old Dec 12, 2020 | 01:10 PM
freddieg's Avatar
freddieg
I have a 16 z51 since new, started hearing noises from the right side during the period of barely pressing the gas pedal on and off, about when the car is doing its 4/8 decision. I installed the range finder and no more noise and the car shifts better at all times! 21k miles.
To Range Technology AFM Question
