500 hp?
Old Dec 1, 2020 | 07:22 PM
topdownc6's Avatar
topdownc6
Default 500 hp?
I just purchased a base 2017 convertible and would like to hit 500 - 525 hp with minimal investment. Is this possible? I am thinking a VARARAM cold air intake and a tune.
Is this is a reasonable & achievable goal or is my hp hopes too high?
Any other cheap upgrade opinions are welcome!
Old Dec 1, 2020 | 08:28 PM
Zipnbyeu's Avatar
Zipnbyeu
On a LT1 N/A build to hit 500-525 rwhp you are going to need to add long tube headers,cam, heads, intake, throttlebody, and cai plus a tune and throw in E85 and you will be at the number you want. And look to spend anywhere between 8000 to 15000K
Old Dec 1, 2020 | 09:12 PM
406Miles's Avatar
406Miles
LMR has this for 530HP:
  • LMR Cold Air Induction System
  • 1 7/8 Stainless Steel Headers with catted connection pipes
  • NGK Spark Plugs
  • Firecore 8.5mm Spark Plug Wires
  • LMR Billet housing w/ 160* Thermostat
  • Professional Installation & Assembly
  • Custom engine control module reprogramming
  • Chassis Dyno testing before & after installation
$4,999.99
Old Dec 2, 2020 | 09:04 AM
mittens's Avatar
mittens
I hit 500 RWHP with both C7 LT1s I have had
one had intake, DOD delete cam, Headers, off road X.
One had stock intake, DOD delete cam, headers and off road X.
But a tune and intake are not going to do it.. ha will nee cam, and headers
Old Dec 7, 2020 | 07:52 PM
lakemg's Avatar
lakemg
I suspect that the OP is looking for 500 - 525 flywheel hp...which shouldn't be too difficult to attain. Thinking CAI, LTs, intake manifold, and tune should be fairly close to 500 hp at the flywheel.
Old Dec 8, 2020 | 05:35 AM
davidtcpa's Avatar
davidtcpa
Go Canes!
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
Supercharger.
Old Dec 8, 2020 | 10:25 AM
JUICED1's Avatar
0JUICED1
Former Vendor
If you're looking for 500hp our Stage 1 package will get you there. If you want to bump it up a few more HP add a ported throttle body.
If you're looking for 500rwhp a cam is needed for sure. Check out our stage 2 package. We can generally run this package from 485-525rwhp depending on cam selection. With E85 and some ported heads/manifold we can close in on 600rwhp.
Old Dec 8, 2020 | 03:32 PM
2ZORNOT2Z's Avatar
2ZORNOT2Z
CAI and a tune won't net you much on an LT1 without other supporting mods. E85 flexfuel sensor and a tune alone will get you pretty close if you are talking about 500 at the flywheel on the cheap, assuming you have E85 available around you. The flexfuel sensor and tune will be around $1k installed. I'd add a CAI at the same time for another 10-ish flywheel horsepower. LTs will take you closer to 530 flywheel horsepower with the flexfuel and CAI but they are $3-6k installed, depending on what you pick. For that money you could almost add a Maggie 2300 to your stock car and forget about it with way over 500 flywheel horsepower.
Old Dec 8, 2020 | 03:38 PM
99vetteran's Avatar
99vetteran
I have E85, long tubes, x pipe and mine only made 451rwhp. Which is 510-525 at the crank. You'll see a little more if you have a Manual Trans. Doesn't matter what it makes on the dyno its at the track that shows the most.
Old Dec 15, 2020 | 11:46 PM
GT2BHPPY's Avatar
GT2BHPPY
2017 LT1 A8, 500 RWHP with E-Force Stage 1 and long tubes. LT's didn't really add much, but it's the sound that they make that is worth the price.
Old Dec 16, 2020 | 09:41 AM
JUICED1's Avatar
0JUICED1
Former Vendor
Long tubes won't add as much on a boosted car as an N/A car.
Old Dec 17, 2020 | 07:52 AM
mittens's Avatar
mittens
My 2014, made 431 rwhp / 449 rwtq with Kooks LT, and Off road X and a AFE intake only.
then did cam swap, 505rwhp / 474rwtq.
Never baselined it.
To 500 hp?
