C7 won't start
Old Dec 3, 2020 | 12:06 PM
finger63's Avatar
finger63
Cruising
Default C7 won't start
My C7 will not do anything. replaced battery in my 2016 corvette z51 convertible with new GM, car will not start, no horn no headlights just running lights, replaced both key fob batteries, key fobs will not function, placed key fob in steering column still car will not start. to enter car must use key to enter trunk & release driver door with emergency release in trunk. to exit car must use door release lever on floor. HELP PLEASE
Old Dec 3, 2020 | 12:43 PM
Flame Red's Avatar
Flame Red
Two thoughts.
Defective new battery? Did you check the new battery?
I maybe the fusible link?
Old Dec 3, 2020 | 01:09 PM
HOXXOH's Avatar
HOXXOH
You have no power. If you just changed the car battery, you either bought a bad battery, broke or don't have a good/clean connection, or installed it backwards.
Old Dec 3, 2020 | 01:21 PM
finger63's Avatar
finger63
Cruising
Originally Posted by Flame Red
Two thoughts.
what is fusible link? do you mean possibly a relay in the engine fuse box. If so which fuse would you suspect. thanks
Old Dec 3, 2020 | 01:30 PM
Kouasupra's Avatar
Kouasupra
Get a voltmeter and see where the voltage is at. If you’re getting at least the running lights on then perhaps your new battery is low on power. Start there first.
Old Dec 3, 2020 | 01:32 PM
finger63's Avatar
finger63
Cruising
Also tried jump starting without success. thanks
Old Dec 3, 2020 | 01:34 PM
finger63's Avatar
finger63
Cruising
battery can only be installed one way . connections are clean & tight. battery was new from dealership. I've never purchased a new battery which was itself dead
Old Dec 3, 2020 | 02:16 PM
JMII's Avatar
JMII
Get a volt meter and start poking around - either the battery is truly dead or something isn't allowing the current to flow. Could be a bad ground connection, the ground wire itself or a blown fuse on the positive side. Start at the battery and work outwards from there.
I've had battery cables go bad in my boat before, the wire corrodes from the inside out so the connection is fine but the juice will not flow. Now with a garage kept car critters might have chewed thru a wire.
Old Dec 3, 2020 | 02:25 PM
finger63's Avatar
finger63
Cruising
thanks flame red
Old Dec 3, 2020 | 02:59 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
There's a 350a fuse on the top of the battery. Did you kill it?
Elmer
Old Dec 3, 2020 | 05:57 PM
ersatz928's Avatar
ersatz928
There have been posts here on the forum, where the battery has been replaced, and similar problems have occurred.
The issue was that when the positive battery/fuse-block terminals was re-installed and tightened, one of the flat metal strap connection sections did not actually sit flush against another metal strap connection, even though the bolt was tightened. This causes a high resistance connection. Undo the bolt on the positive fuse block connection, and make sure that the 2 (?) flat metal plates/connections are really against each other, not cocked, before tightening the bolt.
See post#3 in the below thread:
https://www.corvetteforum.com/forums...rol-panel.html
Old Dec 3, 2020 | 09:29 PM
Avanti's Avatar
Avanti
I have bought a number of faulty new batteries over the years, including what will be my last Optima that would not hold a charge of more than 9 volts two day after being fully charged... out of the car. So, it happens. That's were to start.
I've also seen a battery cable with completely invisible internal corroding at the molded battery terminal. It looked brand new, the contact was cleaned and tight... intermittently dead. It drove us all nuts until wiggling the cable... a lot... disclosed it. So, don't discount anything without a thorough check. All the best.
Old Dec 4, 2020 | 09:00 AM
C7&7's Avatar
C7&7
This.....AFTER the battery is verified with a meter.
To C7 won't start
