ARH Headers & X-pipe. Normal or poor quality?
I got them today, and I'm not exactly excited about them. The headers themselves seem like pretty decent quality, but one of them has a dent in one of the primarys, right by the collector. I'm not 100% sure this is a defect though? Maybe it's intentional for fitment with the 2" primarys? It's a bit hard to see in the pictures, but if you look closely you can see where the bottom primary is dented in right at the collector. The real concern I have is with the X-pipe. The welds and everything are just god awful. The pictures below do not do it justice. I looked inside and literally said "What the ****..?" It's hard to tell, but it is extremely jagged, and quite unsymmetrical. It looks like the two pipes had the crossover port cut into them separately and then were sloppily welded together, but it looks like they weren't perfectly lined up before they were welded. Also, the O2 sensor bung threads on the X-pipe are jacked up. The X-pipe just all around seems very crude and unfinished. I'm sure technically they would work just fine, I just know that the X-pipe that came with the $450 Speed Engineering headers looked so much better than this. For $2000 I kinda expected better
If anyone who has also had a set of ARH headers could pitch in their thoughts. How did yours look compared to these? Is the dent on the primary on the passenger side normal? Am I being too picky or should I contact LMPerformace, who I ordered them from? Or maybe go directly to ARH? If the dent on the primary is normal, I may ask if it's possible to just exchange the X-pipe.
Looking into the X-pipe
So far, it sounds like they take care of their customers.
but the dent is there to clear the starter. Gives your about a 1/4in clearance.
Tip - install the headers and leave the passenger side loose, then attach the x pipe. I used a trusty swiffer to hold things in place.
Yes you need to leave everything loose till you get everything installed and then start tightening up starting at the header flanges bolts working your way back aligning and tightening as you go . Pay particular attention to the alignment of the x pipe and mufflers so you don't end up with rattles. Also make sure you secure the o2 sensor wires
Dave
