Window indexing issue
Old Dec 11, 2020 | 08:45 PM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
Default Window indexing issue
2016 Z06 coupe. Re-indexed windows several times. 1 out of every 5 times the driver's side window will not index on exit. Cleaned the door pad and still have issue. Is there a part that controls the window indexing function? Thanks
Old Dec 11, 2020 | 10:24 PM
Elk's Avatar
Elk
Have you tried disconnecting the battery for a bit, or are you trying to get the windows indexed after already disconnecting the battery?
Old Dec 14, 2020 | 02:49 PM
Tally Ho's Avatar
Tally Ho
Did that and worked for a series of 4 tries (open/close door) but on the 5th it would not index. Still troubleshooting. Thanks.
Old Dec 14, 2020 | 05:27 PM
Elk's Avatar
Elk
Frustrating.
I hope you get it figured out soon.
Old Dec 14, 2020 | 06:31 PM
RonC7's Avatar
RonC7
Does the window fail to index after the car has sat for a few days?
Is the battery original equipment?
Weak / old batteries can cause all kinds of electrical gremlins.
Just a thought...
Ron
Old Dec 15, 2020 | 08:46 AM
Tally Ho's Avatar
Tally Ho
New battery seems to have fixed it. Car does sit periodically but is on a tender when it sits.
Old Dec 15, 2020 | 12:03 PM
Maxpowers's Avatar
Maxpowers
New battery seems to fix a lot of elec issues... even if the old one seems OK. Glad it worked out for you.
To Window indexing issue
